Results 1 to 4 of 4
Like Tree1Likes
  • 1 Post By cellophane
Thread: Length Parameter to Text
    September 16, 2015
    Darwin, Australia
    171
    06:00 AM
    Hi all,
    Simple question: Can two length parameters be combined into a text parameter?
    Example: Face Size (Text Param) = "Width (Length Param)" x "Depth (Length Param)"
    I've had a couple of attempts but keep returning inconsistent units. It doesn't seem reasonably possible, but I thought I'd ask the community. I could use Boolean expression, but I'd spend a year (at least) writing it.
    Any ideas?
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    6,164
    03:30 PM
    You can do it with some third party apps and probably Dynamo but I don't believe there is a way to do that OOTB.
    KiwiCodes Bonus Tools has a tool to copy parameters - to get the result you want you would need a parameter that does the math and your text parameter.
    AreaCalc = WxD
    AreaText = AreaCalc copied through API
    The only problem with this approach is that it isn't up to date unless you run the tool again.
    LukeEvans likes this.
    September 16, 2015
    Darwin, Australia
    171
    06:00 AM
    Cheers for that, I'll check out those tools and see how I go.
    November 12, 2015
    25
    03:30 PM
    You should be able to get by that error by cancelling the units yourself. For instance in your example you have ft*ft in your units and you want to have unitless text. Try =Length/1ft* Width/1ft.
    Sent from my Nexus 6 using Tapatalk
  1. General Annotation Family with Length Parameter using Grip?
    By doni49 in forum Architecture - Family Creation
    Last Post: October 27th, 2015, 01:27 PM
  2. Accessing the cut length parameter for tagging.
    By BoBMudd2 in forum Structure - General Questions
    Last Post: July 8th, 2015, 12:55 AM
  3. Duct Size vs Length parameter
    By brane1012 in forum MEP - Family Creation
    Last Post: November 26th, 2014, 05:58 PM
  4. Use Cut Length parameter in a formula???
    By JasonZischke in forum Structure - Family Creation
    Last Post: August 5th, 2013, 11:15 PM
  5. Text Length in Tags
    By Drew in forum Architecture - Family Creation
    Last Post: January 30th, 2012, 04:08 PM
