Results 1 to 2 of 2
Thread: Linking Hydronic Supply/Return Pipe Connectors
    October 29, 2015
    6
    06:14 PM
    I'm working on a quite large project. We are gonna use Radiators for heating. We are limited to 6 PEX pipes per apartment. 3 Supply, 3 Return.
    The biggest apartments needs 6 Radiators, which means i need to connect them in a series, like the picture below.
    In reality we'll use a so called Quattro connector.
    I can draw the part in 3D in the Family Creator, but how do i connect the Connectors so Revit knows that they are coming from the same Main Supply/Return?
    So, I want Revit to know that, the Main Supply/return goes two ways. Like a Tee.
    Is this possible?
    Linking Hydronic Supply/Return Pipe Connectors-okwnwp.jpg
    Current solution, very time consuming.
    Linking Hydronic Supply/Return Pipe Connectors-24ywrbp.jpg
    Idea.
    Linking Hydronic Supply/Return Pipe Connectors-20h1on4.jpg
    Quattro Connector.
    Linking Hydronic Supply/Return Pipe Connectors-14315r7.jpg
    Quattro - Revit Family
    Attached Thumbnails Attached Thumbnails Linking Hydronic Supply/Return Pipe Connectors-bdqes6.jpg
    Member Darius's Avatar
    May 6, 2013
    488
    02:14 PM
    u can try linking the connectors with supply and return i think you need the connectors to be set to correct in and out and not bidirectional. if there set to bidirectional revit probably will not be able to calculate flow
  1. Hydronic Radiation Systems
    By evan.dodds in forum MEP - General
    Last Post: July 12th, 2015, 01:24 AM
  2. Replies: 2
    Last Post: July 12th, 2014, 06:13 AM
  3. Pipe are far form connectors
    By amarkrish108 in forum MEP - General
    Last Post: April 2nd, 2014, 09:57 AM
  4. Move Pipe Connectors in family
    By domsib in forum Architecture - Family Creation
    Last Post: March 18th, 2013, 10:35 AM
  5. Pipe Connectors move........
    By Ch2M_MikeMaloney in forum MEP - General
    Last Post: October 3rd, 2012, 09:20 AM
