Page 8 of 9 FirstFirst ... 456789 LastLast
Results 71 to 80 of 82
Like Tree11Likes
Thread: RFO Benchmark v3.2 2019 results
  1.    #71
    March 2, 2019
    5
    09:15 PM
    Quote Originally Posted by conne View Post
    We run a cloud desktop offering. Currently testing and looking to optimise Revit, because a prospect has very high demands. But of course with the Xeon Server CPU's we run - even though they are one of the highest models - we can't compete with what they set as the baseline (Core i7-8700K 3.7 GHz base, 4.7 GHz boost).
    We run KVM as the hypervisor, Citrix XenDesktop as the "VDI" solution. We haven't done any optimising yet, but looking for some input.
    Thanks in advance.
    Code:
    RVT 2019 - Full_Standard set - 2019.03.01 @ 13.44.20    RFO Benchmark v3.2 (build 01.05.2018)
        RevitForum.org
    All times are in seconds, lower is better.
    Run on Revit 2019 FCS
    _________________________________________________________________
    Update
        9.80   update previous version file
    Model creation benchmark
        4.31   opening and loading the custom template
       13.84   creating the floors levels and grids
       24.46   creating a group of walls and doors
       43.09   modifying the group by adding a curtain wall
       14.66   creating the exterior curtain wall
       11.43   creating the sections
        5.13   changing the curtain wall panel type
       17.04   creating area plans
        2.40   creating and applying view template
      136.36   TOTAL
    Export benchmark
       88.84   export all views as PNGs at 300 dpi
       61.77   export all views as DWFs
      112.43   export all views as DWGs
       69.69   print all views as vector *
      113.56   print all views as raster *
    Notes:
     *  Print Views tests require the 'Microsoft XPS Document Writer' printer be installed.
    Render benchmark
      145.31   render
    Graphics - Standard View
        5.61   activate View Styles view
        0.68   change view to Wireframe
        1.17   change view to Hidden
        1.51   change view to Shaded
        1.58   change view to Consistent Colors
        2.40   change view to Realistic
        1.13   refresh Wireframe Line view x10
        4.60   refresh Hidden Line view x10
        4.99   refresh Shaded view x10
        4.88   refresh Consistent Colors view x10
        5.24   refresh Realistic view x10
        0.61   activate View Cube view
        3.75   rotate view x1
       38.15   TOTAL
    Notes:
        Graphics benchmark measures the entire graphics stack, which includes CPU and memory.
        To meaningfully compare graphics cards, test all cards in the same machine
        and use the 'Graphics - expanded' benchmark.
    TEST CONDITIONS:
    Mfr: Apache Software Foundation
    Model: CloudStack KVM Hypervisor
    OS: Microsoft Windows Server 2019 Datacenter64-bit
    CPU: Intel(R) Xeon(R) Gold 6128 CPU @ 3.40GHz
    Max Clock Speed: 3.4Ghz
    Number of Processors: 4
    Number of Logical Processors: 4
    Total Physical Memory: 32GB @  Mhz
    Drive Type: local Disk (NTFS)
    Drive Model: Red Hat VirtIO SCSI Disk Device
    Graphics Card: Citrix Display Only Adapter
    Graphics RAM: 0GB
    Driver version: 7.20.0.141
    Graphics Card: Citrix Indirect Display Adapter
    Graphics RAM: 0GB
    Driver version: 18.25.29.157
    Graphics Card: NVIDIA Quadro P5000
    Graphics RAM: 3.9990234375GB
    Driver version: 25.21.14.1678
    Graphics Card: Microsoft Basic Display Adapter
    Graphics RAM: 0GB
    Driver version: 10.0.17763.1
    Screen Resolution:  1920 1920 800x 1080 1080 600x32bit @  59 59 1Hz
    DPI Scaling: 100%
    RAW DATA:
       11.469    8.856    9.074   update previous version file
        4.266    4.406    4.250   opening and loading the custom template
       13.879   13.723   13.918   creating the floors levels and grids
       24.477   24.551   24.363   creating a group of walls and doors
       42.992   42.914   43.356   modifying the group by adding a curtain wall
       14.691   14.328   14.965   creating the exterior curtain wall
       11.363   11.211   11.715   creating the sections
        5.262    5.121    5.016   changing the curtain wall panel type
       17.219   17.109   16.797   creating area plans
        2.430    2.477    2.309   creating and applying view template
       91.398   87.445   87.684   export all views as PNGs at 300 dpi
       62.668   61.672   60.965   export all views as DWFs
      114.637  112.531  110.121   export all views as DWGs
       72.426   68.453   68.191   print all views as vector
      116.477  111.891  112.316   print all views as raster
      144.113  145.887  145.918   render
        5.449    5.680    5.695   activate View Styles view
        0.637    0.629    0.785   change view to Wireframe
        1.125    1.199    1.191   change view to Hidden
        1.480    1.520    1.520   change view to Shaded
        1.629    1.566    1.531   change view to Consistent Colors
        2.387    2.414    2.398   change view to Realistic
        1.121    1.137    1.129   refresh Wireframe Line view x10
        4.598    4.523    4.680   refresh Hidden Line view x10
        4.977    5.000    5.008   refresh Shaded view x10
        4.961    4.879    4.789   refresh Consistent Colors view x10
        5.191    5.277    5.250   refresh Realistic view x10
        0.625    0.613    0.602   activate View Cube view
        3.773    3.754    3.734   rotate view x1
    @Twiceroadsfool; it seems like you have some experience optimising VDI environments for Revit. Any chance I can reach out to you to discuss (perhaps on a consultancy basis)?
