Results 1 to 7 of 7
Thread: Lindab LORU formula
    October 20, 2015
    14
    03:48 PM
    Question Lindab LORU formula
    Hello RVT Forum
    I have a question about these formula in Revit.
    I'm using Lindab's dataset and I'm currently drawing a LORU. I have to manually change the length of the LORU from 200mm to 450mm or 600mm depending on the duct size it is connected to.
    How can I create a formula which can change the length automatic?
    Duct size: 100 - 350 , then LORU length: 200mm.
    Duct size: 351 - 750 , then LORU length: 450mm.
    Duct size: 751 - , then LORU length: 600mm.
    Thank you.
    Christian
    September 16, 2015
    Darwin, Australia
    171
    12:18 AM
    This should do the trick:
    if(Duct Size<350,200,if(Duct Size<750,450,600))
    Put this formula in the formula column of your LORU length parameter.
    EDIT: Make sure that your LORU length and duct size parameters are set to 'Instance'.
    October 20, 2015
    14
    03:48 PM
    Hi LukeEvans
    Thank you for your respond.
    I tried your formula but it didnt work. Instead of "duct size" I have two paremeters: Lenght and Width.
    When one of lenght or width is greater than 350, the LORU lenght is 450mm.
    I have to merge these two parameters in the formula. Is it possible?
    Thank you,
    Christian
    Member evan.dodds's Avatar
    December 29, 2014
    Calgary, Canada
    218
    07:48 AM
    LORU = if(or(Width>750,Length>750),600,if(or(Width>350,Le ngth>350),450,200))
    October 20, 2015
    14
    03:48 PM
    Thank you! It worked.
    September 16, 2015
    Darwin, Australia
    171
    12:18 AM
    I've never used the 'or' operator in Revit, although I can think of a few situations (such as this one) that I could use it. Cheers Evan!
    October 20, 2015
    14
    03:48 PM
    If you find any other situations, feel free to share ;-).
    It is my first formula I'm working on and it is a very interesting part of Revit. Just like Dynamo is.
    Kind regards
    Christian
  1. Formula
    By adamheon in forum Architecture - Family Creation
    Last Post: October 9th, 2014, 03:32 AM
  2. Formula both yes or not
    By srwsl in forum Architecture and General Revit Questions
    Last Post: April 15th, 2014, 02:14 PM
  3. Lindab - Light gauge steel framing addins for RAC and RST
    By Hanky in forum Commercial & Free Add-Ins/Extensions
    Last Post: March 14th, 2012, 02:53 PM
  4. Schedule formula (is there a formula expert in the house?)
    By John McCamont in forum Architecture and General Revit Questions
    Last Post: September 9th, 2011, 09:50 PM
  5. Formula Help
    By Alex Cunningham in forum Architecture and General Revit Questions
    Last Post: March 30th, 2011, 10:27 PM
Tags for this Thread
