Results 1 to 3 of 3
Thread: Connectors
    April 29, 2011
    Pacifica, CA
    18
    05:04 AM
    Connectors
    Morning everyone,
    In our office (ACAD)we have a half shaded telephone outlet representing a combo Data/Tel outlet.
    Is is possible to create one in Revit. My question is are the connectors different? Am I able to insert both type of connectors?
    January 17, 2011
    1,982
    07:04 AM
    Quote Originally Posted by Rev Dawg View Post
    Morning everyone,
    Yes, absolutely possible. The connector can be whatever it needs to be... the symbol is the thing mostly in question. The connector simply holds the required electrical information for the connected load, so whatever that needs to be, make it so. Symbolically it can be whatever it needs to be via a nested Generic Annotation.
    -TZ
    Member Darius's Avatar
    May 6, 2013
    482
    08:04 AM
    make the outlet two seperate halfs that make up the whole size of the out let the connectors will not be on top of each other this way. the connectors look slight different one is a filled triangle while the other is an empty triangle
    still working out the best way to do shaded
    just remember the genric annotation will shrink and grow depending on the scale
    but yes generic annotation is the way to go some things came up here at work and i didn't get back to my post for awhile
    Last edited by Darius; November 7th, 2016 at 08:08 PM. Reason: didt finish post because i had work to do
  1. Mixing tap connectors
    By nick_h in forum MEP - General
    Last Post: August 31st, 2015, 03:30 PM
  2. Two questions about duct connectors
    By brane1012 in forum MEP - Family Creation
    Last Post: October 7th, 2014, 10:28 PM
  3. Families connectors to pipes
    By domsib in forum MEP - General
    Last Post: March 26th, 2013, 01:00 PM
  4. Disappearing Connectors in Families
    By becciasm in forum MEP - Family Creation
    Last Post: March 20th, 2013, 06:06 PM
  5. Connectors and nested faces
    By Randy_CaS in forum MEP - Family Creation
    Last Post: June 21st, 2011, 03:59 PM
