Page 1 of 8 12345 ... LastLast
Results 1 to 10 of 80
Like Tree11Likes
Thread: RFO Benchmark v3.2 2019 results
    Rotterdam, South Holland
    3,039
    04:12 PM
    Please post your RFOBenchmark V3.2 results for the 2019 products here.
    Comments and suggestions should be made in the RFOBenchmark v3.X thread. The download is there too.
    Note: To condense your results, click Go Advanced, highlight the results, then click the code button (the one with a #).
    Thanks!
    Gordon
    3,039
    04:12 PM
    Code:
    RVT 2019 - Full_Simplified set - 2018.04.28 @ 13.46.01 on PX-0.txt
        RFO Benchmark v3.2 (build 28.04.2018)
        RevitForum.org
    All times are in seconds, lower is better.
    Run on Revit 2019 FCS
    _________________________________________________________________
    Model creation benchmark
        4.04   opening and loading the custom template
       14.01   creating the floors levels and grids
       23.59   creating a group of walls and doors
       39.39   modifying the group by adding a curtain wall
       15.50   creating the exterior curtain wall
       11.00   creating the sections
        4.60   changing the curtain wall panel type
       16.94   creating area plans
        2.22   creating and applying view template
      131.29   TOTAL
    Graphics
        5.76   activate View Styles view
        2.42   change view to Wireframe
        0.12   change view to Hidden
        1.19   change view to Shaded
        1.20   change view to Consistent Colors
        1.19   change view to Realistic
        1.30   refresh Wireframe Line view x10
       11.43   refresh Hidden Line view x10
       11.81   refresh Shaded view x10
       11.72   refresh Consistent Colors view x10
       13.06   refresh Realistic view x10
        1.23   activate View Cube view
       14.98   rotate view x1
       77.41   TOTAL
    Notes:
        Graphics benchmark measures the entire graphics stack, which includes CPU and memory.
        To meaningfully compare graphics cards, test all cards in the same machine
        and use the 'Graphics - expanded' benchmark.
    TEST CONDITIONS:
    Mfr: Apple Inc.
    Model: MacBookPro11,3
    OS: Microsoft Windows 10 Pro64-bit
    CPU: Intel(R) Core(TM) i7-4870HQ CPU @ 2.50GHz
    Max Clock Speed: 2.501Ghz
    Number of Processors: 4
    Number of Logical Processors: 8
    Total Physical Memory: 16GB @ 1600 1600Mhz
    Drive Type: Removable Disk (exFAT)
    Drive Model: TOSHIBA TransMemory USB Device
    Graphics Card: NVIDIA GeForce GT 750M
    Graphics RAM: 2GB
    Driver version: 10.18.13.5324
    Screen Resolution: 2880x1800x32bit @ 59Hz
    DPI Scaling: 100%
    Twiceroadsfool likes this.
    Member remiscs's Avatar
    May 18, 2015
    Las Vegas, NV
    227
    08:12 AM
    Here are my results with a Ryzen 1800x stock vs 4050mhz OC (both runs at 3200mhz RAM). Considering that the new Ryzen refresh outperforms the 1800x, the 2700x would make for a nice Revit machine.
    4050mhz Overclock (OC)
    Code:
    RVT 2019 - Full_Simplified set - 2018.05.02 @ 00.11.21 on DESKTOP-FAS01DM.txt    RFO Benchmark v3.2 (build 01.05.2018)
        RevitForum.org
        5.84   opening and loading the custom template
       12.67   creating the floors levels and grids
       21.72   creating a group of walls and doors
       38.67   modifying the group by adding a curtain wall
       14.26   creating the exterior curtain wall
        9.65   creating the sections
        4.36   changing the curtain wall panel type
       14.41   creating area plans
        1.95   creating and applying view template
      123.53   TOTAL
    Graphics
        4.72   activate View Styles view
        1.46   change view to Wireframe
        0.11   change view to Hidden
        0.51   change view to Shaded
        0.55   change view to Consistent Colors
        0.52   change view to Realistic
        1.09   refresh Wireframe Line view x10
        5.30   refresh Hidden Line view x10
        5.62   refresh Shaded view x10
        5.31   refresh Consistent Colors view x10
        6.43   refresh Realistic view x10
        0.59   activate View Cube view
        4.61   rotate view x1
       36.82   TOTAL
    Notes:
    TEST CONDITIONS:
    Mfr: Gigabyte Technology Co., Ltd.