  2.    #72
    9,912
    03:15 PM
    As has been mentioned, ive seen the Server Xeons get the benchmark down to about 110 (Model creation portion), but it isnt feasible to "optimize" VDI to make it as fast as an 8700k, IMVHO. If they have truly set that machine as the "only acceptable baseline" then one of two things is true: They arent going to use VDI, or they are going to be disappointed. End of story.
  3.    #73
    March 2, 2019
    5
    09:15 PM
    Yes, I very much agree. These requirements are being set by a few key users, the rest of their users wouldn't need that. As they say over here: "the soup is never eaten as hot as it is served". And we have a solution in the works for them, Xeon E-21xxG CPU's that should bring the result closer to their expectations.
    But nonetheless, getting anything lower than 136 would already be a great achievement.
  4.    #74
    April 24, 2014
    Brisbane, Australia
    24
    06:15 AM
    New rigs up and running. Pretty happy with the results so far.
    Code:
    RVT 2019 - Full_Standard set - 2019.03.04 @ 13.24.51 on DESKTOP-LIQ8F6V.txt    RFO Benchmark v3.2 (build 01.05.2018)
        RevitForum.org
    Update
        6.43   update previous version file
        3.25   opening and loading the custom template
       10.13   creating the floors levels and grids
       15.97   creating a group of walls and doors
       28.28   modifying the group by adding a curtain wall
       10.11   creating the exterior curtain wall
        8.56   creating the sections
        3.23   changing the curtain wall panel type
       12.85   creating area plans
        1.76   creating and applying view template
       94.14   TOTAL
    Export benchmark
       53.84   export all views as PNGs at 300 dpi
       44.80   export all views as DWFs
       79.05   export all views as DWGs
       54.16   print all views as vector *
       85.11   print all views as raster *
    Notes:
    Render benchmark
       55.23   render
        3.79   activate View Styles view
        0.39   change view to Wireframe
        0.63   change view to Hidden
        0.83   change view to Shaded
        0.83   change view to Consistent Colors
        1.44   change view to Realistic
        0.67   refresh Wireframe Line view x10
        2.74   refresh Hidden Line view x10
        2.95   refresh Shaded view x10
        2.77   refresh Consistent Colors view x10
        3.07   refresh Realistic view x10
        0.39   activate View Cube view
        2.45   rotate view x1
       22.95   TOTAL
    Notes:
    TEST CONDITIONS:
    Mfr: System manufacturer
    Model: System Product Name
    OS: Microsoft Windows 10 Pro64-bit
    CPU: Intel(R) Core(TM) i7-8700K CPU @ 3.70GHz
    Max Clock Speed: 3.696Ghz
    Number of Processors: 6
    Number of Logical Processors: 12
    Total Physical Memory: 64GB @ 2133 2133 2133 2133Mhz
    Drive Model: Samsung SSD 970 EVO Plus 1TB
    Graphics Card: NVIDIA GeForce RTX 2070
    Driver version: 25.21.14.1917
    Screen Resolution: 1920x1200x32bit @ 59Hz
    DPI Scaling: 100%
    RAW DATA:
        6.398    6.465    6.434   update previous version file
        3.246    3.230    3.266   opening and loading the custom template
       10.223   10.074   10.086   creating the floors levels and grids
       15.945   15.852   16.109   creating a group of walls and doors
       28.207   28.191   28.438   modifying the group by adding a curtain wall
       10.094   10.117   10.117   creating the exterior curtain wall
        8.523    8.606    8.539   creating the sections
        3.219    3.219    3.254   changing the curtain wall panel type
       12.894   12.684   12.965   creating area plans
        1.770    1.730    1.773   creating and applying view template
       53.773   54.016   53.727   export all views as PNGs at 300 dpi
       44.938   44.633   44.828   export all views as DWFs
       79.356   79.086   78.715   export all views as DWGs
       54.273   54.172   54.035   print all views as vector
       85.184   85.098   85.055   print all views as raster
       60.250   52.844   52.590   render
        3.762    3.856    3.766   activate View Styles view
        0.375    0.383    0.398   change view to Wireframe
        0.609    0.641    0.641   change view to Hidden
        0.836    0.852    0.805   change view to Shaded
        0.832    0.828    0.820   change view to Consistent Colors
        1.430    1.434    1.469   change view to Realistic
        0.680    0.664    0.664   refresh Wireframe Line view x10
