Results 1 to 3 of 3
Like Tree1Likes
  • 1 Post By RenChan
Thread: diffuser family issues
    Member Darius's Avatar
    May 6, 2013
    482
    10:11 PM
    i just started at a new firm and they have alot of families that do not work they want. So i started fixing some them as problems arise. How ever i modified there diffuser. It seems to work right most of the time but sometimes when you align it to a ceiling grid it will grow and not shift. to add to that it is not every diffuser its just some of them.
    I also can not recreate this in another project file
    Attached Thumbnails Attached Thumbnails diffuser family issues-starting-position.png   diffuser family issues-align-right.png   diffuser family issues-align-left.png
    Attached Files Attached Files
    Gold Coast
    2,602
    12:11 PM
    No revit atm so cant see your family. First thing i would do is review the strong/weak/none settings for the reference planes. Typically, strong will stretch the family, weak will move the family and none won't even be seen in the project.
    Junior Member RenChan's Avatar
    March 30, 2016
    25
    07:11 PM
    Because the parameters in the family are Instances, they are trying to look for the size in the project. I would make the TERMINAL SIZE parameter a Type Parameter instead of an instance since the family itself is using types for the varied sizes. If you just modify that parameter it should be fine. Hopefully that will fix your issue.
    elton williams likes this.
  1. Replies: 3
    Last Post: January 10th, 2017, 02:56 AM
  2. Diffuser Visibility - Strange
    By bmcdaniel in forum MEP - General
    Last Post: July 13th, 2016, 01:38 AM
  3. Diffuser family does not actually attach to the Ceiling Grid?
    By amoroso in forum Architecture and General Revit Questions
    Last Post: December 22nd, 2015, 04:49 PM
  4. Loading of Diffuser family
    By zacoolm in forum MEP - General
    Last Post: April 22nd, 2013, 07:54 PM
  5. Titus diffuser families
    Last Post: February 20th, 2012, 05:24 PM
