Results 1 to 2 of 2
Thread: Want Yes/No (Blocking Self Adjustement ) for VAV Box
    April 21, 2016
    2
    05:24 AM
    Post
    I have modified a VAV Box from Price Industries to size it self when only changing the Actual Supply Air Flow it works great. But I want to know if there was a way to block the auto sizing by Yes/No check box.
    Here is the VAV Box
    Attached Files Attached Files
    May 3, 2012
    1,396
    02:24 PM
    Nice, I also made something similar.
    I think you need to have the same parameters as Instance and Type, then use something like 'Instance Size = if(Autosize, Calculated Instance Size, Type Size)'
    So if Autosize is Yes, it will use the calculated instance size. If Autosize is No, it will revert to the Type settings.
  1. Holes in Default Counter Top blocking the sink
    By gpktm in forum Architecture - Family Creation
    Last Post: September 19th, 2013, 02:48 AM
  2. Furniture blocking Walls Line weight to show normally !!
    Last Post: December 21st, 2012, 08:48 AM
  3. Blocking Specific wall and door from showing except in one view !!
    Last Post: June 27th, 2012, 11:07 PM
  4. Room shading is blocking walls and doors
    By BrianHed in forum Architecture and General Revit Questions
    Last Post: August 3rd, 2011, 12:17 PM
Tags for this Thread