        2.750    2.727    2.734   refresh Hidden Line view x10
        2.941    2.934    2.965   refresh Shaded view x10
        2.758    2.746    2.801   refresh Consistent Colors view x10
        3.090    3.027    3.102   refresh Realistic view x10
        0.391    0.391    0.387   activate View Cube view
        2.434    2.484    2.445   rotate view x1
  5.    #75
    December 21, 2010
    C.LONDON
    4,343
    08:15 PM
    i7-6700@3.4 w/ 64@2133 & 4GB Quadro K2200
    Code:
    RVT 2019 - Full_Simplified set - 2019.03.05 @ 10.57.49 on PTA-PC125.txt
        RevitForum.org
    Run on Revit 2019.1
        4.49   opening and loading the custom template
       10.82   creating the floors levels and grids
       18.78   creating a group of walls and doors
       33.34   modifying the group by adding a curtain wall
       11.82   creating the exterior curtain wall
        8.91   creating the sections
        3.98   changing the curtain wall panel type
       13.40   creating area plans
        1.81   creating and applying view template
      107.35   TOTAL
    Graphics
        4.41   activate View Styles view
        1.46   change view to Wireframe
        0.10   change view to Hidden
        0.41   change view to Shaded
        0.43   change view to Consistent Colors
        0.41   change view to Realistic
        1.05   refresh Wireframe Line view x10
        4.34   refresh Hidden Line view x10
        4.48   refresh Shaded view x10
        4.29   refresh Consistent Colors view x10
        5.40   refresh Realistic view x10
        0.47   activate View Cube view
        5.23   rotate view x1
       32.48   TOTAL
    Notes:
    TEST CONDITIONS:
    Mfr: Dell Inc.
    Model: Precision Tower 3620
    OS: Microsoft Windows 10 Pro for Workstations64-bit
    CPU: Intel(R) Core(TM) i7-6700 CPU @ 3.40GHz
    Max Clock Speed: 3.408Ghz
    Number of Logical Processors: 8
    Drive Model: SAMSUNG SSD SM871 2.5 7mm 256GB
    Graphics Card: NVIDIA Quadro K2200
    Driver version: 23.21.13.9125
    DPI Scaling: 100%
    i7-6700@3.4 w/ 32@2133 & 4GB Quadro K2200
    Code:
    RVT 2019 - Full_Simplified set - 2019.03.05 @ 10.44.20 on PTA-PC125.txt
        RevitForum.org
    Run on Revit 2019.1
        5.14   opening and loading the custom template
       11.36   creating the floors levels and grids
       19.27   creating a group of walls and doors
       34.02   modifying the group by adding a curtain wall
        8.80   creating the sections
        3.85   changing the curtain wall panel type
       12.67   creating area plans
        1.82   creating and applying view template
      108.75   TOTAL
    Graphics
        4.54   activate View Styles view
        1.47   change view to Wireframe
        0.44   change view to Consistent Colors
        1.09   refresh Wireframe Line view x10
        4.31   refresh Hidden Line view x10
        4.46   refresh Shaded view x10
        4.24   refresh Consistent Colors view x10
        5.38   refresh Realistic view x10
        0.46   activate View Cube view
        5.01   rotate view x1
       32.32   TOTAL
    Notes:
    TEST CONDITIONS:
    Mfr: Dell Inc.
    Total Physical Memory: 32GB @ 2133 2133Mhz
    DPI Scaling: 100%
    i7-4770@3.4 w/ 16@1600 & 2GB Quadro K2000
    Code:
    RVT 2019 - Full_Simplified set - 2019.03.05 @ 10.38.42 on PTA-PC100.txt
        RevitForum.org
    Run on Revit 2019.1
        5.08   opening and loading the custom template
       12.07   creating the floors levels and grids
       20.25   creating a group of walls and doors
       36.48   modifying the group by adding a curtain wall
       12.50   creating the exterior curtain wall
        9.47   creating the sections
        4.29   changing the curtain wall panel type
       14.11   creating area plans
        2.02   creating and applying view template
      116.27   TOTAL
    Graphics
        4.76   activate View Styles view
        1.61   change view to Wireframe
        0.11   change view to Hidden
        0.43   change view to Shaded
        0.45   change view to Consistent Colors
        0.44   change view to Realistic
        1.19   refresh Wireframe Line view x10
        4.61   refresh Hidden Line view x10
        4.88   refresh Shaded view x10
        4.59   refresh Consistent Colors view x10
        5.63   refresh Realistic view x10
        0.52   activate View Cube view
        5.28   rotate view x1
       34.50   TOTAL
    Notes:
    TEST CONDITIONS:
    Mfr: Dell Inc.