    Model: AX370-Gaming K7
    CPU: AMD Ryzen 7 1800X Eight-Core Processor
    Max Clock Speed: 4.05Ghz
    Number of Processors: 8
    Number of Logical Processors: 16
    Total Physical Memory: 32GB @ 3200 3200 3200 3200Mhz
    Drive Type: local Disk (NTFS)
    Drive Model: Force MP500
    Graphics Card: AMD FirePro W8000
    Graphics RAM: 3.9990234375GB
    Driver version: 23.20.15007.1005
    Screen Resolution: 3840x2160x32bit @ 60Hz
    DPI Scaling: 150%
    Stock w/3200mhz XMP enabled on RAM
    Code:
    RVT 2019 - Full_Simplified set - 2018.05.02 @ 00.24.00 on DESKTOP-FAS01DM.txt    RFO Benchmark v3.2 (build 01.05.2018)
        RevitForum.org
        6.13   opening and loading the custom template
       13.60   creating the floors levels and grids
       23.93   creating a group of walls and doors
       42.73   modifying the group by adding a curtain wall
       15.54   creating the exterior curtain wall
       10.65   creating the sections
        4.84   changing the curtain wall panel type
       15.01   creating area plans
        2.03   creating and applying view template
      134.46   TOTAL
    Graphics
        5.08   activate View Styles view
        1.59   change view to Wireframe
        0.56   change view to Shaded
        0.60   change view to Consistent Colors
        0.57   change view to Realistic
        1.18   refresh Wireframe Line view x10
        5.81   refresh Hidden Line view x10
        6.17   refresh Shaded view x10
        5.81   refresh Consistent Colors view x10
        7.08   refresh Realistic view x10
        0.65   activate View Cube view
        4.98   rotate view x1
       40.20   TOTAL
    Notes:
    TEST CONDITIONS:
    Max Clock Speed: 3.6Ghz
    DPI Scaling: 150%
    Forum Addict Robin Deurloo's Avatar
    July 7, 2011
    Rotterdam, Holland
    1,082
    04:12 PM
    The results for my laptop
    Code:
    RVT 2019 - Full_Simplified set - 2018.05.02 @ 09.40.29 on LAPTOP-DEURLOOB.txt
        RevitForum.org
        6.66   opening and loading the custom template
       14.91   creating the floors levels and grids
       25.59   creating a group of walls and doors
       42.17   modifying the group by adding a curtain wall
       14.10   creating the exterior curtain wall
       11.55   creating the sections
        4.66   changing the curtain wall panel type
       16.60   creating area plans
        2.09   creating and applying view template
      138.33   TOTAL
    Graphics
        5.11   activate View Styles view
        1.56   change view to Wireframe
        0.45   change view to Shaded
        0.48   change view to Consistent Colors
        0.47   change view to Realistic
        1.25   refresh Wireframe Line view x10
        4.85   refresh Hidden Line view x10
        5.05   refresh Shaded view x10
        4.78   refresh Consistent Colors view x10
        6.28   refresh Realistic view x10
        0.54   activate View Cube view
        3.73   rotate view x1
       34.67   TOTAL
    Notes:
    TEST CONDITIONS:
    Mfr: HP
    Model: HP Pavilion Power Laptop 15-cb0xx
    OS: Microsoft Windows 10 Home64-bit
    CPU: Intel(R) Core(TM) i7-7700HQ CPU @ 2.80GHz
    Max Clock Speed: 2.808Ghz
    Total Physical Memory: 16GB @ 2400 2400Mhz
    Drive Model: KXG50ZNV256G TOSHIBA
    Graphics Card: NVIDIA GeForce GTX 1050
    Graphics RAM: 2GB
    Driver version: 23.21.13.8873
    Graphics Card: Intel(R) HD Graphics 630
    Graphics RAM: 1GB
    Driver version: 22.20.16.4815
    Screen Resolution: 1920 1920x1080 1080x32bit @ 60 60Hz
    DPI Scaling: 125%
    Kingdom of Denmark
    4,203
    04:12 PM
    Code:
    RVT 2019 - Full_Simplified set - 2018.05.02 @ 13.30.05 on KM-D20-2.txt
        RevitForum.org
        4.51   opening and loading the custom template
       15.94   creating the floors levels and grids
