Page 1 of 2 12 LastLast
Results 1 to 10 of 11
Thread: Families Overlapping
    November 10, 2015
    Mlebourne
    9
    11:30 PM
    I have created a new family for a piece of duct work and am having an issue with it overlapping with families it is aligned to.
    I have created the same piece as a co-worker but his works fine while mine is not showing properly and we cannot figure out why.
    The over lap only happens when hidden line is selected, not wireframe, the problem is when print in hidden line so I need to fix this somehow.
    September 16, 2015
    Darwin, Australia
    171
    02:30 PM
    The only time I have seen this issue is when two parts are not connected to each other via connectors. Gave me quite the headache on a large pipework project, once I ensured the parts were connected properly I had no visibility issues.
    I am not sure if this is your issue. Could you confirm if this is or is not the case?
    November 10, 2015
    Mlebourne
    9
    11:30 PM
    I have put duct connectors onto my duct and I still get the same issue.
    I have just inserted both my duct piece and my co-workers into a new project and now they are both overlapping.
    Is it possible this is a graphics setting in my project and now an issue with the family?
    September 16, 2015
    Darwin, Australia
    171
    02:30 PM
    Could you perhaps upload both versions of this family?
    January 17, 2011
    2,030
    11:00 PM
    I will back up LukeEvans on the issue - see the same thing all the time.
    However, in your example, these are duct transitions, correct? If so, then this is not a typical scenario at all, am I right?
    May 3, 2012
    1,401
    06:00 AM
    Are the two lines that are obscuring the other fitting drawn with a detail line inside the family?
    November 10, 2015
    Mlebourne
    9
    11:30 PM
    They are not drawn with detail lines. The overlaps are with a nested family.
    Here are both families.
    Transition is mine
    DUCT - Rec to Rec is my co workers.
    Attached Files Attached Files
    September 16, 2015
    Darwin, Australia
    171
    02:30 PM
    First of all these families are incredibly complicated, they have more formulas than Revit itself. So it makes diagnosing the issue infintely harder and I don't have the time at the moment. Once the families were in the project environment t I tried to replicate the image you posted in at the start of this thread.
    However, I did not have an issue with the overlap. Although there are no duct connectors on either fitting, is this intentional?
    November 10, 2015
    Mlebourne
    9
    11:30 PM
    My Transition file is an attempt as reducing the complications of my coworkers family.
    I'm still learning revit so i'm sure most of what I have done could have been done better.
    There are no duct connectors because the draftsmen in our office were complaining that some duct was dragging other ducts around when it was changed and they didn't want that, by taking away the connectors we solved that problem for them.
    September 16, 2015
    Darwin, Australia
    171
    02:30 PM
    Well you have certainly reduced the file size significantly, so well done. I've still got plenty to learn myself, so don't doubt yourself too much. Personally as a draftsman I don't like how adjusting a taper/offset/transition messes with my ductwork, however, I keep the connectors on.
    The way I deal with is to disconnect the taper/offset/transition before changing it's values. Tedious? Absolutely.
    But I couldn't sleep at night knowing my transition is as useless as a detail group. Just my thoughts though. Other than that I couldn't replicate the visibility issues you were having with those families, so I am assuming the problem is project specific.
  1. Link Overlapping into Message Content
    By doni49 in forum Forum Suggestions and Feedback
    Last Post: October 9th, 2015, 02:45 PM
  2. Overlapping Annotation - best practice
    By Lkenshalo in forum Architecture and General Revit Questions
    Last Post: July 23rd, 2014, 08:18 PM
  3. Overlapping wall layers
    By mona miller in forum Architecture and General Revit Questions
    Last Post: June 19th, 2014, 04:07 PM
  4. Overlapping Revisions
    By DaveP in forum Architecture and General Revit Questions
    Last Post: December 23rd, 2013, 09:50 PM
  5. Text overlapping
    By Astoria in forum Architecture and General Revit Questions
    Last Post: January 25th, 2012, 08:15 PM
