Results 1 to 6 of 6
Thread: Adding Selectable Text to a Family
    March 20, 2013
    12
    11:07 PM
    I want to add a simple text to a family which is activated by a checkbox in the family properties. So, if I select the checkbox the letter or text appears by the equipment. Then I want to be able to move that text once the family is inserted into my floorplan to keep it visible. What is the best way to tackle this?
    Thanks!!
    Coeur d Alene, ID
    4,817
    10:07 PM
    This is why we have tags....
    You would have to use something like model text for it to appear....then it gets complicated about moving it depending on how you want it to move.
    Tags can be moved anywhere, and they have leaders...
    March 20, 2013
    12
    11:07 PM
    I thought about that, but how do you determine what tag is associated with that family?
    April 12, 2011
    Chicago, IL
    532
    12:07 AM
    Tags are based on the family category and you can have multiple tags for any given category. Under the annotation >tag menu you can assign which tag is the default for each category, but any of them can be changed after being placed. If you use the tag all tool you can select which tag is used at that time.
    March 20, 2013
    12
    11:07 PM
    I think I got it all figured out - the only thing that is left is how do I set that tag to have a transparent background so it isn't overriding the family? Thanks for your help...
    jmk
    jmk is offline
    Forum Addict jmk's Avatar
    December 31, 2012
    NM, USA
    1,457
    11:07 PM
    Edit the label type in the tag family and change the background (under graphics) to transparent.
  1. point cloud visible but not selectable
    By cbaze in forum Architecture and General Revit Questions
    Last Post: December 20th, 2013, 07:16 PM
  2. Adding a text in a family (how?)
    By gpktm in forum Architecture and General Revit Questions
    Last Post: November 22nd, 2013, 12:55 PM
  3. Adding Text to Families
    By MartinGT in forum Architecture and General Revit Questions
    Last Post: December 17th, 2011, 03:09 PM
  4. Making 'Revit Links' Un-snapable and Un-selectable?
    By Roberto in forum Architecture and General Revit Questions
    Last Post: October 25th, 2011, 04:54 PM
  5. Adding symbols to a text note
    By soboyle in forum Architecture and General Revit Questions
    Last Post: April 22nd, 2011, 06:31 PM
Tags for this Thread
