Results 1 to 8 of 8
Like Tree1Likes
  • 1 Post By Matt Stachoni
Thread: What are the graphic cards that solve black screen render ?
    Senior Member ahmed_hassan's Avatar
    April 25, 2011
    Egypt
    752
    03:10 AM
    Hi, since i recognized that solving black screen show progress up to 50 %
    what are the graphics cards names for both laptop and desktop that solve the problem for revit 2013
    i do not want to buy a new laptop that get me trouble into the same problem.
    Please advise into grahic cards that is working perfect with revit 2013. !
    Cheers
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    6,164
    11:10 PM
    What do you have now? First thing I would do is update my drivers - that frequently will fix the issue. Depending on how new the card is they may be releasing drivers once a month if not more frequently.
    April 25, 2011
    Egypt
    752
    03:10 AM
    i want to buy laptop but i did not find it among recommended or certified on autodesk website
    i found similar names like
    AMD Radeon HD 6450M (certified recommended graphic card on autodesk website for revit 2013)
    and AMD Radeon™ HD 7670M Graphics (2GB dedicated memory) this what i found in store
    so can i buy a second one and it solves to me problem of black screen (just afraid to make a risk ??)
    April 25, 2011
    Egypt
    752
    03:10 AM
    Also i have this laptop options in my plan do you see it will solve the problem of this black screen :
    -Dell XPS 15z laptop
    -HP Pavilion DV6-7080ex
    -The New Inspiron 15R SE
    -The New Inspiron 15R SE The New Inspiron 15R
    -Toshiba Satellite P850-A839
    -Toshiba Satellite L850-A848
    Junior Member Matt Stachoni's Avatar
    December 11, 2010
    Newark, DE
    11
    11:10 PM
    Are you complaining about the prolonged black screen that appears when you hit the Render button, where the rendering doesn't start appearing for quite a while?
    That's normal. It's part of the Final Render calculation component of the mental ray rendering process. It's busy calculating the FG sample points spraying from the camera into the scene and bouncing around to determine the color at each pixel. Once that's done the bucket rendering process starts.
    Being that mental ray's implementation in Revit does not use the graphics card whatsoever, no graphics card will solve this "issue" - rendering in Revit is purely a CPU bound operation.
    iru69 likes this.
    "OMG I killed Revit"
    dzatto's Avatar
    December 9, 2010
    5,234
    10:10 PM
    I'm just asking this for my own information since I know nothing about how mental ray works. But, when there's a background image used (not just the default Revit sky) it's starts rendering the background image at about 10%. The rest starts at the normal 50%. Why is that?
    April 25, 2011
    Egypt
    752
    03:10 AM
    Quote Originally Posted by Matt Stachoni View Post
    Assuming you are right why this is not the same case in revit 2012 or earlier versions ?
    United States
    1,634
    08:10 PM
    Hi Ahmed - It seems like Matt answered your question. That's just the way rendering in 2013 appears to work. It's not clear what the "problem" is? When it's at 100%, it's no longer black, correct?
    If you don't want to wait a long time to see if a rendering is going to turn out well, I suggest testing it out with a very low "draft" setting and/or using the "Ray Trace" visual setting.
    At any rate, it doesn't appear to be a graphics card (or computer hardware) issue.
  1. Revit Hardware : Video Graphic Cards
    By iru69 in forum Hardware and Infrastructure
    Last Post: December 17th, 2018, 10:36 PM
  2. Revit 2013 - rendering within Revit - black screen first
    By willsud in forum Rendering and Gallery
    Last Post: August 18th, 2012, 12:05 AM
  3. Screen goes black!!!!
    By wjnaim in forum Architecture and General Revit Questions
    Last Post: September 19th, 2011, 02:54 PM
  4. Surface pattern goes black
    By Hirvio in forum Architecture and General Revit Questions
    Last Post: September 16th, 2011, 10:33 PM
  5. I don't know how to solve this
    By Yan Naing Bo in forum Structure - General Questions
    Last Post: September 7th, 2011, 06:11 AM
