Results 1 to 6 of 6
Thread: System type
    October 28, 2014
    27
    02:49 PM
    System type
    Is someone who know how to change system type for air terminal? I need exhaust type. Another elements I've direct type instead of that one. Or woh can I add this one to system.
    Please help!
    January 17, 2011
    2,051
    08:49 AM
    Change the Connector in the Family to "Global" instead of a specific system type.
    February 8, 2016
    2
    05:49 PM
    Tannar is right. just edit the family and change the system classification to global so that it can adopt any system type. But if you want the exact system as you said, exhaust... select exhaust.
    September 16, 2015
    Darwin, Australia
    171
    12:19 AM
    Since the same terminals are often used for exhaust and return air, I find it best practice to just use global for everything. The only time I specify supply, exhaust, or return is on mechanical equipment.
    May 3, 2012
    1,403
    03:49 PM
    Well.. You still need to make separate Supply and Return/Exhaust air terminals.. So that the In and Out directions are correct.
    Member ThatBIMGuy's Avatar
    May 23, 2011
    Denver, CO
    461
    07:49 AM
    Both Tanner and Joseph are correct. Global parameter but separate families so the flow direction is correct. Once they are separate, you can create types based on your standard air terminals designations.
  1. Replies: 0
    Last Post: May 18th, 2015, 03:45 AM
  2. How to change system type of pipework
    By fifthtexas in forum MEP - General
    Last Post: November 13th, 2014, 03:58 PM
  3. System type becoming underfined
    By nick_h in forum MEP - General
    Last Post: February 3rd, 2014, 08:24 PM
  4. What system type
    Last Post: October 30th, 2013, 11:44 PM
  5. Turn off system type in view
    By domsib in forum MEP - General
    Last Post: May 23rd, 2013, 03:09 PM
