Results 1 to 1 of 1
Thread: Fabric Duct / Multi Connector Air Terminals
    Junior Member sumex's Avatar
    May 17, 2011
    New Hampshire
    14
    10:41 PM
    Ok, so I am wondering if anyone has ever made an air terminal that can pass its flow THROUGH it while it also diffuses air. I had thought by linking the connectors, I might be capable of doing this, but so far, no joy.
    Basically, what I am trying to do is trick Revit into considering Fabric Duct. I've got the math right and the flow calculates swimmingly, but it only works on branch runs. It won't allow air to pass THROUGH the air terminal and also keep going. Basically, I made a simple air terminal that's nothing more than a cylinder with a connector on each end. I had linked the two connectors, hoping it might pass the flow upstream, but no joy.
    Any ideas?
  1. Is it possible to array air terminals on a duct?
    By danezeq in forum MEP - General
    Last Post: August 10th, 2016, 11:36 AM
  2. Duct connector array
    By saifsaad in forum MEP - Family Creation
    Last Post: February 21st, 2016, 04:53 PM
  3. AHU Duct Connector Size Changes
    By LiMe in forum MEP - Family Creation
    Last Post: February 9th, 2016, 12:09 PM
  4. Automatic duct connector changes
    By aykhan9 in forum MEP - Family Creation
    Last Post: July 15th, 2014, 02:30 AM
  5. Duct Connector Configurations
    By W.Neuok in forum MEP - Family Creation
    Last Post: July 19th, 2011, 02:48 PM
