Results 1 to 4 of 4
Like Tree1Likes
  • 1 Post By wongk2
Thread: Spigot - flexible duct to connect into a rigid rectangular duct
    September 2, 2016
    2
    12:33 PM
    Hi guys,
    I've been stuck for a long while on how to create this part. Essentially its a spigot which connects into the rigid duct for a flexible duct to connect onto; so a duct fitting; i've tried creating a tap- perpedicular or adjustable, still doesnt work. Even after I've load it into the project and try to get revit to auto route it, but no dice. I would really really really appreciate any advice. I've attached the family.
    Attached Files Attached Files
    January 17, 2011
    1,982
    07:33 AM
    Did you create this from scratch? Sometimes the best way to approach MEP Families not working is to start with the ones that come with Revit. Copy the most basic Tap Family and rename it. Open it up, and strip the things you don't need while adding the things you do, and see if it has better results.
    -TZ
    September 2, 2016
    2
    12:33 PM
    Thank you so much TZ; yes I did create it from scratch. Best advice. I found it works now. (and your answer solved another issue I was having - creating another custom fitting, but it only worked when I opened a fitting already made by revit, deleted all of it and created my custom part from there - even though everything was the same, some how making a custom part from new family -> Metric Generic Model -> and setting the family type does not work/is not reliable)
    I will always use your way now - create it from scratch - but not from the blank metric generic model - will open a already made family part from revit and delete it all and make it from scratch from there. Thanks again TZ!
    tzframpton likes this.
    January 17, 2011
    1,982
    07:33 AM
    Excellent glad it worked.
  1. Revit - MEP - Oval Flexible duct
    By Ivo021 in forum MEP - General
    Last Post: September 21st, 2015, 10:46 AM
  2. rectangular duct multiport conversion
    By AKDBrown in forum MEP - Family Creation
    Last Post: December 3rd, 2013, 02:12 PM
  3. Seeking RECTANGULAR DUCT ELBOW - Radius...But VERTICAL?
    By Spinalfarm in forum MEP - Family Creation
    Last Post: October 16th, 2013, 02:48 PM
  4. Rectangular Duct Elbow with two different widths possible?
    By tzframpton in forum MEP - General
    Last Post: July 16th, 2013, 08:40 PM
  5. Switch between which duct to connect to
    By domsib in forum MEP - General
    Last Post: March 21st, 2013, 10:31 PM
