Results 1 to 6 of 6
Like Tree3Likes
  • 3 Post By Artejon
Thread: Extrusions ending at walls
    April 14, 2016
    3
    11:57 PM
    I am currently editing a Fire alarm device family to show coverage areas per candela rating. I am doing this with an extrusion that shows as a hatch pattern in the model.
    An issue that i am trying to fix right now is having those extrusions ending at walls. Is there a way to have a the extrusion have a specific width and length unless it is running into a wall?
    I have attached the family for your reference.
    Any help would be appreciated, even if its a "this wont work".
    Zach
    Attached Files Attached Files
    March 3, 2016
    179
    04:57 AM
    If you want your family to automatically detect it's surrounding in a project and flex itself to fit then this is not possible with a family editor.
    You could try to achive it with Dynamo or global parameters in latest versions of Revit but that will require some work and I am not sure if you get it faster and easier than just dragging grips of coverage area manually but YMMV.
    April 14, 2016
    3
    11:57 PM
    Quote Originally Posted by Artejon View Post
    Thanks for replying,
    I will look into the dynamo and global parameters for this.
    Also for the grips, is there a way to put a maximum distance that they can extend to?
    March 3, 2016
    179
    04:57 AM
    You have to put a formula for a parameter to limit it's maximum value.
    jmk
    jmk is offline
    Forum Addict jmk's Avatar
    December 31, 2012
    NM, USA
    1,425
    09:57 PM
    Which will work to limit the extension, but I think once its controlled by a formula the grips disappear. You might be able to have a grip with no elements associated that can be stretched to infinity and then the formula controlled coverage area that has a formula that uses the user value if it is less than a certain value or the max value if the user value is greater.
    March 3, 2016
    179
    04:57 AM
    Quote Originally Posted by jmk View Post
    Yes, grips will dissapear but you can still drive geometry with grips :-), no need to input a value. See attached family.
  1. How to create a wall ending at an angle ?
    By Filip Koruznjak in forum Architecture and General Revit Questions
    Last Post: June 25th, 2015, 12:57 PM
  2. sweeps vs extrusions
    By dyepaintball45 in forum MEP - Family Creation
    Last Post: September 4th, 2014, 07:21 PM
  3. Wood Rafter ending ajustment
    By mona miller in forum Architecture and General Revit Questions
    Last Post: June 25th, 2014, 06:01 PM
  4. Revit TotD: Not so Perfect Ending…
    By Revit TotD in forum Blog Feeds
    Last Post: October 1st, 2013, 08:45 PM
  5. Beams Ending Short of Slanted Column Centerline - Help Please
    By Haymaker81 in forum Structure - General Questions
    Last Post: April 26th, 2011, 02:07 PM
