Results 1 to 4 of 4
Thread: placing a lighting connector to a lighting consultants light fixture family
    July 17, 2014
    1
    08:56 PM
    I am working on a project that has 2 different lighting consultants. My questions is I have placed lighting connectors into their lighting families in order to power the lighting circuits. The problem is in some of the lighting consultants lighting families my lighting connector gets lost or nested behind their symbol not letting me tab to select my connector to power the lighting circuit.
    Does anyone have a solution how to fix this??? so I can select my lighting connector.
    Thank you in advance for any assistance!!
    January 28, 2014
    55
    10:56 PM
    Why do you need to select the connector in order to circuit, or am i confused about the question? Click the fixture and select power from ribbon, select panel and then select the other fixtures you want connected to that circuit.
    December 31, 2015
    4
    04:56 AM
    Hello, I am a ligthing designer (quite new in the revit world), and I have some related questions:
    1) we would not like to insert the electrical connector in the lighting fixture; we are suggesting the electrical engineer to copy monitor with mapping the lighting fixture families; since we are not moving or re-defining the geometry of the lighting fixture, would this be the best practice?
    2) with the method on point 1), parameters such as voltage and power could be read from the shared parameters that have been already filled in the lighting fixture families: is that correct?
    3) neverthless, the electrical engineer asked to create shared instance parameters such as circuit number and switching type: will they be filled by the lighting designers or by the electrical? can the electrical engineer fill these parameters?
    Thank you in advance for the help!
    December 31, 2015
    4
    04:56 AM
    Hello, I am a lighting designer, quite new in the revit world, and I would ask some connectors related questions:
    1) we would not like to insert the connector in the lighting fixture families: we are suggesting the electrical engineer to copy monitor with mapping of the lighting fixtures families; since the light fixtures will not move or be re-defined in the geometry, would this be a best practice?
    2) given the method at point 1), informations such as voltage and power can be read by the electrical eingineer from the shared parameters that have been already filled in the lighting fixture families: is that correct?
    3) the electrical engineer asked us to add two shared instance parameters ( i.e. circuit number) to the lighting fixtures families: is the electrical engineer allowed to fill these fields (without touching the lighting fixtures families)? can these parameters be added in the correspondant lighting fixture families of the mapping?
  1. Lighting Fixture Default Placement
    By pierre7800 in forum Architecture and General Revit Questions
    Last Post: July 16th, 2019, 09:39 PM
  2. How to add a photometric web file parameter for new lighting fixture
    By veeranna.guggari13 in forum MEP - Family Creation
    Last Post: October 14th, 2016, 09:56 AM
  3. Lighting Family - Face Host, Adding multiple light sources, Best Practices
    By Orbik in forum Architecture - Family Creation
    Last Post: December 15th, 2015, 03:37 PM
  4. strip lighting fixture w/ linear light source
    By Ning Zhou in forum MEP - Family Creation
    Last Post: May 12th, 2012, 12:39 AM
  5. help with lighting fixture rendering
    By barry in forum Architecture and General Revit Questions
    Last Post: June 26th, 2011, 12:20 PM
