Donate Now Goal amount for this year: 3000 USD, Received: 2477 USD (83%)
Page 48 of 52 FirstFirst ... 38444546474849505152 LastLast
Results 471 to 480 of 518
Like Tree32Likes
Thread: Revit Hardware : Video Graphic Cards
  1. #471
    Member rbcameron1's Avatar
    August 15, 2012
    USA
    191
    03:13 AM
    Pound for pound the 940MX is the budget way to go....for the latest low end chip. This tells me that at that point if an alternative is available like an 870m. "last years" higher end is usually cheaper and better than "this years" budget card.
    GeForce GTX 960M vs 940MX
    Total Performance:
    Tips for buying notebook with decent graphics (Summer 2016 edition)
  2. #472
    October 18, 2016
    4
    11:13 AM
    Hi to all,
    I have a workstation dual Xeon and I make rendering with Cpu (not Gpu).
    I use these software: Revit, Autocad, 3d Studio + vray plugin, Adobe Suite and suite for structural analysis.
    I need a graphic card because at this moment I use the integrated video card.
    Witch is a minimum card recommended? Quadro, Firepro, Gtx and witch model?
    Many thanks
  3. #473
    October 18, 2016
    7
    04:13 AM
    I have a Quadro M2000m, which isnt the same, but its WORLDS better than my older Quadro K2100m. The difference in Revit is perceptible.
    I have a new Dell 7510 with a Quadro M2000M and I can't get my render settings corrected. I've set the CUDA - GPU use to None, but each render is a fail. I'm running Revit 2016. Do you have any advice? Thanks!
  4. #474
    Senior Member Tim West's Avatar
    December 9, 2010
    Auckland, New Zealand
    575
    09:13 PM
    Quote Originally Posted by mblacklock View Post
    For starters, Revit doesn't use GPU to render. Can you create a new thread with your issue. Can I suggest explaining how rendering fails? Do you get a black image, does a dialog box pop up, etc.
  5. #475
    October 18, 2016
    7
    04:13 AM
    Quote Originally Posted by Tim West View Post
    I will, but I'm also having the same issue that Revit does not recognize my video card. Even after I installed the driver from Autodesk this morning, and my card is listed as a recommended video card. I do understand that Revit doesn't use GPU to render, that's why I set it to None on the video card.
  6. #476
    October 27, 2016
    1
    11:13 AM
    Hi Guys! first of all, sorry for not knowing (and using Revit) but a friend asked me what to do since I'm the computer expert. Hardwarewise I know my language, only choosing a GPU for Revit shows my lack in knowledge on the point.
    He wants a computer he can game on, but for his study it would be nice to be able to run Revit. Now my question is; what GPU do I have to take?
    I read everywhere that the Quadro's and Firepro's are to expensive, especially when the Revit usage is occasionaly, and since he just started I don't think it will be intense. here I see that GTX650's are able to run it? because that would mean that the new 1050 (Ti) would be able to do a decent job.
    that or an equivalent AMD card is the choice. does Revit support CUDA or just OpenGL/DirectX?
    furthermore; is 16GB of ram usefull for him? he will a Core i5 6500
  7. #477
    January 13, 2017
    1
    10:13 AM
    Hello everybody,
    This is my first post in the forum so I am not sure if this is the right place for this question.
    My problem is very close related with the stair handrails and I suspect that it also has a lot to do with my Video Graphic Card. Revit tells me that my Graphic card is not an official GPU but as far as I know there are 100's of GCards that are not official but that work very well with Revit.
    Let me give you some context information:
    - Operating System is Windows 7 Home Edition
    - Graphic Card: NVIDIA GeForce 7300 SE/7200 GS (Microsoft Corporation - WDDM)
    - Hardware Acceleration bothe checked and not checked
    The problem is that when I insert a handrail stair, if the hardware acceleration option is checked, I would say that aroung 60-70% of the times I insert a Handrail the weird error of the 3D and 2D Error images I insert here happens (it is like Revit were drawing some rays from some vanishing point)
    When I uncheck the accelerating hardware option, the frequency of this error happening reduces quite a bit, but it also happens from time to time. This weird rays are not recognized by Revit, It does not detect this rays, you cannot select them.
