Results 1 to 8 of 8
Thread: Pipe Fitting Not appearing Consistently
    Junior Member RenChan's Avatar
    March 30, 2016
    25
    09:09 PM
    I have a long sweep elbow fitting that works beautifully in one project, but in a different project the angle fails. Can anyone help me troubleshoot this odd and frustrating issue?
    It only happens on the 45° angles. The annotation on low detail levels shows up correctly, but just the 3D element in that one project template it goes wrong and the fitting angle extends too far.
    Pipe Fitting Not appearing Consistently-bce-template-elbow.pngPipe Fitting Not appearing Consistently-am-template-elbow.png
    Thank you,
    -Ren
    Member Darius's Avatar
    May 6, 2013
    488
    12:09 AM
    I dont think they make 45 degree elbows the way you are showing them i know in my office when dont show them like that. because we cant find a company to make them that way.
    Attached Thumbnails Attached Thumbnails Pipe Fitting Not appearing Consistently-pvc-elbows.jpg
    May 6, 2013
    488
    12:09 AM
    they do make them but they are very expensive for a pvc fitting
    anyway post the offending family ill see if i can fix it
    I take that back it was pvc conduit not pipe
    Last edited by Darius; October 31st, 2016 at 06:07 PM. Reason: change in information
    March 30, 2016
    25
    09:09 PM
    These are long sweep elbows based off the dimensions my company needs for our in-house fabrication. It is programmed with the functionality to change angles, but the trick is that the family functions perfectly in one template, but not another. I based this off of a similar working fitting that behaved correctly, but did not have the long sweep.
    The generic fittings you find in Revit do not have this function and manufacturer's families have no functionality for adjustments, so typically I make my own. This is the first time I have had this particular issue though. It can be done and has been, just this time I am stumped on this error.
    May 6, 2013
    488
    12:09 AM
    have u tried running a recover on the file?
    Other than that your probably going to have to look at the api or the journal file to see what is causing the elbow to behave that way in one project file and not another
    March 30, 2016
    25
    09:09 PM
    March 30, 2016
    25
    09:09 PM
    I tried a recover with back-up files. The fitting can be inserted into both projects back and forth with the same results.
    How would I look at the api/ journal file?
    May 6, 2013
    488
    12:09 AM
    api is the actual computer code for revit so i would go with the journal file trying to recall the location where they are stored
    Revit OpEd: Revit Journal Folder and Saving Files on Network Drives
    this web site shows be default where they are stored
  1. Pipe Fitting Connections to each other/NO Pipe
    By se13gits in forum MEP - General
    Last Post: July 8th, 2016, 01:56 PM
  2. pipe fitting for XYZ-like tee
    By Ning Zhou in forum MEP - Family Creation
    Last Post: July 14th, 2015, 08:43 AM
  3. Pipe fitting. Who can help?
    By domsib in forum MEP - Family Creation
    Last Post: January 30th, 2015, 02:33 PM
  4. Pipe fitting issue
    By sabari2504 in forum MEP - General
    Last Post: January 30th, 2014, 09:50 AM
  5. Pipe Fitting Problem
    Last Post: January 16th, 2014, 11:43 AM
Tags for this Thread