    Model: Precision T1700
    CPU: Intel(R) Core(TM) i7-4770 CPU @ 3.40GHz
    Max Clock Speed: 3.401Ghz
    Total Physical Memory: 16GB @ 1600 1600 1600 1600Mhz
    Drive Model: LITEONIT LCS-256M6S 2.5 7mm 256GB
    Graphics Card: NVIDIA Quadro K2000
    Graphics RAM: 2GB
    Screen Resolution: 1920x1080x32bit @ 60Hz
    DPI Scaling: 100%
    i7-4790@3.6 w/ 32@1600 & 2GB QuadroK2000
    Code:
    RVT 2019 - Full_Simplified set - 2019.03.05 @ 15.20.35 on PTA-PC113.txt
        RevitForum.org
    Run on Revit 2019.1
        7.46   opening and loading the custom template
       12.36   creating the floors levels and grids
       20.04   creating a group of walls and doors
       35.95   modifying the group by adding a curtain wall
       12.85   creating the exterior curtain wall
        9.49   creating the sections
        4.30   changing the curtain wall panel type
       14.41   creating area plans
        2.03   creating and applying view template
      118.89   TOTAL
    Graphics
        4.89   activate View Styles view
        1.54   change view to Wireframe
        0.42   change view to Realistic
        1.16   refresh Wireframe Line view x10
        4.48   refresh Hidden Line view x10
        4.65   refresh Shaded view x10
        4.43   refresh Consistent Colors view x10
        5.47   refresh Realistic view x10
        0.50   activate View Cube view
        4.45   rotate view x1
       32.96   TOTAL
    Notes:
    TEST CONDITIONS:
    Mfr: Dell Inc.
    CPU: Intel(R) Core(TM) i7-4790 CPU @ 3.60GHz
    Max Clock Speed: 3.601Ghz
    Total Physical Memory: 32GB @ 1600 1600 1600 1600Mhz
    Drive Model: SAMSUNG SSD SM841N 2.5 7mm 256GB
    DPI Scaling: 100%
    Code:
    RVT 2019 - Full_Simplified set - 2019.03.05 @ 14.05.17 on PTA-PC129.txt
        RevitForum.org
    Run on Revit 2019.1
        6.80   opening and loading the custom template
       12.38   creating the floors levels and grids
       20.50   creating a group of walls and doors
       35.04   modifying the group by adding a curtain wall
       12.60   creating the exterior curtain wall
        9.95   creating the sections
        4.15   changing the curtain wall panel type
       15.24   creating area plans
        2.12   creating and applying view template
      118.78   TOTAL
    Graphics
        5.00   activate View Styles view
        1.51   change view to Wireframe
        1.07   refresh Wireframe Line view x10
        4.39   refresh Hidden Line view x10
        4.53   refresh Shaded view x10
        4.27   refresh Consistent Colors view x10
        5.28   refresh Realistic view x10
        5.32   rotate view x1
       33.21   TOTAL
    Notes:
    TEST CONDITIONS:
    Mfr: Dell Inc.
    Drive Model: SAMSUNG SSD SM871 2.5 7mm 512GB
    DPI Scaling: 100%
    Attached Thumbnails Attached Thumbnails RFO Benchmark v3.2 2019 results-all.png
  6.    #76
    March 5, 2019
    Richmond, VA
    1
    03:15 PM
    Scores from our latest workstation build:
    Code:
    RVT 2019 - Full_Standard set - 2018.11.02 @ 16.41.51 on DESKTOP-0H74H3O.txt
        RevitForum.org
    Update
        2.87   opening and loading the custom template
        7.39   creating the floors levels and grids
       13.42   creating a group of walls and doors
       25.11   modifying the group by adding a curtain wall
        8.04   creating the exterior curtain wall
        6.41   creating the sections
        2.67   changing the curtain wall panel type
        9.49   creating area plans
        1.36   creating and applying view template
       76.76   TOTAL
    Export benchmark
       45.58   export all views as PNGs at 300 dpi
       37.30   export all views as DWFs
       67.05   export all views as DWGs
       45.03   print all views as vector *
       73.71   print all views as raster *
    Notes:
    Render benchmark
       36.22   render
        3.27   activate View Styles view
        0.30   change view to Wireframe
        0.48   change view to Hidden
        0.67   change view to Shaded
        0.65   change view to Consistent Colors
        1.19   change view to Realistic
        0.54   refresh Wireframe Line view x10
        2.37   refresh Hidden Line view x10
        2.55   refresh Shaded view x10