    So my question is obviously if anybody knows what could the problem/solution to this, if is a problem of the Graphic card or some configuration parameter etc. For me is something I cant understand, I dont know the exact pattern that produces the error, especially when the Hardware Acceleration option is unchecked but it whos up over and over again.
    Just in case, let me show the Hardware Accelaration option I am refereing to:
    Thank you very much in advance.
    Attached Thumbnails Attached Thumbnails Revit Hardware : Video Graphic Cards-stairshandrailerror3d.jpg   Revit Hardware : Video Graphic Cards-stairshandrailerror2d.jpg   Revit Hardware : Video Graphic Cards-hardwareaccelerationchecked.jpg   Revit Hardware : Video Graphic Cards-hardwareaccelerationnotchecked.jpg
  8. #478
    United States
    1,596
    02:13 AM
    Hi GonzaloPolo - welcome to RFO!
    You're pretty much doing everything you can, AFAIK. Keep the HWA off, and save often. Are you using the latest nvidia driver available for that card? If not, try a newer driver.
    The 7300 (7 series) is a decade old now, and is no longer supported with the latest drivers... newer versions of Revit have newer graphic systems that may require updated GPU drivers than what's available for the 7300. Maybe more likely is that those cards have a very limited amount of memory, so that could also be an issue with newer versions of Revit. So it's possible you're out of luck. Keep as few views open as possible, and turn off all the eye candy (turn off shadows, anti-aliasing, etc.)
    That being said, some specific issues with modeling may be related to the model itself, and the GPU is just a trigger, i.e. if you fixed something in the model, it might not crash (not saying that's the case, just saying it's a possibility)
    Best of luck!
  9. #479
    February 16, 2017
    1
    02:43 PM
    Hello iru69,
    My friend wants to buy a laptop which he can use to work on software like Revit, Lumina, other CAD like applications and for rendering (I'm no expert in these software). Do you think a gaming laptop such as MSI or ASUS ROG will be good for that? The hardware specifications of the models I suggested him are these:
    -> Intel i7 6th/7th gen quad core CPU
    -> 8 GB DDR4 RAM
    -> Nvidia GTX 950M/960M 2GB
    Thank you.
  10. #480
    April 13, 2012
    13
    03:13 AM
    I have used this forum for reference a lot over the years when making hardware decisions. The updated info about Intel's latest chips and video graphics prompted me to add my two cents.
    We recently purchased new W10 machines. We were able to get i7-7700k, M.2 storage, and 32GB RAM. For the kind of work with do (security and telecom), renderings and pretty 3D views are not very common. However, we do work on large models, with combined linked model file sizes easily over 2GB.
    Compared to our previous setup, Xeon E5-2620 v3, traditional HDD, same RAM, the difference is night and day. Using the RFO benchmark, the new setup is literally twice as fast.
    But all of that is a little off topic. We are still considering our options for GPU. I have been using the integrated graphics for several days with no noticeable difference in our day to day work. I have not had any issues with HWA on. So far we have only compared to a Quadro M2000 because we had one available. Using the RFO benchmark tool revealed a slight edge to the Quadro (81 vs 96, I can post results). I find that pretty remarkable.
    Lastly, I also tested a little with HWA on and off with the integrated graphics. This was in Revit 2017. If anything I would say performance was worse with HWA off. This was most noticeable rotating and working in 3D views. Again, keep in mind the type of work we primarily do.
    At this point I am considering just getting GTX 1050 Ti cards. They are inexpensive and don't require additional power like 1060 on up. This means they should work in our OEM Dell machine configuration/power supplies. I'd be interested to get opinions on that.
    Thanks.
    Sent from my Nexus 7 using Tapatalk
    iru69 likes this.
  1. Revit Hardware : CPU
    By iru69 in forum Hardware and Infrastructure
    Last Post: February 12th, 2018, 11:18 PM
  2. Revit Hardware : General
    Last Post: April 10th, 2015, 03:39 AM
  3. Revit Video Tutorials for beginners
    By JCM in forum Tutorials, Tips & Tricks
    Last Post: June 20th, 2011, 11:59 PM
  4. Revit 2012 assemblies - CADclips video
    By willsud in forum Tutorials, Tips & Tricks
    Last Post: May 4th, 2011, 11:08 PM
  5. Best graphic card for Revit 2011 for less than $250 ?
    By Munkholm in forum Hardware and Infrastructure
    Last Post: December 14th, 2010, 12:58 PM
