Results 1 to 3 of 3
Like Tree1Likes
  • 1 Post By GMcDowellJr
Thread: Need your guidance.
    September 18, 2014
    9
    01:51 PM
    Smile Need your guidance.
    Hi All,
    I have a situation here. Project architect is asking to add additional information like Item Code(Bar Code serial no) and manufacturer to some of revit families in MEP and further he wants to tag them to suit his requirement. I am planning to add these as shared parameters under project parameters (just wanted to use this info for this project only). So I have created a new shared parameters text file with these two new entries and added them into the project and updated by choosing "overwrite the existing version" option. I have tested the tagging as well by adding this new info in the tag family. However, my question is this new shared parameters family file (with only two entries in it) would not overwrite the actual shared parameters file. If I'm not wrong there would be only one file (shared parameters) across the organisation.
    Please guide me as I am waiting for your your inputs/comments.
    Thanks.
    December 21, 2010
    Phoenix, AZ
    2,556
    07:51 PM
    You don't actually need a single file for the entire office. You can have an office file and a series of project files. The danger in this is duplicating parameters in each file. You don't want that.
    Once the shared parameters have been used the file itself is not needed until/unless you want to reference the parameter again. Even then you don't need the original file because you can export the SP from the family to a new/existing file. The family stores the GUID of the SP which is how Revit knows they're the same across files.
    Dave Jones likes this.
    September 18, 2014
    9
    01:51 PM
    Thanks for explaining in detail Greg.
  1. Guidance Requested: Using Generic Objects Only in Library
    By colokate in forum Architecture and General Revit Questions
    Last Post: February 10th, 2015, 06:19 AM
  2. Guidance Requested: Which Standard to Use: Masterfromat/Uniformat/OmniFormat??
    Last Post: February 17th, 2014, 04:06 PM
  3. Journal Language - Any guidance?
    By Barrie in forum Architecture and General Revit Questions
    Last Post: November 8th, 2013, 09:13 AM
  4. Guidance on First Project
    By domsib in forum MEP - General
    Last Post: November 21st, 2012, 01:17 PM
  5. Guidance on Families
    By domsib in forum MEP - Family Creation
    Last Post: November 12th, 2012, 02:55 PM
