Results 1 to 5 of 5
Like Tree3Likes
  • 1 Post By Twiceroadsfool
  • 1 Post By tzframpton
  • 1 Post By josephpeel
Thread: Transparent Material for Clearance Areas
    February 22, 2013
    317
    10:17 PM
    Hey everybody. So I have a VAV family which requires a clearance area to the side for access to the electrical panel, motor, etc. I want to use an extrusion to show this clearance area, so that it will be visible in section and 3D views as well as plan views. I've created a Subcategory called "Clearance Areas" and applied the desired Line Style to it, so it will appear dashed.
    My problem is that I want this clearance area to be transparent. I created a material with its transparency set to 100 and applied that to my clearance area extrusion. It looks transparent in the Family Editor (see picture), but when I load it into my model, it's Opaque. (second picture.) There's a controls box inside the clearance area that I want to be visible through the clearance area. Can someone clue me in? Did I miss a step somewhere? Thanks for reading!
    Attached Thumbnails Attached Thumbnails Transparent Material for Clearance Areas-box_family-editor.png   Transparent Material for Clearance Areas-box_plan-view.png   Transparent Material for Clearance Areas-box_plan-view.png
    10,036
    09:17 PM
    Its only going to be transparent in views that show things in Shaded mode, or Realistic Mode. To do what you are after, you have a couple of options:
    1. Use a Shared/Nested Family for the clearance, that can be Filtered/Set to transparent in plans.
    2. Use a solid for 3d views and exporting to navisworks, and ALSO use Lines (model or symbolic) that show up in flat views.
    cganiere likes this.
    April 5, 2017
    Ohio, USA
    1
    09:17 PM
    In the example above from Necro99, is there a way to set the bottom of the clearance area to be at floor level to see what crosses above ceiling that could potentially hinder access, and furniture or equipment below ceiling that could make it tough to get a ladder in place?
    January 17, 2011
    1,982
    09:17 PM
    This is what I do. In the Family Editor, I set the clearance geometry to only show in 3D, while using 2D symbolic lines to represent Plan and Section Views in a dashed linetype.
    Quote Originally Posted by MSDCADMgr View Post
    You could use an instance based parameter to set this. I don't know of an automatic way unless you were to use a custom offset method where the family itself is offsetted within the Family, rather than the Project based Offset.
    -TZ
    May 3, 2012
    1,396
    04:17 AM
    Shared families are the way to go for MEP families, as they are unaffected by System overides for colour or material.
    Twiceroadsfool likes this.
  1. Custom Areas added to Room Areas
    By Munkholm in forum Dynamo BIM
    Last Post: February 18th, 2016, 02:13 PM
  2. Scheduling Areas from multiple files. Can blank rows be added for missing areas?
    By kescr in forum Architecture and General Revit Questions
    Last Post: October 22nd, 2014, 12:10 AM
  3. Render Transparent Material
    By safoulkes in forum Architecture and General Revit Questions
    Last Post: September 13th, 2012, 06:17 PM
  4. Transparent material
    By yil5167 in forum Architecture - Family Creation
    Last Post: June 5th, 2012, 05:14 PM
  5. Transparent Glass not transparent in Section View
    By Elisa in forum Architecture and General Revit Questions
    Last Post: December 17th, 2010, 06:02 PM