       32.96   creating a group of walls and doors
       62.61   modifying the group by adding a curtain wall
       19.66   creating the exterior curtain wall
       14.21   creating the sections
        6.66   changing the curtain wall panel type
       20.32   creating area plans
        2.87   creating and applying view template
      179.74   TOTAL
    Graphics
        6.08   activate View Styles view
        2.24   change view to Wireframe
        0.18   change view to Hidden
        0.77   change view to Shaded
        0.86   change view to Consistent Colors
        0.78   change view to Realistic
        1.83   refresh Wireframe Line view x10
        7.96   refresh Hidden Line view x10
        8.59   refresh Shaded view x10
        7.97   refresh Consistent Colors view x10
        9.93   refresh Realistic view x10
        0.90   activate View Cube view
        5.13   rotate view x1
       53.22   TOTAL
    Notes:
    TEST CONDITIONS:
    Mfr: LENOVO
    Model: 4158GV3
    CPU: Intel(R) Xeon(R) CPU           X5690  @ 3.47GHz
    Max Clock Speed: 3.459Ghz
    Number of Processors: 6
    Number of Logical Processors: 12
    Total Physical Memory: 32GB @ 1333 1333 1333 1333Mhz
    Drive Model: Samsung SSD 840 Series
    Graphics Card: NVIDIA GeForce GTX 1080 Ti
    Driver version: 24.21.13.9731
    Screen Resolution: 1920x1200x32bit @ 59Hz
    DPI Scaling: 100%
    July 7, 2011
    Rotterdam, Holland
    1,082
    04:12 PM
    Interesting Klaus that your results are a lot slower then mine and you are running a much faster workstation then my laptop.
    Noticed in the 2018 test that updated drivers can help a lot with some of the results.
    3,039
    04:12 PM
    Quote Originally Posted by Robin Deurloo View Post
    Definitely! The impact of graphics drivers is showing, given how little the GPU is actually working. I would bet really old CPU "drivers" could have an impact too. In general, I think a fully updated machine is always fastest, with the one exception being the first few versions of a new major release of the GPU drivers. Then sometimes the last version of the last major release is fastest.
    May 18, 2015
    Las Vegas, NV
    227
    08:12 AM
    Quote Originally Posted by Gordon Price View Post
    I have to agree as my older Firepro W8000 (basically a Radeon 7950) is still faster at 4K resolution....not sure if I missed anything. I also had two 1050x1680 (portrait) monitors connected too.
    Coeur d Alene, ID
    4,632
    08:12 AM
    Wow....terrible....ha ha. Only went through 6 or so Journal Errors and took almost 3 days.
    Code:
    RVT 2019 - Full_Expanded set - 2018.04.30 @ 16.51.54 on WAG13.txt
        RFO Benchmark v3.2 (build 29.04.2018)
        RevitForum.org
    Update
       10.71   update previous version file
        4.42   opening and loading the custom template
        0.07   saving the new project
       23.39   loading and arraying link
       36.51   setting links to halftone
        1.20   saving the project with links
       61.93   creating the floors levels and grids
       34.25   creating a group of walls and doors
       59.45   modifying the group by adding a curtain wall
      116.50   creating the exterior curtain wall
       45.07   creating the sections
       28.19   changing the curtain wall panel type
       34.76   creating area plans
        4.52   creating and applying view template
        2.03   saving the project with completed model
      452.29   TOTAL
    Export benchmark
     1432.02   export all views as PNGs at 300 dpi
      945.02   export all views as DWFs
     3341.59   export all views as DWGs
     4041.15   print all views as vector *
        0.00   print all views as raster *
    Notes:
     *  Print Views tests require the 'Microsoft XPS Document Writer' printer be installed.
