Results 1 to 2 of 2
Thread: Duct Fitting_Te​e Problem
    March 31, 2014
    63
    03:25 AM
    Hi All!
    When I am using tee like this:
    I often want to have a duct transition to smaller/bigger dimension on straight part of the tee, something like this:
    But I must do that always manually, or to be more precise attach duct transition to the straight part of the tee. When I start duct route from the straight part of the tee Revit doesn't make duct transition, Revit just reorganizes division inside tee, something like this:
    To conclude, how can I "lock" the tee division so I can only change the division between elbow and straight part? The division between straight part and elbow is only defined via the number (not formula) so it can easily be changed in design (because each tee is different), something like this:
    Best regards, Branimir
    May 3, 2012
    1,396
    04:25 AM
    Make a small duct from the T first, then add the transition. This makes everything a lot more stable and you can also use Justification if you want to make an eccentric transition.
  1. Piping/duc​t legend on sheet
    By brane1012 in forum MEP - General
    Last Post: April 23rd, 2016, 04:36 PM
  2. Duct accessorie​s Loss method
    By brane1012 in forum MEP - Family Creation
    Last Post: November 5th, 2014, 06:03 PM
  3. Problems contro11in​g visiblity graphics between discipline​s
    By cadmancan in forum Architecture and General Revit Questions
    Last Post: June 17th, 2013, 03:11 PM
  4. Replies: 1
    Last Post: June 27th, 2012, 06:33 AM
