Results 1 to 3 of 3
Thread: Couple of Family issues: Flexing Sweep Angle and Sizing in Project.
    December 18, 2012
    Atlanta, GA
    25
    03:02 PM
    I am creating a pipe elbow family.
    All seems to be going well with the parameters and lookup table until I try to change the angle. When I changed the FitAng value to 45, that's when I get the constraints not satisfied warning.
    Thoughts on that?
    The second issue is that when I put the elbow into a project as a 90 degree (the angle that works), it works fine as a draw pipe changing sizes and everything. However, when I select pipes and fittings, and then change sizes, I get a warning about an elbow not being present. ...then it changes as it should. (attached picture of the warning)
    Thanks!
    Attached Thumbnails Attached Thumbnails Couple of Family issues: Flexing Sweep Angle and Sizing in Project.-capture.png
    Attached Files Attached Files
    March 3, 2016
    179
    08:02 PM
    Quote Originally Posted by BarryMClark View Post
    Thoughts on that?
    Thanks!
    You can open a family from a default library and see how it works if you want to create it on your own.
    December 18, 2012
    Atlanta, GA
    25
    03:02 PM
    Quote Originally Posted by Artejon View Post
    That's what has gotten me as far as I have gotten. This one has be a bit stumped though.
  1. Building Coder: A Couple of Recent Issues
    Last Post: September 17th, 2014, 09:15 AM
  2. 2013: variable angle sweep trouble
    By jesse.walt in forum Architecture - Family Creation
    Last Post: June 11th, 2014, 06:42 PM
  3. Detail Item Not Flexing in Family
    By Revitista in forum Architecture - Family Creation
    Last Post: March 19th, 2014, 01:17 AM
  4. single parameter re-size sweep-blend based on locked angle constraints
    By aheintze in forum Architecture - Family Creation
    Last Post: August 1st, 2012, 03:07 PM
  5. Flexing Tag Family - Shape Handles
    By Alex Cunningham in forum Architecture - Family Creation
    Last Post: September 8th, 2011, 09:23 PM
