Results 1 to 6 of 6
Like Tree2Likes
  • 1 Post By josephpeel
  • 1 Post By Alex Page
Thread: Surface mounted electrical fixtures guidance
    October 26, 2016
    18
    05:48 AM
    Hi, first post on here so I'll introduce myself.
    I work for a small catering equipment distributor in the UK. I have built up a catering equipment library to the point where I can produce layout drawings, elevations etc...
    The next challenge I am faced with is mechanical and electrical service drawings. I have not had any training on revit MEP so I am currently exporting the layout from revit to autoCAD then drawing single line MEP symbols to provide my client with a drawing.
    When I attempt to add electrical fixtures from the autodesk library to my model revit will not recognise the walls. It is not recognising the walls because I am working off a linked model. I link the architects model into my project to keep the file size down.
    I have drawn and added the appropriate labels for a single switch socket outlet. But I am struggling to find any guidance on creating surface mounted (not wall mounted) fixtures. Has anyone come across a tutorial of this description?
    Thanks
    PS, I apologies for any misuse of revit terminology - I'm no expert.
    Member Darius's Avatar
    May 6, 2013
    488
    12:48 AM
    u will need face based families they attach to ceilings, walls, floors, and any other face
    May 3, 2012
    1,401
    06:48 AM
    My advice, (Which not everyone agrees with but is based on 5+ years experience with MEP projects) is to only use Level hosted fixtures. So they are just placed on the floor plane and with an offset height. Its not hard to align fixtures with the wall when you place them.
    Placing fixtures on the wall so that they move with the architects changes might sound like a good idea... but in practice I think it is much easier to be able to clearly see which fixtures are not aligned with the walls and re-align them, than have to find/manage which fixtures have moved or not, which fixtures have lost their host wall etc..
    Level based fixtures are also much easier to copy from room to room and floor to floor, saving a lot of time.
    If you really do need to place a fixture on a wall/panel/cable tray etc. this is still possible. You can edit the family and check the 'Workplane based' box. Then you can place the family on any face too.
    Heres an example.
    Attached Files Attached Files
    cganiere likes this.
    October 26, 2016
    18
    05:48 AM
    Quote Originally Posted by Darius View Post
    Thanks, Darius. I searched 'create face based family' and found what I was looking for. In hindsight, I think I was focusing my search on 'electrical fixtures and components'.
    My aim is to place various electrical components within my kitchen model with the intention of producing elevations like the attached, showing electrical outlet heights, avoiding clashes etc.. elevation.pdf
    In the plan view electrical components will be indicated by use of symbols (attached).
    I have modeled my face based electrical outlet and drawn my symbol for plan view.
    Surface mounted electrical fixtures guidance-symbol.pngSurface mounted electrical fixtures guidance-sso.png
    I have since discovered that annotation symbols cannot be attached to a face based family – it’s got to be a wall based family.
    I link architect’s models so wall based is not an option. I have tried the copy monitor method of converting face based to wall based but it was unsuccessful.
    October 26, 2016
    18
    05:48 AM
ID:	28391Click image for larger version.
    Senior Member Alex Page's Avatar
    December 13, 2010
    Wellington, New Zealand
    650
    04:48 PM
    Annotation symbols can be attached to a face based familiy: I posted a solution here:
    http://www.revitforum.org/architectu...tml#post175600
  1. Cannot Click My Electrical Fixtures
    By domsib in forum MEP - General
    Last Post: June 29th, 2016, 09:05 AM
  2. Place a electrical fixtures
    By rashid hasan in forum MEP - General
    Last Post: June 25th, 2015, 01:40 PM
  3. Tag for elevation of electrical fixtures
    By boriskam1991 in forum Architecture and General Revit Questions
    Last Post: August 14th, 2014, 04:42 PM
  4. Surface Mounted Electrical Devices?
    By Troy Stepp in forum MEP - General
    Last Post: April 4th, 2013, 01:56 PM
