Results 1 to 7 of 7
Like Tree2Likes
  • 2 Post By Alfredo Medina
Thread: Need tutoring from an expert
    August 7, 2015
    USA
    11
    12:37 PM
    Question Need Quick Tip from an expert
    The file has 2 Wye, i created the top darker one. when the bottom Wye branching pipe is stretch the Radial point is the Insertion of the family.
    How can i mimic that on mine. My Radial point is not the insertion point, its the pipe connector. thus I can't turn my Wye into a Tee.
    Thanks.
    Attached Files Attached Files
    Last edited by RubberDinero; August 10th, 2015 at 04:46 PM. Reason: Shorter issue description
    Orlando, FL, USA
    3,096
    03:37 PM
    Please contact me. My email address is in my signature.
    August 7, 2015
    USA
    11
    12:37 PM
    Still accepting help with this issue. Thanks
    August 7, 2015
    USA
    11
    12:37 PM
    In a WebEx meeting with our BIM Lead, he explained how to make it radial in less then 5 seconds. I was so easy, it made me look so entry level. Which I am to Revit, but still. Thanks everyone for your interest.
    Orlando, FL, USA
    3,096
    03:37 PM
    Quote Originally Posted by RubberDinero View Post
    Glad to know that you found help. I'd like to say a couple of things about this thread:
    Since you started a thread for this question, it is a good etiquette of the forum to "close" a thread by sharing the solution, not only saying that a solution was found but without sharing the solution. Someone else might come to this thread later on, looking for a solution to the same issue.
    Also, I'd like to add a brief note explaining my post # 2 above. The original question of the thread was a more elaborated question, and it included a request for "tutoring", and I understood that as a request for private training on creating pipe fittings with look-up tables. After the original question was edited, my reply looked strange, and that's why I want to add this comment to clarify my post.
    iru69 and kubsix like this.
    Coeur d Alene, ID
    4,783
    12:37 PM
    Your BIM Lead should be your first POC for Revit issues before outside contact....As he/she may have a specific direction for project content vs outside help.
    August 7, 2015
    USA
    11
    12:37 PM
    Except I was trying to mimic a part, for my own understanding, that was already created. Not a whole lot of different directions you can have for a Tee/Wye.
  1. Replies: 0
    Last Post: April 29th, 2015, 07:45 PM
  2. Replies: 0
    Last Post: April 15th, 2015, 07:45 PM
  3. Replies: 0
    Last Post: April 15th, 2013, 05:45 AM
  4. teaching/tutoring Revit
    By afwelch87 in forum Tutorials, Tips & Tricks
    Last Post: February 11th, 2013, 01:32 AM
  5. Replies: 0
    Last Post: August 16th, 2012, 03:15 AM
Tags for this Thread
