Results 1 to 7 of 7
Thread: Taco Pump Family Broken?
    Senior Member
    June 14, 2011
    CT, USA
    567
    12:36 AM
    Downloaded this from SEEK and I am not seeing anything change when switching types. It's in 2013. I want to use it 2016. Tried it in 2014 with no difference.
    Is there an easy fix?
    Attached Files Attached Files
    March 3, 2016
    179
    05:36 AM
    Almost all parameters have the same values for each type, except e.g. Fixture Material. That is why you can't see any change. Names of types suggest they are essentially the same geometry with only minor differences.
    Senior Member
    June 14, 2011
    CT, USA
    567
    12:36 AM
    I saw that, too, but I didn't see the material changing.
    Someone else mentioned I might need a "catalog" file?
    March 3, 2016
    179
    05:36 AM
    If you have got a type catalog (it should be listed as a part of download on Seek) then you should load a family via ribbon and do not drag it into Revit via explorer.
    Senior Member
    June 14, 2011
    CT, USA
    567
    12:36 AM
    It doesn't seem to be available for this pump but other Taco pumps do have them.
    March 3, 2016
    179
    05:36 AM
    You can try to go to manufacturer's site, grab data for this pump and create your own catalog:
    -open a family, R>Export>Family Types., this will give you a starting point
    -open a txt file in Excel, type in values, save a file as txt and put it in the same catalog with your family
    Now you will be able to load a family using your type catalog.
    Senior Member
    June 14, 2011
    CT, USA
    567
    12:36 AM
    I wish I had the time to do that and learn a bit while doing it. I just whipped up a very basic family (two cylinders, two connectors, and a symbol) for the type I need until I can come up with something better.
    Thanks for the help.
  1. Family Editor changes 2012 - 2014. Constraint to nested family broken.
    By Duncan in forum Architecture - Family Creation
    Last Post: May 4th, 2017, 10:35 PM
  2. Help !!! Chilled water pump head calculation
    By duchien007 in forum MEP - General
    Last Post: October 31st, 2013, 03:40 PM
  3. 2014 ribbon broken?
    By Tim West in forum Architecture and General Revit Questions
    Last Post: August 9th, 2013, 03:59 AM
  4. Why is this Family broken?
    Last Post: November 8th, 2012, 05:56 PM
  5. Compressor (pump) not behaving.
    By Gabriel Black in forum MEP - General
    Last Post: March 8th, 2012, 12:39 PM
