Results 1 to 10 of 10
Like Tree2Likes
  • 1 Post By cellophane
  • 1 Post By laBaumba
Thread: Family Type Parameter Help
    August 11, 2015
    4
    10:59 PM
    So, I am attempting to build a condensing unit that will have 4 different length legs.
    I built the legs in individually families with each leg length as a type. Currently the unit is offset the same distance as the length of the legs; and they adjust in sync with each other as necessary. This is working by typing in the length you want.
    My issue is how do I restrict the leg height to only the types that I created? I do not necessarily want to be able to build say a 13” leg when all I need is a 6, 12, 24 and 36 inch leg length.
    I thought using a family type parameter would work, however the types are not changing in the project environment as many “you tube” videos suggested they would.
    The second part of this is if I am able to create the types using the family type parameter, how do I ensure the offset of the unit will match the length of the leg?
    I am trying to avoid using visibility parameters.
    Currently the two parameters I am working with are “H of leg” and “Leg Type<Generic Models>”
    Any thoughts or suggestions would be greatly appreciated.
    Attached is a 2016 model.
    Attached Files Attached Files
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    6,190
    12:59 AM
    To use Types the nested family needs to be shared.
    The other option is what will probably end up becoming a long formula: http://www.revitforum.org/tutorials-...day-usage.html
    if(LegLength<6",6",if(LegLength<12",12",if(LegLeng th<24",24", etc (I haven't tried that - you may need some Not or And statements.)
    Orlando, FL, USA
    3,141
    12:59 AM
    To use Types the nested family needs to be shared. ...
    No, is not necessary that the nested families are shared.
    Orlando, FL, USA
    3,141
    12:59 AM
    ...The other option is what will probably end up becoming a long formula:...
    Not necessary, either. Simply tie the instance Height parameter of the nested leg to a local type Height parameter. If the legs have different features, use a type parameter with a label to control the type of leg. Move the box up as per the same Height parameter. See illustration and attached sample family (2016 format).
    Attached Thumbnails Attached Thumbnails Family Type Parameter Help-2015-10-13_22-26-12.jpg
    August 11, 2015
    4
    10:59 PM
    Thanks
    Hey Thanks for the input, I will let you know how it works out.
    August 9, 2011
    Louisville, KY
    6,190
    12:59 AM
    fail on my part!
    I was using the formula to restrict the sizes available per the OP's question:
    Quote Originally Posted by laBaumba View Post
    That could be done by only have predefined types available but there isn't anything stopping someone from creating a leg that is 13" that way.
    tzframpton likes this.
    August 11, 2015
    4
    10:59 PM
    So, I have the predefined types. However, they are not appearing when chosen. I looked at Medina's family and am unsure how his is different than what I currently have. When using his family type parameter, the legs change shape. Mine are currently not different shapes, but they are different heights. However, when I change the type, nothing happens. So, I assume there is a disconnect somewhere, but not sure where... the hunt continues.
    May 6, 2014
    Dallas, Texas
    19
    11:59 PM
    Perhaps I'm misunderstanding the issue, but it seems that the types could simply be achieved by the following steps:
    -Draw reference plane at top-of-legs/bottom-of-unit.
    -Place dimension between Ref. Level and newly created reference plane.
    -Apply "H of leg" parameter to this dimension (make sure it's a type parameter).
    -Set leg extrusion equal to "H of leg" in Properties window.
    -Similarly, lock bottom of unit to reference plane.
    -Create four different family types: one for each "H of leg" value.
    Orlando, FL, USA
    3,141
    12:59 AM
    ...My issue is how do I restrict the leg height to only the types that I created? I do not necessarily want to be able to build say a 13” leg when all I need is a 6, 12, 24 and 36 inch leg length.
    Simply create the types. There is no need to "prevent people from creating a 13" type". Create four types, one for 6, one for 12, one for 24, and for 36. Use the family that I posted as example. Create types there, and see how everything works.
    August 11, 2015
    4
    10:59 PM
    Got It! Thanks for the ideas and the direction GIGI. There was a label not applied to the family in the properties window.
    Gigi likes this.
  1. shared family and <family type.....> parameter, when loaded error
    By Bross in forum Structure - Family Creation
    Last Post: November 25th, 2013, 11:56 AM
  2. Type Catalog to family parameter
    By alex60 in forum Architecture and General Revit Questions
    Last Post: June 11th, 2013, 02:48 PM
  3. select by parameter? curtain wall panels' materials by parameter, by type or family?
    By oompa_l in forum Architecture and General Revit Questions
    Last Post: January 24th, 2013, 02:20 PM
  4. Can you use a 'Family Tpe' parameter in a type catalogue?
    By brett05 in forum Architecture - Family Creation
    Last Post: September 6th, 2011, 06:45 AM
Tags for this Thread
