Page 1 of 2 12 LastLast
Results 1 to 10 of 14
Like Tree1Likes
Thread: 2 head pole? 2 IES files?
    February 6, 2015
    84
    07:50 PM
    Hi everyone,
    We're trying to run some site lighting calculations for the first time using Revit and ElumTools, but from our search through manufacturer's websites, none seem to offer (proper BIM files to begin with) a fixture that can have 2-heads.
    Are there any that do? Moreover, how would they deal with the two heads photometrics? Is there someone out there that provides that but I haven't found them yet?
    Any help/advice/insight is appreciated.
    Thanks!
    10,183
    02:50 PM
    Make the heads a nested, Shared family, and put the IES file in them. Load them in to the pole family, then load in to project.
    December 21, 2010
    Phoenix, AZ
    2,599
    12:50 PM
    That will get you two heads (what's a head?) but, unless each has its own IES file it won't be correct. IES files are typically of an entire fixture and, in my experience, don't go nearly far enough (typically only one size, power, color, down/up in the same fixture blocked by geometry, etc.).
    10,183
    02:50 PM
    It'll be correct if the IES file is for each individual head, which seemed to be what the OP was asking about.
    December 21, 2010
    Phoenix, AZ
    2,599
    12:50 PM
    True that. How have you addressed the other issues with IES files? I ended up creating essentially nested light bulbs for the various color/power combinations. No small amount of work but a type catalog from Excel makes it manageable.
    February 6, 2015
    84
    07:50 PM
    That's what I ended up doing, though not my favorite approach since I can't change IES files on the fly through ElumTools while working on the project. But it seems like the only solution. Thanks.
    Quote Originally Posted by GMcDowellJr View Post
    That's an interesting approach to deal with multiple variations of the same/similar fixture type. How did you do that exactly? And I'm guessing the IES files would be found within those nested light bulbs?
    December 21, 2010
    Phoenix, AZ
    2,599
    12:50 PM
    No, manufacturers typically only make one IES file per fixture due to costs. Often they're 48" fixtures so if you have a 24" what do you do? If you have a 96" you can argue the use of 2 of the 48" and that will probably get you close enough for a photometric calc but not for a rendering. Light distrubution from a 96" fixture is different than a 48" fixture. I'm just using the built in parameters to contol power/color/etc. It generates about the right light but not necessarily the right distribution. I'm just as curious how others manage this as you.
    Senior Member Alex Page's Avatar
    December 13, 2010
    Wellington, New Zealand
    649
    07:50 AM
    Quote Originally Posted by mkisno4 View Post
    ... I can't change IES files on the fly through ElumTools while working on the project...
    Even is the nested family is Shared? (like Aaron recommended)
    June 23, 2016
    1
    07:50 PM
    I do not yet quite understand doctors explained to me is not it more understandable
    February 6, 2015
    84
    07:50 PM
    Quote Originally Posted by Alex Page View Post
    Sorry had to jump around on other projects.
    But by "shared" you mean this kind of thing: Revit OpEd: Connecting Parameters in Nested Families ?
  1. Section Head
    By robledojuan7 in forum Architecture and General Revit Questions
    Last Post: January 11th, 2016, 03:40 PM
  2. Group Multiple Pole Breakers on Schedule
    By dzatto in forum MEP - General
    Last Post: January 15th, 2015, 05:32 PM
  3. Electrical Fixture with double pole switches?
    By saviolam17 in forum MEP - General
    Last Post: August 14th, 2014, 03:25 AM
  4. Single pole - single phase panel schedule
    By jmlarias in forum MEP - General
    Last Post: March 13th, 2014, 06:48 PM
  5. Revit browser pole - i-Drop IE only?
    By Michi-Ken in forum Architecture and General Revit Questions
    Last Post: October 7th, 2013, 08:23 PM
