Results 1 to 3 of 3
Thread: Family showing on floors above
    Senior Member domsib's Avatar
    April 30, 2012
    586
    04:29 AM
    Anyone any idea why this family shows up on the level above when placed on a level.
    E.g Place family on Ground Floor wall @ 1350mm. It will show up on First Floor plans.
    Attached Files Attached Files
    May 3, 2012
    1,401
    06:29 AM
    Look for things like reference/model lines that extend too far above the family. Make them shorter or set to 'not a reference'
    jmk
    jmk is offline
    Forum Addict jmk's Avatar
    December 31, 2012
    NM, USA
    1,425
    10:29 PM
    Quote Originally Posted by josephpeel View Post
    This is the main culprit, and don't forget to check any nested families for the issue. I've had nested elements with reference lines 10' away from the component, which also made it awkward to select.
  1. Conc Walls & Floors. Showing mat'l incorrectly.
    By doni49 in forum Structure - General Questions
    Last Post: September 10th, 2015, 05:30 PM
  2. Same Family, different way of showing it
    By jean_francois_nant in forum Structure - General Questions
    Last Post: January 15th, 2014, 03:06 PM
  3. Floors Geometry Showing Through Walls
    By qutaibah in forum Architecture and General Revit Questions
    Last Post: July 30th, 2013, 11:35 AM
  4. Stuff showing up on multiple floors
    By tumbo in forum Architecture and General Revit Questions
    Last Post: October 17th, 2012, 04:50 PM
  5. Family not showing up
    Last Post: June 25th, 2011, 02:35 AM
