Results 1 to 8 of 8
Like Tree5Likes
  • 1 Post By hoangxuanhai
  • 2 Post By rjmrichard
  • 2 Post By josephpeel
Thread: Cable tray type
    October 28, 2012
    2
    07:00 PM
    Exclamation Cable tray type
    Hi everybody
    If i want to create cable tray type (for example cable tray LV and cable tray ELV). How do you load difference cable tray types in revit MEP 2016 ?
    Pls help me
    NijamKareem likes this.
    August 23, 2011
    3
    01:00 PM
    Cable Tray Types
    Duplicate a cable tray type and name it as the required system.
    Duplicate the cable tray fitting types and name those types as the required system.
    Edit the cable tray routing preference to use the new cable tray fitting types.
    See if the attached files help.
    Attached Thumbnails Attached Thumbnails Cable tray type-revit-cable-tray-types.png
    Attached Files Attached Files
    demdiin and NijamKareem like this.
    May 3, 2012
    1,396
    02:00 PM
    Or. You can use the same cable tray and fittings, but select the whole system and fill in the standard Service Type instance parameter.
    Then make filter for cable trays with Service Type="name of system" and add a colour overide.
    Ning Zhou and NijamKareem like this.
    October 28, 2012
    2
    07:00 PM
    Hi
    Thank you for your information
    May 21, 2013
    2
    05:30 PM
    I need this in rvt2013 version,can u pls...
    May 9, 2017
    5
    01:00 PM
    Hi rjmrichard ...... Thank you for this - it is a great help.
    I have used your method to create a tray called 'AC TRAY' - this is to model AC containment and display it within a Mechanical View.
    Can you please offer me some advice?
    I have the 'normal' Electrical Containment filtered on within the Mechanical View at halftone.
    When I filter off the Electrical Containment, the 'AC Tray' also turns off - despite me wanting to view this as a mechanical item.
    Can you please advise how I can achieve this?
    I thought is may be possible to put the Mechanical AC Tray (with is Electrical containment) on a Mechanical discipline somehow but I am not really having much luck.
    Any assistance that you can offer would be greatly appreciated.
    Thank you
    May 3, 2012
    1,396
    02:00 PM
    You need to do it the other way around.
    Have all cable trays on in your mechanical view, make a filter for "Type name does NOT contain AC", then set the visibility of that filter to off to hide everything except the AC trays.
    NOT filters are the most reliable way to filter stuff, even if new systems or types are added to the model.
    May 9, 2017
    5
    01:00 PM
    That's great - thank you very much!
  1. Cable Tray Clearance Space
    By CRapai in forum MEP - Family Creation
    Last Post: July 6th, 2017, 07:38 PM
  2. Cable tray fittings not shaded
    By fifthtexas in forum MEP - General
    Last Post: June 4th, 2015, 07:57 PM
  3. How To Draw Cable Tray
    By fifthtexas in forum Structure - General Questions
    Last Post: February 20th, 2015, 01:03 PM
  4. Filters for Cable Tray
    By JamesLawrence in forum MEP - General
    Last Post: May 24th, 2013, 12:46 PM
  5. Cable Tray and Plan Regions
    By ThatBIMGuy in forum MEP - General
    Last Post: April 9th, 2013, 10:38 PM
