Results 1 to 3 of 3
Thread: Pipe Annotation Size for Wye fittings does not Correspond to the MEP Definition
    Member evan.dodds's Avatar
    December 29, 2014
    Calgary, Canada
    197
    09:45 PM
    Does anyone know why the wye fittings are huge when using the annotation scale and how to rectify it (while keeping the lines in the fitting)? My Annotation size is 3mm (which is what the tee is).
    Pipe Annotation Size for Wye fittings does not Correspond to the MEP Definition-pipe-fitting-annotation-size.png
    May 3, 2012
    1,401
    05:45 AM
    Annotations for fittings are in the fitting families themselves. So it depends how they have been made.
    Ideally the annotation lines in the fitting will have a parameter to control thier size.
    December 29, 2014
    Calgary, Canada
    197
    09:45 PM
    The wye fittings and the tee are both made the same (I think, they are the OOTB ones). If I take a tee (or cross) and make it have a 45° angle the symbol does get bigger but not nearly as big as the wye fittings. Most of the fittings I see, the annotation lines are controlled by the same parameters as the geometry.
  1. Size limitations to duct fittings
    By Mevald in forum MEP - General
    Last Post: November 11th, 2015, 06:36 AM
  2. Pipe fittings are not the right size........
    By rogpatt in forum MEP - General
    Last Post: October 14th, 2015, 04:27 PM
  3. Pipe fittings not shading
    By fifthtexas in forum MEP - General
    Last Post: August 17th, 2015, 09:37 AM
  4. Steel pipe and fittings
    By tzframpton in forum MEP - Family Creation
    Last Post: July 16th, 2014, 12:31 PM
  5. Pipe Fittings
    By MWatts12 in forum MEP - General
    Last Post: August 22nd, 2013, 03:31 PM