        2.40   refresh Consistent Colors view x10
        2.70   refresh Realistic view x10
        0.33   activate View Cube view
        1.86   rotate view x1
       19.31   TOTAL
    Notes:
    TEST CONDITIONS:
    Mfr: Velocity Micro
    Model: ProMagix HD60
    CPU: Intel(R) Core(TM) i9-9900K CPU @ 3.60GHz
    Max Clock Speed: 3.6Ghz
    Number of Processors: 8
    Number of Logical Processors: 16
    Total Physical Memory: 32GB @ 2667 2667Mhz
    Drive Model: NVMe Samsung SSD 970 SCSI Disk Device
    Driver version: 25.21.14.1616
    Screen Resolution: 1280x1024x32bit @ 60Hz
    DPI Scaling: 100%
    RAW DATA:
        7.707    5.836    5.762   update previous version file
        2.879    2.867    2.867   opening and loading the custom template
        7.434    7.414    7.320   creating the floors levels and grids
       13.324   13.500   13.445   creating a group of walls and doors
       24.938   25.340   25.062   modifying the group by adding a curtain wall
        8.008    8.055    8.070   creating the exterior curtain wall
        6.449    6.457    6.324   creating the sections
        2.672    2.688    2.664   changing the curtain wall panel type
        9.453    9.621    9.398   creating area plans
        1.348    1.391    1.328   creating and applying view template
       46.277   45.656   44.812   export all views as PNGs at 300 dpi
       37.691   37.098   37.117   export all views as DWFs
       67.391   66.219   67.551   export all views as DWGs
       44.930   45.156   45.004   print all views as vector
       73.387   74.312   73.430   print all views as raster
       35.945   36.750   35.957   render
        3.266    3.281    3.266   activate View Styles view
        0.301    0.297    0.309   change view to Wireframe
        0.480    0.484    0.477   change view to Hidden
        0.672    0.672    0.668   change view to Shaded
        0.637    0.672    0.656   change view to Consistent Colors
        1.188    1.195    1.199   change view to Realistic
        0.543    0.531    0.547   refresh Wireframe Line view x10
        2.375    2.359    2.371   refresh Hidden Line view x10
        2.543    2.547    2.555   refresh Shaded view x10
        2.406    2.398    2.410   refresh Consistent Colors view x10
        2.699    2.688    2.707   refresh Realistic view x10
        0.328    0.316    0.340   activate View Cube view
        1.820    1.879    1.867   rotate view x1
    remiscs likes this.
  7.    #77
    Forum Addict Robin Deurloo's Avatar
    July 7, 2011
    Rotterdam, Holland
    1,093
    09:15 PM
    I realised that I never posted any 2019 results for my new workstation, processor clocked to 5,0 Ghz
    Here goes:
    Code:
    RVT 2019 - Full_Simplified set - 2019.03.06 @ 07.13.05 on WORKSTATION.txt
        RevitForum.org
    Run on Revit 2019.2
        3.54   opening and loading the custom template
        8.04   creating the floors levels and grids
       13.59   creating a group of walls and doors
       25.25   modifying the group by adding a curtain wall
        8.50   creating the exterior curtain wall
        6.87   creating the sections
        2.83   changing the curtain wall panel type
       10.08   creating area plans
        1.43   creating and applying view template
       80.13   TOTAL
    Graphics
        3.39   activate View Styles view
        0.90   change view to Wireframe
        0.07   change view to Hidden
        0.27   change view to Shaded
        0.29   change view to Consistent Colors
        0.28   change view to Realistic
        2.86   refresh Hidden Line view x10
        3.02   refresh Shaded view x10
        2.86   refresh Consistent Colors view x10
        3.66   refresh Realistic view x10
        0.35   activate View Cube view
        2.10   rotate view x1
       20.72   TOTAL
    Notes:
    TEST CONDITIONS:
    CPU: Intel(R) Core(TM) i7-8086K CPU @ 4.00GHz (clocked to 5.0 Ghz)
    Max Clock Speed: 4.008Ghz
    Total Physical Memory: 32GB @ 3200 3200 3200 3200Mhz
    Drive Model: Samsung SSD 970 PRO 512GB
    Graphics Card: NVIDIA GeForce GTX 1070 Ti
    Driver version: 25.21.14.1722
    DPI Scaling: 100%
    remiscs likes this.
  8.    #78
    March 6, 2019
    1
    09:15 PM
    My first benchmark on my old laptop.