    Render benchmark
      133.40   render
    Graphics - Activate first view
       56.53   activate View Styles view
    Graphics - Change view visual style from a common start
       32.82   common start: from Hidden Line to Wireframe
       38.52   common start: from Hidden Line to Shaded
       37.74   common start: from Hidden Line to Consistent Colors
       42.33   common start: from Hidden Line to Realistic
       13.21   common start: from Consistent Colors to Wireframe
       37.11   common start: from Consistent Colors to Hidden Line
       39.17   common start: from Consistent Colors to Shaded
       41.10   common start: from Consistent Colors to Realistic
      282.00   TOTAL
    Graphics - Change view visual style from a common end
       37.13   common end: from Wireframe to Hidden Line
       38.39   common end: from Shaded to Hidden Line
       37.99   common end: from Consistent Colors to Hidden Line
       37.33   common end: from Realistic to Hidden Line
       37.21   common end: from Wireframe to Consistent Colors
       38.18   common end: from Hidden Line to Consistent Colors
       38.49   common end: from Shaded to Consistent Colors
       37.85   common end: from Realistic to Consistent Colors
      302.57   TOTAL
    Graphics - Change view visual style in sequence
       13.21   in sequence: from Realistic to Wireframe
       37.48   in sequence: from Wireframe to Hidden Line
       38.29   in sequence: from Hidden Line to Shaded
       36.81   in sequence: from Shaded to Consistent Colors
       40.38   in sequence: from Consistent Colors to Realistic
       36.72   in sequence: from Realistic to Consistent Colors
       38.24   in sequence: from Consistent Colors to Shaded
       37.23   in sequence: from Shaded to Hidden Line
       13.17   in sequence: from Hidden Line to Wireframe
      291.53   TOTAL
    Graphics - Refresh views
       77.17   refresh Wireframe view x10
      168.22   refresh Hidden Line view x10
      176.91   refresh Shaded view x10
      171.71   refresh Consistent Colors view x10
      177.07   refresh Realistic view x10
      771.08   TOTAL
    Graphics - Rotate views
       19.74   activate View Cube view
       98.44   rotate view x1
        6.82   activate View Cube - Sketchy view
      116.66   rotate sketchy view x1
      241.66   TOTAL
    Notes:
        To meaningfully compare graphics cards, test all cards in the same machine.
    TEST CONDITIONS:
    Mfr: System manufacturer
    Model: System Product Name
    CPU: Intel(R) Core(TM) i7-3820 CPU @ 3.60GHz
    Max Clock Speed: 3.601Ghz
    Total Physical Memory: 16GB @ 1600 1600 1600 1600Mhz
    Drive Model: Samsung SSD 850 EVO 1TB
    Driver version: 23.21.13.8813
    Screen Resolution: 1920x1080x32bit @ 60Hz
    DPI Scaling: 100%
    RAW DATA:
       11.246>   10.6210   10.9020   10.6210   10.500<   update previous version file
        4.4140    4.3830    4.562>    4.4650    4.328<   opening and loading the custom template
        0.0660    0.0660    0.074>    0.051<    0.0620   saving the new project
       23.1170   23.8560   23.871>   23.051<   23.2110   loading and arraying link
       36.1720   37.2890   38.172>   35.805<   36.0660   setting links to halftone
        1.1950    1.207>    1.2070    1.188<    1.1990   saving the project with links
       61.332<   64.394>   62.7500   61.3520   61.6800   creating the floors levels and grids
       33.8160   34.9020   36.496>   34.0230   33.746<   creating a group of walls and doors
       59.0390   60.3560   62.223>   58.9530   58.856<   modifying the group by adding a curtain wall
      115.9730  118.1060  124.344>  114.836<  115.4180   creating the exterior curtain wall
       44.5470   45.9220   47.793>   44.293<   44.7460   creating the sections
       27.7110   29.4140   29.641>   27.441<   27.4570   changing the curtain wall panel type
       34.7380   34.8830   37.961>   34.418<   34.6520   creating area plans
