Results 1 to 4 of 4
Thread: Isolating Valves
    Senior Member domsib's Avatar
    April 30, 2012
    586
    07:08 PM
    Isolating Valves
    Anyone got any Isolating Valve families they can share?
    It needs to go down to small sizes (15mm smallest connector).
    Thanks
    Member ThatBIMGuy's Avatar
    May 23, 2011
    Denver, CO
    461
    01:08 PM
    Quote Originally Posted by domsib View Post
    Thanks
    You can just use a ball valve or butterfly valve. They are classified as being isolation valves.
    April 30, 2012
    586
    07:08 PM
    The valves I require are smaller sized than the ootb revit ones. The standard ball valve in revit is 50mm & above. I need a valve with sizes around 15mm, 22mm, 28mm 35mm etc.
    May 23, 2011
    Denver, CO
    461
    01:08 PM
    We don't use anything that small. Have you tried editing the family to add those sizes?
  1. Replies: 0
    Last Post: November 28th, 2012, 11:49 AM
  2. isolating elements
    By Will P. in forum Architecture and General Revit Questions
    Last Post: July 6th, 2011, 05:49 PM
