Results 1 to 4 of 4
Like Tree2Likes
  • 2 Post By iru69
Thread: Hosting Revit Central Files on a Mac OS Server
  1.    #1
    June 17, 2011
    20
    06:52 PM
    Hello all,
    I have a client that's transitioning from Vectorworks to Revit.
    Are there any issues with hosting Revit Central files on a macOS server? I know other people use NAS's which are also Unix variants
    Thanks in advance for the help!
    Rick
    btw, Mods
    I know there were database issues. I previewed this and got tossed out, but when I just Posted it, things worked fine.
    Also, I'm a supporting member and it doesn't show up on the info displayed.
  2.    #2
    Member mjajansen's Avatar
    December 25, 2011
    The Netherlands
    180
    06:52 PM
    I have no experience with MacOS but if the location isn't encrypted then you will have no problems using it for our central files.
  3.    #3
    Member BD Mackey's Avatar
    November 1, 2013
    468
    12:52 PM
    I have no experience either but have had a client make the exact same change. They had many issues with the macOS server and ended up getting a windows based version. I don't know if it was an issue with their IT not understanding how to make the connections but after putting a bunch of money attempting to make it work they realized it would have been cheaper in the long run to just get a windows server.
  4.    #4
    United States
    1,630
    11:52 AM
    Quote Originally Posted by rickbern View Post
    Hello all,
    Rick
    btw, Mods
    If you're using the Mac as a file server through an SMB connection, it should work fine. That being said, while I know it "works", I've never used it that way long-term, and don't know if there's anything "weird" that might pop up at some point. But we've been using Synology (linux-based) NAS's for many years, and never an issue there (linux via SMB) - it's the same concept.
    Re "supporting member" status, I don't believe RFO indicates that in the user profile. There was actually a bit of discussion about that when RFO was created - at least at the time, coming from AUGI, we were really intent on setting up the most egalitarian version of a support forums that we could. RFO has matured quite a bit since then, and maybe it would be a nice way to encourage donations. In any case, thank you for supporting RFO, and hopefully it's good enough for you to know that you did a good thing!
    Twiceroadsfool and FBlome like this.
  1. Building Coder: Accessing a Revit Server Central Model Path
    Last Post: August 11th, 2014, 02:45 PM
  2. Building Coder: Saving a New Central File to Revit Server
    Last Post: December 12th, 2013, 09:45 AM
  3. Revit Server - Replacing Central File
    By jasonbailly in forum Worksharing, Revit Server & C4R
    Last Post: August 1st, 2011, 09:54 PM
  4. Revit Server - Replacing a Central Server
    Last Post: May 28th, 2011, 02:39 PM
  5. Revit Server - how many central servers can a local server serve?
    By kingjosiah in forum Worksharing, Revit Server & C4R
    Last Post: March 8th, 2011, 04:12 PM