        4.5510    4.5350    4.938>    4.477<    4.4770   creating and applying view template
        2.0040    2.0390    2.305>    1.996<    2.0470   saving the project with completed model
     1420.3550 1434.6560 1470.828> 1417.344< 1441.0550   export all views as PNGs at 300 dpi
      973.6800  917.9800  987.953>  890.195<  943.3870   export all views as DWFs
     3314.2190 3364.7660 3403.867> 3293.863< 3345.7970   export all views as DWGs
     4020.6560 2728.031< 4335.48> 4010.9920 4091.7890   print all views as vector
      130.695<  136.867>  130.9840  134.0060  135.1990   render
       54.879<   56.2730   55.9140   57.4000   58.129>   activate View Styles view
       32.9410   32.8360   32.6680   33.340>   32.367<   common start: from Hidden Line to Wireframe
       37.797<   38.5270   39.0510   37.9710   40.598>   common start: from Hidden Line to Shaded
       36.402<   37.7190   37.1130   38.3870   39.375>   common start: from Hidden Line to Consistent Colors
       40.422<   41.8980   41.3160   43.7700   44.266>   common start: from Hidden Line to Realistic
       12.9800   13.1060   12.977<   13.5590   13.578>   common start: from Consistent Colors to Wireframe
       36.070<   37.3480   36.5940   37.3790   38.644>   common start: from Consistent Colors to Hidden Line
       37.457<   38.8980   38.0980   40.549>   40.5080   common start: from Consistent Colors to Shaded
       39.406<   40.7540   40.1210   42.4220   42.644>   common start: from Consistent Colors to Realistic
       35.703<   37.0510   37.2930   37.816>   37.0550   common end: from Wireframe to Hidden Line
       36.043<   37.3120   39.0040   38.8480   39.777>   common end: from Shaded to Hidden Line
       36.144<   37.1950   38.0550   38.7090   39.809>   common end: from Consistent Colors to Hidden Line
       35.918<   37.4380   36.5350   38.0230   39.606>   common end: from Realistic to Hidden Line
       35.996<   37.6130   36.0900   37.9220   39.641>   common end: from Wireframe to Consistent Colors
       36.617<   40.387>   36.9530   37.5820   40.0000   common end: from Hidden Line to Consistent Colors
       36.4570   40.398>   36.223<   38.9730   40.0470   common end: from Shaded to Consistent Colors
       36.2810   40.793>   36.051<   37.5780   39.6760   common end: from Realistic to Consistent Colors
       12.8120   13.832>   12.543<   13.6370   13.1840   in sequence: from Realistic to Wireframe
       35.6950   39.418>   35.445<   38.1130   38.6250   in sequence: from Wireframe to Hidden Line
       37.4020   39.1130   37.219<   38.3440   39.496>   in sequence: from Hidden Line to Shaded
       36.4880   39.672>   36.211<   36.8940   37.0350   in sequence: from Shaded to Consistent Colors
       39.336<   44.133>   39.3560   39.6250   42.1480   in sequence: from Consistent Colors to Realistic
       36.3910   39.012>   36.078<   36.5230   37.2540   in sequence: from Realistic to Consistent Colors
       37.4180   38.8120   37.156<   38.4960   39.051>   in sequence: from Consistent Colors to Shaded
       36.0740   40.480>   35.883<   36.8910   38.7270   in sequence: from Shaded to Hidden Line
       12.9650   13.75>   12.703<   13.2270   13.3090   in sequence: from Hidden Line to Wireframe
       77.9260   78.863>   76.488<   76.9220   76.6760   refresh Wireframe view x10
      168.0120  171.781>  163.543<  168.4610  168.1990   refresh Hidden Line view x10
      175.8160  182.234>  171.973<  176.7580  178.1480   refresh Shaded view x10
      171.9730  173.637>  166.180<  171.0940  172.0740   refresh Consistent Colors view x10
      178.9020  179.902>  171.727<  175.2890  177.0120   refresh Realistic view x10
       20.113>   19.8590   19.102<   19.3440   20.0120   activate View Cube view
      100.9060   99.3830   93.535<   95.0310  103.094>   rotate view x1
        6.8280    6.7970    6.621<    6.8200    7.090>   activate View Cube - Sketchy view
      117.1480  118.6990  111.922<  114.1290  122.160>   rotate sketchy view x1
    Note: I do have the XPS Document Writer installed.