    Code:
    RVT 2019 - Full_Standard set - 2019.03.06 @ 10.37.04 on MY-LAPTOP.txt
        RevitForum.org
    Run on Revit 2019.1
    Update
       14.99   update previous version file
        6.03   opening and loading the custom template
       23.46   creating the floors levels and grids
       41.62   creating a group of walls and doors
       75.00   modifying the group by adding a curtain wall
       25.97   creating the exterior curtain wall
       20.40   creating the sections
        8.32   changing the curtain wall panel type
       31.00   creating area plans
        4.02   creating and applying view template
      235.82   TOTAL
    Export benchmark
      127.57   export all views as PNGs at 300 dpi
      104.14   export all views as DWFs
      210.71   export all views as DWGs
      138.93   print all views as vector *
      208.34   print all views as raster *
    Notes:
    Render benchmark
      165.33   render
        8.12   activate View Styles view
        1.03   change view to Wireframe
        1.79   change view to Hidden
        2.26   change view to Shaded
        2.27   change view to Consistent Colors
        3.41   change view to Realistic
        2.08   refresh Wireframe Line view x10
        7.13   refresh Hidden Line view x10
        7.71   refresh Shaded view x10
        7.16   refresh Consistent Colors view x10
        8.07   refresh Realistic view x10
        0.96   activate View Cube view
        6.97   rotate view x1
       58.96   TOTAL
    Notes:
    TEST CONDITIONS:
    Mfr: Hewlett-Packard
    Model: HP EliteBook 8570w
    CPU: Intel(R) Core(TM) i7-3610QM CPU @ 2.30GHz
    Max Clock Speed: 2.301Ghz
    Total Physical Memory: 16GB @ 1600 1600 1600Mhz
    Drive Model: Hitachi HTS725050A7E630
    Graphics Card: NVIDIA Quadro K1000M
    Graphics RAM: 2GB
    Driver version: 24.21.14.1216
    Screen Resolution: 1920x1080x32bit @ 59Hz
    DPI Scaling: 100%
    RAW DATA:
       19.535   12.699   12.750   update previous version file
        7.277    5.379    5.441   opening and loading the custom template
       30.680   19.535   20.176   creating the floors levels and grids
       51.258   36.805   36.809   creating a group of walls and doors
       87.644   73.051   64.312   modifying the group by adding a curtain wall
       32.414   22.051   23.457   creating the exterior curtain wall
       25.570   17.152   18.492   creating the sections
       10.406    7.062    7.500   changing the curtain wall panel type
       41.723   25.281   25.988   creating area plans
        5.223    3.367    3.469   creating and applying view template
      165.219  108.144  109.352   export all views as PNGs at 300 dpi
      124.793   94.336   93.277   export all views as DWFs
      272.320  178.484  181.316   export all views as DWGs
      180.664  116.250  119.887   print all views as vector
      263.988  177.379  183.664   print all views as raster
      196.789  151.250  147.941   render
        9.648    7.332    7.375   activate View Styles view
        1.137    1.020    0.938   change view to Wireframe
        1.707    1.766    1.910   change view to Hidden
        2.227    2.281    2.281   change view to Shaded
        2.328    2.289    2.199   change view to Consistent Colors
        3.406    3.383    3.445   change view to Realistic
        2.367    1.977    1.894   refresh Wireframe Line view x10
        7.020    7.164    7.215   refresh Hidden Line view x10
        7.586    7.816    7.719   refresh Shaded view x10
        7.148    7.199    7.121   refresh Consistent Colors view x10
        7.996    7.984    8.242   refresh Realistic view x10
        0.945    0.957    0.977   activate View Cube view
        7.102    7.227    6.570   rotate view x1
  9.    #79
    9,912
    03:15 PM
    I hadnt done the machines here in 2019.2, since there was no need. But a new Laptop showed up, so i figured i would run both laptops side by side, as a comparison. Since the new laptop showed up with some specs incorrect, when the new one gets here, it might be neat to see if the different specs make much difference.
    BIMBOX Stryker-M 15. i9-9900k, 64GB at 2400Mhz, RTX2070. @1920...
    Code:
    RVT 2019 - Full_Standard set - 2019.03.14 @ 10.18.28 on PRLXBBS03.txt
        RevitForum.org
    Run on Revit 2019.2
    Update
        6.94   update previous version file
        3.03   opening and loading the custom template
        9.72   creating the floors levels and grids
       16.05   creating a group of walls and doors
       29.43   modifying the group by adding a curtain wall
        9.91   creating the exterior curtain wall
        8.29   creating the sections
        3.17   changing the curtain wall panel type
       12.47   creating area plans
        1.68   creating and applying view template
       93.75   TOTAL
    Export benchmark
       53.73   export all views as PNGs at 300 dpi
       42.86   export all views as DWFs
       79.50   export all views as DWGs
       52.30   print all views as vector *
       83.24   print all views as raster *
    Notes:
    Render benchmark
       43.87   render
        3.51   activate View Styles view
        0.34   change view to Wireframe
        0.55   change view to Hidden
        0.73   change view to Shaded
        0.73   change view to Consistent Colors
        1.29   change view to Realistic
        0.61   refresh Wireframe Line view x10
        2.56   refresh Hidden Line view x10
        2.76   refresh Shaded view x10
        2.59   refresh Consistent Colors view x10
        2.89   refresh Realistic view x10
        0.36   activate View Cube view
        2.15   rotate view x1
       21.07   TOTAL
    Notes:
    TEST CONDITIONS:
    Mfr: Notebook
    Model: P7xxTM1
