Results 1 to 4 of 4
Like Tree2Likes
  • 2 Post By cellersick
Thread: Rotation Error
    October 18, 2016
    26
    03:09 AM
    Rotation Error
    Hello evryone,
    I'm having troubles with the rotation of a simple extrusion. ( In a Metric Generic Model )
    I made this extrusion with a different centerpoint where it is supposed to rotate. and added here a reference line to make the rotation work -> see image 1
    After that I Loaded this family ( Metric Genreric Model ) in another Family ( Also Metric Generic ) .
    Here i added the Parametric parameter to make a instance of that rotation. -> image 2
    The rotation works perfectly , as demonstration i setted a rotation on 90°, 10° and 50°.
    But as soon as i put the angle on 0° or 180°, the model isn't centered anymore and rotates however it wants .. -> Image 5
    Any suggestions ?
    Thank you in advance !
    Attached Thumbnails Attached Thumbnails Rotation Error-1.png   Rotation Error-2.png   Rotation Error-rot-10-.png   Rotation Error-rot-50-.png   Rotation Error-rot-50-error.png
    Attached Files Attached Files
    March 21, 2013
    Phoenix, AZ
    275
    07:09 PM
    Rotation is tricky. Try looking here:
    Simply Complex: ROTATION RIGS THAT DO NOT USE THE ANGLUAR DIMENSION
    - - - Updated - - -
    http://therevitcomplex.blogspot.com/2012/04/rotation-rigs-that-do-not-use-angluar.html
    cganiere and Allu like this.
    October 18, 2016
    26
    03:09 AM
    Looks like a great help.
    I'll try it right away.
    Thank you!
    October 18, 2016
    26
    03:09 AM
    Seems like nesting the family for each movement did the trick..
  1. 3d Extrusion Rotation
    By rboaz in forum Architecture - Family Creation
    Last Post: November 23rd, 2016, 04:51 PM
  2. Duct Tee rotation
    By brane1012 in forum MEP - Family Creation
    Last Post: September 17th, 2014, 01:40 PM
  3. rotation
    By mona miller in forum Architecture - Family Creation
    Last Post: July 27th, 2014, 10:47 PM
  4. Tag Family Rotation
    By darknes15 in forum Structure - Family Creation
    Last Post: June 19th, 2014, 03:30 AM
  5. object rotation
    By mona miller in forum Architecture and General Revit Questions
    Last Post: April 5th, 2014, 10:19 AM
