Results 1 to 4 of 4
Thread: System Seperators - Mechanical Equipment -vs- Pipe Accessory
    December 29, 2014
    Calgary, Canada
    187
    02:16 AM
    Is the pipe accessory category a reliable choice for this, or is mechanical equipment the way to go?
    May 3, 2012
    1,401
    10:16 AM
    You mean with two different connector types so you can connect, for example, heating supply with heating return?
    I would use a pipe accessory because it is easy to place it in a pipe (I made one that is a regulating valve). For air duct systems Mech Eq is probably better, a fan box or recirculation valve in an AHU for example.
    December 29, 2014
    Calgary, Canada
    187
    02:16 AM
    Yes I mean with two different connector types. But I was thinking more along the lines of connecting supply A to supply B, if that makes any difference.
    September 16, 2015
    Darwin, Australia
    171
    06:46 PM
    I think I know what you mean in terms of the relationship between systems. I'm assuming you're looking at something like pipework from two or more pumps returning to a common header or similar. In this case a motorized control valve (or regulating valve) wouldn't seem necessary. Perhaps just a regular old isolation valve or equivalent would do the trick, you could just modify the current valve family you'd use to separate the systems. I used a motorized valve to separate my supply and return systems on chilled water project recently and never had a second thought.
    I've not separated a supply network into 2 or more systems before so I could be completely off the mark. However the answer to your initial question was answered very well by Joseph: Ductwork = Mech. Eq. & Pipework = Pipe Acc.
  1. Mechanical Equipment Tag
    By aykhan9 in forum MEP - General
    Last Post: August 10th, 2015, 02:35 PM
  2. Constraining Array Length/Depth on Pipe Accessory
    By wgfletch in forum MEP - Family Creation
    Last Post: June 4th, 2015, 11:13 PM
  3. pipe system seperators
    By Darius in forum MEP - Family Creation
    Last Post: April 30th, 2015, 07:12 PM
  4. Brainstorming mechanical equipment with optional equipment?
    By tzframpton in forum MEP - Family Creation
    Last Post: July 30th, 2014, 03:58 PM