    Total Physical Memory: 64GB @ 2400 2400 2400 2400Mhz
    Driver version: 25.21.14.1759
    Screen Resolution: 1920x1080x32bit @ 144Hz
    DPI Scaling: 125%
    RAW DATA:
        8.012    6.250    6.551   update previous version file
        3.062    3.020    3.020   opening and loading the custom template
       10.144    9.586    9.426   creating the floors levels and grids
       16.324   15.824   15.988   creating a group of walls and doors
       29.066   30.238   28.996   modifying the group by adding a curtain wall
        9.914    9.793   10.027   creating the exterior curtain wall
        8.199    8.363    8.297   creating the sections
        3.211    3.184    3.113   changing the curtain wall panel type
       12.566   12.520   12.316   creating area plans
        1.762    1.648    1.625   creating and applying view template
       53.449   54.129   53.621   export all views as PNGs at 300 dpi
       42.883   42.477   43.234   export all views as DWFs
       79.008   79.500   79.984   export all views as DWGs
       52.051   52.621   52.215   print all views as vector
       82.707   83.797   83.211   print all views as raster
       44.133   43.613   43.871   render
        3.531    3.520    3.480   activate View Styles view
        0.352    0.336    0.332   change view to Wireframe
        0.559    0.539    0.543   change view to Hidden
        0.727    0.727    0.734   change view to Shaded
        0.719    0.762    0.715   change view to Consistent Colors
        1.305    1.297    1.281   change view to Realistic
        0.606    0.602    0.609   refresh Wireframe Line view x10
        2.559    2.562    2.566   refresh Hidden Line view x10
        2.750    2.750    2.770   refresh Shaded view x10
        2.582    2.594    2.586   refresh Consistent Colors view x10
        2.891    2.879    2.906   refresh Realistic view x10
        0.352    0.363    0.363   activate View Cube view
        2.164    2.113    2.172   rotate view x1
    Second Machine. Its the same machine, but from last year, so the specs are different:
    BIMBOX Stryker-M 15. i7-8700k, 64GB at 2400Mhz, GTX1080. @1920...
    Code:
    RVT 2019 - Full_Standard set - 2019.03.14 @ 18.54.02 on PRLXBBS02.txt
        RevitForum.org
    Run on Revit 2019.2
    Update
        7.55   update previous version file
        3.60   opening and loading the custom template
       11.22   creating the floors levels and grids
       18.59   creating a group of walls and doors
       33.16   modifying the group by adding a curtain wall
       11.22   creating the exterior curtain wall
        3.73   changing the curtain wall panel type
       14.38   creating area plans
        1.99   creating and applying view template
      107.38   TOTAL
    Export benchmark
       59.03   export all views as PNGs at 300 dpi
       48.71   export all views as DWFs
       89.51   export all views as DWGs
       60.78   print all views as vector *
       93.65   print all views as raster *
    Notes:
    Render benchmark
       57.04   render
        4.25   activate View Styles view
        0.42   change view to Wireframe
        0.68   change view to Hidden
        0.92   change view to Shaded
        0.91   change view to Consistent Colors
        1.57   change view to Realistic
        0.73   refresh Wireframe Line view x10
        3.04   refresh Hidden Line view x10
        3.20   refresh Shaded view x10
        3.00   refresh Consistent Colors view x10
        3.38   refresh Realistic view x10
        0.41   activate View Cube view
        2.49   rotate view x1
       25.00   TOTAL
    Notes:
    TEST CONDITIONS:
    Mfr: Notebook
    Model: P7xxTM1
    Drive Model: Intel Raid 0 Volume
    Graphics Card: NVIDIA GeForce GTX 1080
    Driver version: 24.21.14.1163
    DPI Scaling: 100%
    RAW DATA:
        8.414    7.086    7.164   update previous version file
        3.672    3.594    3.531   opening and loading the custom template
       11.641   11.047   10.984   creating the floors levels and grids
       18.852   18.695   18.219   creating a group of walls and doors
       33.711   33.344   32.422   modifying the group by adding a curtain wall
       11.297   11.328   11.039   creating the exterior curtain wall
        9.391    9.430    9.648   creating the sections
        3.703    3.742    3.734   changing the curtain wall panel type
       14.125   14.547   14.461   creating area plans
        2.000    1.984    1.977   creating and applying view template
       58.727   59.250   59.117   export all views as PNGs at 300 dpi
       48.688   49.273   48.180   export all views as DWFs
       89.203   89.688   89.633   export all views as DWGs
       60.789   60.711   60.836   print all views as vector
       94.578   93.531   92.844   print all views as raster
       56.938   57.414   56.758   render
        4.195    4.273    4.289   activate View Styles view
        0.422    0.422    0.414   change view to Wireframe
        0.703    0.664    0.688   change view to Hidden
        0.914    0.922    0.914   change view to Shaded
        0.883    0.914    0.945   change view to Consistent Colors
        1.547    1.617    1.531   change view to Realistic
        0.758    0.719    0.719   refresh Wireframe Line view x10
        3.102    2.984    3.023   refresh Hidden Line view x10
        3.242    3.164    3.180   refresh Shaded view x10
        3.047    2.977    2.977   refresh Consistent Colors view x10
        3.414    3.289    3.422   refresh Realistic view x10
        0.391    0.406    0.430   activate View Cube view
        2.477    2.500    2.508   rotate view x1
    Last edited by Twiceroadsfool; March 15th, 2019 at 10:27 PM. Reason: Forgot to add second machines data
    remiscs likes this.
