Page 6 of 6 FirstFirst ... 23456
Results 51 to 59 of 59
Like Tree7Likes
Thread: RFO Benchmark v3.2 2019 results
  1.    #51
    November 19, 2018
    Dresden, Germany
    11
    05:53 AM
    My new build: i9-9900K @5.0GHz w/ Gigabyte GTX 1070 8GB
    Code:
    RVT 2019 - Full_Simplified set - 2019.02.04 @ 14.49.16 on CAD-001.txt
        RFO Benchmark v3.2 (build 01.05.2018)
        RevitForum.org
    All times are in seconds, lower is better.
    Run on Revit 2019 FCS
    _________________________________________________________________
    Model creation benchmark
        4.43   opening and loading the custom template
        9.20   creating the floors levels and grids
       14.66   creating a group of walls and doors
       25.92   modifying the group by adding a curtain wall
        9.06   creating the exterior curtain wall
        7.23   creating the sections
        2.92   changing the curtain wall panel type
       10.49   creating area plans
        1.45   creating and applying view template
       85.36   TOTAL
    Graphics
        3.67   activate View Styles view
        0.94   change view to Wireframe
        0.07   change view to Hidden
        0.32   change view to Shaded
        0.35   change view to Consistent Colors
        0.34   change view to Realistic
        0.68   refresh Wireframe Line view x10
        3.36   refresh Hidden Line view x10
        3.48   refresh Shaded view x10
        3.31   refresh Consistent Colors view x10
        4.20   refresh Realistic view x10
        0.39   activate View Cube view
        3.08   rotate view x1
       24.19   TOTAL
    Notes:
        Graphics benchmark measures the entire graphics stack, which includes CPU and memory.
        To meaningfully compare graphics cards, test all cards in the same machine
        and use the 'Graphics - expanded' benchmark.
    TEST CONDITIONS:
    Mfr: Gigabyte Technology Co., Ltd.
    Model: Z390 AORUS PRO
    OS: Microsoft Windows 10 Pro64-bit
    CPU: Intel(R) Core(TM) i9-9900K CPU @ 3.60GHz
    Max Clock Speed: 3.6Ghz
    Number of Processors: 8
    Number of Logical Processors: 16
    Total Physical Memory: 16GB @ 3200 3200Mhz
    Drive Type: local Disk (NTFS)
    Drive Model: Samsung SSD 970 EVO 500GB
    Graphics Card: NVIDIA GeForce GTX 1070
    Graphics RAM: 3.9990234375GB
    Driver version: 25.21.14.1771
    Screen Resolution: 3840x2160x32bit @ 59Hz
    DPI Scaling: 150%
  2.    #52
    November 26, 2018
    1
    05:53 AM
    Code:
    RVT 2019 - Full_Simplified set - 2019.02.05 @ 17.55.35 on FELIX.txt
        RevitForum.org
    Run on Revit 2019.1
        9.00   opening and loading the custom template
       19.93   creating the floors levels and grids
       38.31   creating a group of walls and doors
       71.23   modifying the group by adding a curtain wall
       22.14   creating the exterior curtain wall
       14.46   creating the sections
        7.64   changing the curtain wall panel type
       19.40   creating area plans
        2.80   creating and applying view template
      204.91   TOTAL
    Graphics
        7.89   activate View Styles view
        2.73   change view to Wireframe
        0.20   change view to Hidden
        0.89   change view to Shaded
        1.00   change view to Consistent Colors
        0.91   change view to Realistic
        1.98   refresh Wireframe Line view x10
        8.97   refresh Hidden Line view x10
       10.08   refresh Shaded view x10
        9.31   refresh Consistent Colors view x10
       11.75   refresh Realistic view x10
        1.05   activate View Cube view
        6.07   rotate view x1
       62.83   TOTAL
    Notes:
    TEST CONDITIONS:
    Mfr: ASUSTeK COMPUTER INC.
