Results 1 to 5 of 5
Thread: Trench Symbol Issue
    Member CRapai's Avatar
    April 30, 2015
    Michigan
    225
    11:49 PM
    Trench Symbol Issue
    I'm using a detail line in my trench family to represent it in plan. It is a rectangle that is 6 11/16" wide by 6' 9 1/4" long. However when I load it to the project it is consistently 6 1/16" wide. This measurement doesn't change if I change the families width to be 10 11/16" or 4". It always stays 6 1/16" wide. I thought maybe it wasn't actually showing up in the project and I was seeing something else, but if I delete the detail line and load it into the project the line disappears. I thought that maybe there is another line covering one side that is slightly off but I can't find anything in the family that would do that. Any suggestions?
    Member evan.dodds's Avatar
    December 29, 2014
    Calgary, Canada
    197
    09:49 PM
    Is your detail line constrained to the width?
    April 30, 2015
    Michigan
    225
    11:49 PM
    I have a parameter for the width that is set at 6 11/16"
    December 29, 2014
    Calgary, Canada
    197
    09:49 PM
    But is your detail line constrained/connected to the width in your family?
    April 30, 2015
    Michigan
    225
    11:49 PM
    Yes it is constrained to reference lines that have the parameter for width. When I change the parameter the detail line changes to match it.
  1. Adaptive Trench Drain
    By Elias in forum MEP - Family Creation
    Last Post: January 5th, 2016, 06:02 AM
  2. Trench Drain Simple Shape
    By CRapai in forum MEP - Family Creation
    Last Post: December 1st, 2015, 12:28 PM
  3. Elec fixt symbol / placement ht / feed value to plan symbol label?
    By Fritz in forum Architecture - Family Creation
    Last Post: November 1st, 2013, 03:53 PM
  4. Replies: 0
    Last Post: March 6th, 2013, 10:16 PM
  5. Trench Footings
    By kev4174 in forum Structure - General Questions
    Last Post: May 1st, 2012, 07:05 PM
