Results 1 to 8 of 8
Like Tree5Likes
  • 2 Post By LukeEvans
  • 1 Post By LukeEvans
  • 2 Post By mbirm92
Thread: Duct Accessory Issue
    October 25, 2013
    New York, NY
    4
    11:42 PM
    I have an issue when creating a heating coil duct accessory with the part type set to breaks into. Whenever I place it on a duct it makes the duct sloped. I have been playing around with this for a few days and can't seem to figure it out. And when I create a new one from scratch I get the same issue. Was hoping someone could tell me what I'm doing wrong. I have attached the family for reference. Thanks!
    Attached Files Attached Files
    September 16, 2015
    Darwin, Australia
    171
    02:12 PM
    I had a quick look, and don't have time to go through this as extensively as I'd like to. But I did find that you have locked the bottom of the accessory to the X reference plane, this means that your offset of the accessory in the project is always going to differ from the offset of the duct run. I'd like to think this is what is causing your issue, but I cannot confirm it.
    Try to remake (again) the family, saving the geometry if possible, with the duct of the family centered on both the X and Y axis
    Good luck.
    mbirm92 and wgfletch like this.
    October 25, 2013
    New York, NY
    4
    11:42 PM
    Quote Originally Posted by LukeEvans View Post
    Good luck.
    This was exactly the issue. The center of the coil needed to be at the plane. Thank you for your help!
    September 16, 2015
    Darwin, Australia
    171
    02:12 PM
    Glad I could help you, anytime!
    May 12, 2014
    2
    03:42 AM
    Having the same problem. When you say 'at the plane' what do you mean exactly. Its driving me crackers that Im so close but yet so far....
    September 16, 2015
    Darwin, Australia
    171
    02:12 PM
    Hi Troy, I'll try to put this information a little simpler as it seems you may be new to family creation. Correct me if I'm wrong though!
    The guy above fixed this issue by centering the connector of his duct accessory on the horizontal reference plane. My terminology is off as I don't have Revit in front of me. But if you look at your family in a section/elevation view that is the plane that runs from left to right on your screen. You can set a equal dimension on to both your geometry and and that plane, this will keep the accessory centered on that plane.
    If that fails upload some pictures of your issue, or the family itself if you don't mind.
    troydyall likes this.
    October 25, 2013
    New York, NY
    4
    11:42 PM
    Quote Originally Posted by troydyall View Post
    You need the center of the coil to be at the center of the reference plane. Like in this image.Duct Accessory Issue-coil.png
    Hopefully this is helpful!
    LukeEvans and troydyall like this.
    May 12, 2014
    2
    03:42 AM
    Thanks gents, get it!!
    Now onto my next problem......
  1. Accessory - inserted into duct.
    By Gabriel Black in forum MEP - Family Creation
    Last Post: September 23rd, 2015, 06:25 AM
  2. Revit Duct sizing issue
    By kvusal in forum MEP - General
    Last Post: April 7th, 2015, 03:14 PM
  3. How to create a Duct Accessory for Round Duct?
    By BalajiBBI2205 in forum MEP - Family Creation
    Last Post: January 21st, 2015, 12:13 PM
  4. Duct Fitting Issue
    By brane1012 in forum MEP - Family Creation
    Last Post: March 31st, 2014, 10:19 AM
  5. Riser Duct Visibility Issue
    By Yogesh in forum MEP - General
    Last Post: July 23rd, 2011, 08:25 AM