    March 4, 2018
    1
    03:12 PM
    Did a quick test at the office, results were a bit but i guess i should of waited until after work so i could run it without the overhead of having other instances of revit and cad hovering around in the background.
    Will also add results of my personal PC when i get home
    Code:
    RVT 2019 - Full_Simplified set - 2018.05.10 @ 16.12.26    RFO Benchmark v3.2 (build 01.05.2018)
        RevitForum.org
        7.25   opening and loading the custom template
       25.51   creating the floors levels and grids
       30.90   creating a group of walls and doors
       46.53   modifying the group by adding a curtain wall
       19.26   creating the exterior curtain wall
       23.61   creating the sections
        6.13   changing the curtain wall panel type
       21.59   creating area plans
        3.23   creating and applying view template
      184.01   TOTAL
    Graphics
       10.29   activate View Styles view
        1.96   change view to Wireframe
        0.13   change view to Hidden
        0.52   change view to Consistent Colors
        1.44   refresh Wireframe Line view x10
        5.31   refresh Hidden Line view x10
        5.66   refresh Shaded view x10
        5.39   refresh Consistent Colors view x10
        6.70   refresh Realistic view x10
        0.79   activate View Cube view
        3.89   rotate view x1
       43.11   TOTAL
    Notes:
    TEST CONDITIONS:
    Mfr: Hewlett-Packard
    Model: HP Z440 Workstation
    CPU: Intel(R) Xeon(R) CPU E5-1620 v3 @ 3.50GHz
    Max Clock Speed: 3.501Ghz
    Total Physical Memory: 64GB @ 2133 2133 2133 2133 2133 2133Mhz
    Drive Model: NVMe SAMSUNG MZVPV256
    Graphics Card: Radmin Mirror Driver V3
    Graphics RAM: 0GB
    Driver version: 3.1.0.0
    Graphics Card: AMD FirePro W5100
    Driver version: 23.20.15025.2011
    DPI Scaling: 100%
    Code:
    RVT 2019 - Full_Simplified set - 2018.05.10  RFO Benchmark v3.2 (build 01.05.2018)
        RevitForum.org
        4.38   opening and loading the custom template
       18.41   creating the floors levels and grids
       25.23   creating a group of walls and doors
       41.34   modifying the group by adding a curtain wall
       14.38   creating the exterior curtain wall
       16.23   creating the sections
        5.18   changing the curtain wall panel type
       16.98   creating area plans
        2.56   creating and applying view template
      144.69   TOTAL
    Graphics
        5.88   activate View Styles view
        1.78   change view to Wireframe
        0.48   change view to Shaded
        0.51   change view to Consistent Colors
        0.48   change view to Realistic
        1.39   refresh Wireframe Line view x10
        5.18   refresh Hidden Line view x10
        5.42   refresh Shaded view x10
        5.16   refresh Consistent Colors view x10
        6.42   refresh Realistic view x10
        0.67   activate View Cube view
        3.61   rotate view x1
       37.10   TOTAL
    Notes:
    TEST CONDITIONS:
    Graphics RAM: 0GB
    DPI Scaling: 100%
  1. RFO Benchmark v3.1 2018 results
    By Gordon Price in forum Hardware and Infrastructure
    Last Post: March 11th, 2019, 08:47 AM
  2. RFO Benchmark v3 2017 results
    Last Post: May 9th, 2018, 08:20 AM
  3. RFO Benchmark v3 2015 results
    Last Post: June 22nd, 2017, 11:39 AM
  4. RFO Benchmark v3 2016 results
    Last Post: May 9th, 2017, 12:00 AM
