Page 1 of 2 12 LastLast
Results 1 to 10 of 12
Thread: Family Too Small
    March 20, 2013
    12
    08:54 PM
    Family Too Small
    I'm having a problem building Revit families - I need to draw lines and fill the center, but apparently the area is too small. I have this problem a lot when revising the family - it says the line is too short. It seems like the family needs to be built larger and scaled down when inserted into the drawing. Is there a way to do this?
    December 21, 2010
    C.LONDON
    4,353
    03:54 AM
    Quote Originally Posted by JasonA. View Post
    There are hacks that sometimes work to beat Revit's working limits, but let's first understand what - and why - you are modelling...
    March 20, 2013
    12
    08:54 PM
    I work on things like fire alarm and security, and there aren't many families built into Revit MEP for that, so we have to build some of our own. We mostly work in 2D drawings, so we usually just build them with lines and need to fill some spaces. Like this smoke detector, where the backwards "S" needs filled in the center:
    Member Darius's Avatar
    May 6, 2013
    482
    10:54 PM
    so your drawing annotation symbols then?
    so y arent u doing any of this in 3d since your using revit?
    I work at an MEP firm and we do have a bunch of symbols to draw schematics but we still make everything in 3d including thermostats a 2d symbol can be place inside a 3d family for layout veiws if that is all u want to see
    March 20, 2013
    12
    08:54 PM
    Sorry, I wasn't very clear. They are families. There are times that we have to show devices in a cut plane view, I just need to fix the 2D portion.
    May 6, 2013
    482
    10:54 PM
    I'm think it the problem that we sometimes run into with are symbols in for schematics in revit where the scale is set as such that the symbol appears to be to large correct
    May 6, 2013
    482
    10:54 PM
    like this with the pump symbol
    March 20, 2013
    12
    08:54 PM
    Exactly. Another example is the data symbol, which is built into Revit.
    May 6, 2013
    482
    10:54 PM
    what is the scale of your view? if u can take the scale from 1/4 to 1/2 shrinks the symbol i have made a small pump symbol but as you have found you can only go so far.
    If u make the object as small as it can go and then scale it down does that work?
    March 20, 2013
    12
    08:54 PM
    It will not allow me to scale it.
  1. RTC: Thinking Small
    By RTC in forum Blog Feeds
    Last Post: August 8th, 2016, 12:45 AM
  2. Just a small complaint
    By ryntau in forum Dynamo BIM
    Last Post: March 26th, 2015, 01:53 PM
  3. BimBlog: bim IS for small firms
    By BimBlog in forum Blog Feeds
    Last Post: June 30th, 2012, 12:15 AM
  4. Revit OpEd: A Small Collection of Family Editor Advice
    Last Post: April 9th, 2012, 03:15 PM
  5. How to create terrain or small mountains
    By niet in forum Architecture and General Revit Questions
    Last Post: September 13th, 2011, 05:43 PM
Tags for this Thread
