Results 1 to 6 of 6
Like Tree3Likes
  • 1 Post By Twiceroadsfool
  • 1 Post By tzframpton
  • 1 Post By josephpeel
Thread: Problems using ROUND() function with Duct Size parameter
    January 17, 2011
    2,052
    11:03 PM
    Question Problems using ROUND() function with Duct Size parameter
    Hello everyone! I've currently hit a wall. Here's the scenario:
    Mechanical HVAC equipment have duct opening sizes, and a lot of times the physical size of the opening is built to the 1/16" of accuracy. So for example you may have a supply duct discharge opening of 23-5/8"x16-3/16". Duct sizes are manufactured in 1/2" size increments, thus the need to try and use the ROUND() function to apply to the actual Duct Connector, rather than utilize the physical size opening. The smaller duct size is okay, it's an open flange that a sheet metal mechanic then "fits" in the opening with certain fasteners (clips, S & Drive, etc).
    I am getting nothing but Inconsistent Units no matter what I try. I've referenced the "Inconsistent Units" thread and for the last half hour I've tried everything, and even test examples in my Family but I am stuck. Is there any way at all to neutralize the units so the ROUND() function can be utilized? Below is an example of what I'm trying to accomplish. Now, I've tried all types of variations with the example, but nothing is working. Everything is "inconsistent units" in the end, no matter how many ways you break it a part. It seems I may need to find a way to convert the units from fractional inches to decimal and then back to fractional inches - is this easily achieved? Thanks in advance!
    -TZ
    Code:
    Parameter		| Value		| Formula
    RTU_SA Drop Height	| 47 7/8"	|
    RTU_SA Drop Width	| 102 1/2"	|
    DUCT_SA Drop Height	| 		| ROUNDDOWN(RTU_SA Drop Height)
    DUCT_SA Drop Width	| 		| ROUNDDOWN(RTU_SA Drop Width)
    RTU_* parameter Discipline/Type is HVAC/Duct Size
    DUCT_* parameter Discipline/Type is Common/Dimension or Common/Number (tried both, don't work)
    10,346
    11:03 PM
    Post Family?
    January 17, 2011
    2,052
    11:03 PM
    Here it is, without any ROUND() function parameters in place. You'll have to add to test.
    Attached Files Attached Files
    10,346
    11:03 PM
    Quote Originally Posted by tzframpton View Post
    Here you go. You can do it, but as you said, you need to remove the units (extra parameter), do the round, then put the units back (another parameter). I imagine you MIGHT be able to do it with a formula IN the rounddown, but i dont use Round that much, so im not sure. I would want it this way anyway, so the formulas are cleaner. Youll want to redo with Shared Parameters.
    tzframpton likes this.
    January 17, 2011
    2,052
    11:03 PM
    Well that was easy. I was one parameter away from getting this to work.
    Thanks again man!! As always, much much appreciated.
    -TZ
    Twiceroadsfool likes this.
    May 3, 2012
    1,403
    06:03 AM
    I always put in lots of ' /1 ' in formulas to eliminate the units and make everything numbers. Then multiply by the correct unit at the end of the formula. It does mean your formulas might be wrong if someone goes and changes the input units but it makes life easier.
  1. Circular Round Supply Differ & Round Duct
    By amoroso in forum MEP - General
    Last Post: September 18th, 2015, 12:26 PM
  2. How to create a Duct Accessory for Round Duct?
    By BalajiBBI2205 in forum MEP - Family Creation
    Last Post: January 21st, 2015, 12:13 PM
  3. Duct Size vs Length parameter
    By brane1012 in forum MEP - Family Creation
    Last Post: November 26th, 2014, 05:58 PM
  4. How to keep round duct flat on top - eccentric taper
    By nick_h in forum MEP - General
    Last Post: November 11th, 2013, 01:35 PM
  5. ROUND function - Inconsistant Units!
    By Barrie in forum Architecture - Family Creation
    Last Post: June 27th, 2013, 09:44 PM
