Results 1 to 4 of 4
Like Tree1Likes
  • 1 Post By josephpeel
Thread: how to swivel connections in Multibody part
    December 17, 2015
    11
    05:12 PM
    I posted the question at the other family group, but its more for MEP actually.
    In short, is there a way in a multisolid-import to change the angle of 2 solids via angles. These solids would be the inlet/outlet connections for chillers. Anything else in the geometry would stay the same.
    The idea is, if I swivel the connections, all the conditions would hang on the connection (flowrate etc).
    Or would I have to make one model per connection layout?
    Cheers,
    Steffen
    May 3, 2012
    1,396
    07:12 PM
    I did this with a nested family for connectors.
    Make a new family with a ref line that rotates around the origin in the horizontal plane.
    Then set the vertical plane of the first ref line to be the work plane and add another ref line that rotates vertically.
    On the second line make an extrusion for your connector/pipe.
    If you have the two angles and the diameter of the connector controlled by instance parameters, you can load this family into your main family and control everything by linking the parameters.
    Place your connector on the extrusion in the main family and it will move with the nested family when you change the angle.
    Ning Zhou likes this.
    December 17, 2015
    11
    05:12 PM
    thanks, I will try.
    Am new to Revit
    December 17, 2015
    11
    05:12 PM
    https://aectechtalk.wordpress.com/20...evit-families/
    does this mean, its actually 2 files?
  1. swivel connections in Family part
    By Steffen595 in forum Architecture - Family Creation
    Last Post: December 17th, 2015, 10:02 AM
  2. Here's Part 2 of my 10-part series on Creating Loadable Revit Families
    By MichaelLV in forum Architecture - Family Creation
    Last Post: December 15th, 2015, 03:21 AM
  3. Cranked connections
    By simon1688 in forum Structure - General Questions
    Last Post: November 15th, 2015, 12:39 PM
  4. Duct connections
    By fifthtexas in forum MEP - General
    Last Post: December 5th, 2014, 08:06 AM
  5. Connections Pipework
    Last Post: June 9th, 2014, 02:26 PM
