Results 1 to 3 of 3
Thread: Downloaded family not allowing parameters to be added
    April 11, 2014
    Rochester, New York
    25
    01:15 AM
    I'm trying to add another parameter to a family i downloaded. However, when i tried I got this message "invalid input for assembly code: please enter a valid assembly code". This is astronomically irritating. I got this family from a suppliers website, so is it possible they lock their family so nobody can make changes to it? If so, can i somehow "break" the invisible lock they placed on the family? This makes it very hard to use the family in the correct way and have what i want on the schedule. Any input will be appreciated.
    Senior Member
    August 19, 2011
    New Hampshire
    505
    01:15 AM
    Remove the value for the assembly code parameter that's in the family. It's likely not a code the program recognizes so it won't allow edits to the family parameters until the issue is fixed.
    Member ThatBIMGuy's Avatar
    May 23, 2011
    Denver, CO
    461
    11:15 PM
    I 2nd what Andrew said. Just remove the information in the value column for assembly code. If grayed out, remove it from the formula column, than the value column.
  1. Strange flexing behaviour on downloaded window family
    By BLothian in forum Architecture - Family Creation
    Last Post: March 13th, 2014, 04:58 PM
  2. Replies: 0
    Last Post: August 15th, 2013, 12:15 AM
  3. Can't edit downloaded family?
    By lukewallace1990 in forum Architecture - Family Creation
    Last Post: February 14th, 2013, 08:22 AM
  4. How to create views in a family you downloaded that only has the Ref. level view?
    Last Post: January 31st, 2013, 02:16 PM
  5. Precision is not allowing small details
    By tzframpton in forum Architecture and General Revit Questions
    Last Post: November 1st, 2012, 05:43 PM
Tags for this Thread
