Results 1 to 4 of 4
Thread: Label Visibility Hanger Tag
    October 13, 2015
    12
    11:37 AM
    I am creating a hanger tag and would like to control a label based on whether or not the parameter has a value. I would like to have two labels in one place and have one turn off if the parameter is null and the other one stay on. Is this even possible?
    November 2, 2015
    6
    10:37 AM
    The bad news is revit currently can't handle having a family drive visibility within a tag. The way to do this is have 2 types within the tag family and the users will need to select the correct one.
    October 13, 2015
    12
    11:37 AM
    Thanks for the reply. Guess two separate tags it will be.
    December 21, 2010
    Phoenix, AZ
    2,556
    09:37 AM
    You might be able to use a new formula in the family to determine the status of the parameters and use this in your tag instead. Not if its text but maybe otherwise.
  1. Duct Hanger doubt
    By Lauft in forum MEP - Family Creation
    Last Post: September 27th, 2015, 03:52 AM
  2. Hanger tag re-number
    By Brocha in forum MEP - General
    Last Post: August 18th, 2015, 08:18 PM
  3. Duct/pipe support and hanger REVIT2016
    By Lauft in forum MEP - General
    Last Post: August 6th, 2015, 05:44 AM
  4. Hanger Columns
    By kev4174 in forum Structure - General Questions
    Last Post: August 9th, 2013, 08:26 AM
  5. thewrz's super awesome hanger family
    By thewrz in forum MEP - Family Creation
    Last Post: February 10th, 2012, 05:58 PM
