Results 1 to 6 of 6
Thread: Using floor based families in a linked model
    October 26, 2016
    18
    08:16 PM
    I have modeled a drain that pops up through the floor using a face based family template.
    When I load it into a project I get the desired result, below.
    When I load it into a project that is using a linked architects model, I get the below result.
    Am I using the wrong template? I have tried floor based template but It will not recognize linked floors.
    Member Darius's Avatar
    May 6, 2013
    484
    03:16 PM
    Is there a reason your not using a pipe for your drain?
    For the family it depends on how u oriented the family in the family editor how it attaches to the face of an object
    October 26, 2016
    18
    08:16 PM
    Quote Originally Posted by Darius View Post
    I am not using pipes because I am not modelling full systems, only plotting a preferred location of drain pop ups. I have attached a screenshot of the symbol we currently use in AutoCAD.
    Will I be able to host a symbol (similar to the attached) if I use a pipe?
    October 26, 2016
    18
    08:16 PM
    This is how the family looks in the family editor.
    Gold Coast
    2,617
    05:16 AM
    Quote Originally Posted by Sim_nn View Post
    Families won't cut through linked model geometry. For openings that small we don't even create openings, just represent the area in plan. Less geometry faces for Revit to calculate also.
    Make sure 'always vertical' is checked in the family properties to keep it vertical.
    October 26, 2016
    18
    08:16 PM
    I cannot see the ‘always vertical’ check box in family properties.
    The Autodesk website says ‘The option to create vertical families pertains only to families hosted by floors, ceilings, roofs, and site surfaces.’
    Can you recommend what template would be best to use?
  1. Floor based generic model - how to get dimension parameter into schedule?
    By therkelsenmeister in forum Architecture and General Revit Questions
    Last Post: January 28th, 2016, 01:15 PM
  2. Creating a floor based and wall based generic model in a single family
    By PraveenPonnuru in forum Tutorials, Tips & Tricks
    Last Post: September 10th, 2015, 04:16 PM
  3. Generic Model Floor Based Floor
    Last Post: June 6th, 2014, 04:19 PM
  4. Generic model floor based line weights
    By redmonki in forum Architecture - Family Creation
    Last Post: June 18th, 2013, 03:51 AM
  5. Make Generic Model Adaptive > Floor Based
    By qutaibah in forum Architecture - Family Creation
    Last Post: November 1st, 2011, 07:20 AM