  10.    #80
    March 14, 2019
    1
    01:15 PM
    Hey Guys
    Im new here are my stats on my laptop
    Code:
    RVT 2019 - Full_Standard set - 2019.03.14 @ 15.12.46 on DESKTOP-USGU45G.txt    RFO Benchmark v3.2 (build 01.05.2018)
        RevitForum.org
    Update
        9.03   update previous version file
        4.45   opening and loading the custom template
       13.00   creating the floors levels and grids
       22.89   creating a group of walls and doors
       39.47   modifying the group by adding a curtain wall
       14.10   creating the exterior curtain wall
       10.82   creating the sections
        4.68   changing the curtain wall panel type
       16.25   creating area plans
        2.53   creating and applying view template
      128.19   TOTAL
    Export benchmark
       72.48   export all views as PNGs at 300 dpi
       59.17   export all views as DWFs
      111.99   export all views as DWGs
       64.40   print all views as vector *
      116.80   print all views as raster *
    Notes:
    Render benchmark
       95.84   render
        4.94   activate View Styles view
        0.60   change view to Wireframe
        0.95   change view to Hidden
        1.23   change view to Shaded
        1.21   change view to Consistent Colors
        2.01   change view to Realistic
        1.01   refresh Wireframe Line view x10
        3.85   refresh Hidden Line view x10
        4.12   refresh Shaded view x10
        3.90   refresh Consistent Colors view x10
        4.33   refresh Realistic view x10
        0.53   activate View Cube view
        3.14   rotate view x1
       31.82   TOTAL
    Notes:
    TEST CONDITIONS:
    Mfr: ASUSTeK COMPUTER INC.
    Model: GL702VSK
    OS: Microsoft Windows 10 Home64-bit
    CPU: Intel(R) Core(TM) i7-7700HQ CPU @ 2.80GHz
    Max Clock Speed: 2.808Ghz
    Total Physical Memory: 32GB @ 2400 2400Mhz
    Drive Model: HGST HTS721010A9E630
    Screen Resolution: 1920x1080x32bit @ 75Hz
    DPI Scaling: 100%
    RAW DATA:
        8.715    8.391    9.992   update previous version file
        4.055    5.242    4.047   opening and loading the custom template
       12.945   12.977   13.070   creating the floors levels and grids
       22.988   22.934   22.738   creating a group of walls and doors
       39.531   39.691   39.199   modifying the group by adding a curtain wall
       13.984   14.109   14.199   creating the exterior curtain wall
       10.879   10.746   10.840   creating the sections
        4.770    4.656    4.602   changing the curtain wall panel type
       16.301   16.430   16.031   creating area plans
        2.629    2.500    2.453   creating and applying view template
       72.777   72.160   72.492   export all views as PNGs at 300 dpi
       59.711   59.039   58.758   export all views as DWFs
      113.562  110.828  111.586   export all views as DWGs
       64.887   64.133   64.168   print all views as vector
      118.160  115.918  116.328   print all views as raster
       95.898   95.746   95.887   render
        4.910    4.969    4.934   activate View Styles view
        0.703    0.543    0.543   change view to Wireframe
        0.977    0.941    0.934   change view to Hidden
        1.270    1.203    1.211   change view to Shaded
        1.230    1.191    1.203   change view to Consistent Colors
        2.035    1.996    2.000   change view to Realistic
        1.023    0.992    1.023   refresh Wireframe Line view x10
        3.879    3.812    3.856   refresh Hidden Line view x10
        4.133    4.109    4.117   refresh Shaded view x10
        3.914    3.875    3.910   refresh Consistent Colors view x10
        4.312    4.316    4.348   refresh Realistic view x10
        0.520    0.520    0.543   activate View Cube view
        3.148    3.160    3.113   rotate view x1
  1. RFO Benchmark v3.1 2018 results
    By Gordon Price in forum Hardware and Infrastructure
    Last Post: March 11th, 2019, 08:47 AM
  2. RFO Benchmark v3 2017 results
    Last Post: May 9th, 2018, 08:20 AM
  3. RFO Benchmark v3 2015 results
    Last Post: June 22nd, 2017, 11:39 AM
  4. RFO Benchmark v3 2016 results
    Last Post: May 9th, 2017, 12:00 AM
