Results 1 to 3 of 3
Thread: Replacing my 90 deg Bends by 2 45 Deg. Bends
    December 10, 2015
    2
    06:11 AM
    Hi there
    I have a question, is it possible to ask revit to uses 2 bend 45 degree rather than a Bend 90 degree# As you know when I am trying to draw a pipe from let's say a Drain Fixture, I have to offset let's say -500 mm then if I go to let's say right for a 1000 mm
    I have created a L shape Piping segment# As you know again the Fittings that Revit Uses for this action is a 90 deg Bend But I rather it uses 2 Bends 45 deg#
    I know I should be able to do it by some how manipulating my Pipe Family and it's preferences, But I do not know how?
    Regards
    Bijankaraji
    December 10, 2015
    2
    06:11 AM
    I should add that I am doing sanitary Piping using Only 80 mm and 100 mm PVC Pipes.
    Is it possible that in my look up table of (Bend - PVC - Sch 40 – DWV) Table I delete all 90 deg and 60 deg Rows of info from my table? I tried it but I get a message that some thing is wrong about my Lookup formula. Any recommendation is greatly appreciated.
    Regards
    Bijankaraji
    May 3, 2012
    1,396
    04:11 AM
    Its not possible to get revit to place 2x 45 degree bends and a piece of pipe between, but it is possible to make a bend family that looks like that.
    So actually it is a single bend so far as revit is concerned, making it easy to move, trim etc. but then you can control the length of the pipe between the two bends with a parameter.
    If you only want to use specific angles, you can do that with the settings under Mechanical Settings -> Pipes -> Angles. Easier than modifying all your fittings.
  1. Replacing TB's across multiple project files.
    By BrianMyers in forum Architecture and General Revit Questions
    Last Post: July 22nd, 2015, 12:59 PM
  2. Replacing Shared Parameters globally
    By amoursol in forum Dynamo BIM
    Last Post: February 1st, 2015, 09:23 PM
  3. Ducts/Right Angle bends not playing nice
    By BLothian in forum MEP - General
    Last Post: November 3rd, 2014, 05:13 PM
  4. Replacing windows and doors
    By mdradvies in forum Tutorials, Tips & Tricks
    Last Post: May 28th, 2011, 10:47 AM
  5. Replacing Worksets as a visibility tool
    Last Post: March 21st, 2011, 01:12 AM