    Model: Z9PA-D8 Series
    OS: Microsoft Windows 7 Ultimate 64 64-bit
    CPU: Intel(R) Xeon(R) CPU E5-2660 v2 @ 2.20GHz Intel(R) Xeon(R) CPU E5-2660 v2 @ 2.20GHz
    Max Clock Speed: Ghz
    Number of Processors: 10 10
    Number of Logical Processors: 20 20
    Total Physical Memory: 64GB @ 1600 1600 1600 1600 1600 1600 1600 1600Mhz
    Screen Resolution: 1920 1920x1200 1080x32bit @ 59 60Hz
    DPI Scaling: 100%
  3.    #53
    January 11, 2017
    2
    11:53 PM
    Here's my data:
    Simplified
    Code:
    RVT 2019 - Full_Simplified set - 2019.02.05 @ 10.10.12 on DESKTOP-JSDOU18.txt
        RevitForum.org
    Run on Revit 2019.1
        3.62   opening and loading the custom template
       11.96   creating the floors levels and grids
       19.29   creating a group of walls and doors
       33.33   modifying the group by adding a curtain wall
       12.07   creating the exterior curtain wall
        9.70   creating the sections
        3.94   changing the curtain wall panel type
       14.07   creating area plans
        2.08   creating and applying view template
      110.06   TOTAL
    Graphics
        4.54   activate View Styles view
        1.34   change view to Wireframe
        0.10   change view to Hidden
        0.40   change view to Shaded
        0.43   change view to Consistent Colors
        0.40   change view to Realistic
        1.09   refresh Wireframe Line view x10
        4.28   refresh Hidden Line view x10
        4.44   refresh Shaded view x10
        4.25   refresh Consistent Colors view x10
        5.33   refresh Realistic view x10
        0.48   activate View Cube view
        3.64   rotate view x1
       30.72   TOTAL
    Notes:
    TEST CONDITIONS:
    Mfr: Dell Inc.
    Model: Precision Tower 3620
    OS: Microsoft Windows 10 Pro for Workstations64-bit
    CPU: Intel(R) Xeon(R) CPU E3-1270 v6 @ 3.80GHz
    Max Clock Speed: 3.792Ghz
    Number of Processors: 4
    Number of Logical Processors: 8
    Total Physical Memory: 32GB @ 2400 2400Mhz
    Drive Model: SM961 NVMe SAMSUNG 512GB
    Graphics Card: NVIDIA Quadro P4000
    Driver version: 23.21.13.9125
    Screen Resolution: 5120x1440x32bit @ 23Hz
    DPI Scaling: 100%
    and Standard
    Code:
    RVT 2019 - Full_Standard set - 2019.02.05 @ 09.34.24 on DESKTOP-JSDOU18.txt
        RevitForum.org
    Run on Revit 2019.1
    Update
        7.47   update previous version file
        3.64   opening and loading the custom template
       12.15   creating the floors levels and grids
       19.81   creating a group of walls and doors
       33.51   modifying the group by adding a curtain wall
       11.98   creating the exterior curtain wall
        9.74   creating the sections
        3.98   changing the curtain wall panel type
       14.24   creating area plans
        2.10   creating and applying view template
      111.15   TOTAL
    Export benchmark
       58.31   export all views as PNGs at 300 dpi
       49.45   export all views as DWFs
       85.81   export all views as DWGs
       58.71   print all views as vector *
       90.34   print all views as raster *
    Notes:
     *  Print Views tests require the 'Microsoft XPS Document Writer' printer be installed.
    Render benchmark
       85.30   render
    Graphics - Standard View
        4.52   activate View Styles view
        0.48   change view to Wireframe
        0.89   change view to Hidden
        1.12   change view to Shaded
        1.11   change view to Consistent Colors
        1.78   change view to Realistic
        0.92   refresh Wireframe Line view x10
        3.59   refresh Hidden Line view x10
        3.78   refresh Shaded view x10
        3.65   refresh Consistent Colors view x10
        3.97   refresh Realistic view x10
        3.68   rotate view x1
       29.97   TOTAL
    Notes:
    TEST CONDITIONS:
    Mfr: Dell Inc.
    DPI Scaling: 100%
    RAW DATA:
        7.836    7.301    7.266   update previous version file
        3.688    3.586    3.648   opening and loading the custom template
       12.898   11.840   11.711   creating the floors levels and grids
       20.703   19.285   19.441   creating a group of walls and doors
       35.023   32.699   32.820   modifying the group by adding a curtain wall
       12.062   11.891   11.977   creating the exterior curtain wall
        9.766    9.785    9.660   creating the sections
        3.996    4.020    3.914   changing the curtain wall panel type
       14.242   14.328   14.160   creating area plans
        2.109    2.094    2.086   creating and applying view template
       58.285   58.203   58.438   export all views as PNGs at 300 dpi
       49.254   49.613   49.484   export all views as DWFs
       86.559   85.508   85.371   export all views as DWGs
       58.641   58.676   58.828   print all views as vector
       90.410   90.398   90.215   print all views as raster
       83.133   83.281   89.496   render
        4.555    4.500    4.516   activate View Styles view
        0.473    0.488    0.480   change view to Wireframe
        0.840    0.926    0.910   change view to Hidden
        1.106    1.141    1.125   change view to Shaded
        1.102    1.117    1.109   change view to Consistent Colors
        1.773    1.797    1.773   change view to Realistic
        0.906    0.934    0.906   refresh Wireframe Line view x10
        3.566    3.578    3.625   refresh Hidden Line view x10
        3.738    3.785    3.816   refresh Shaded view x10
        3.606    3.668    3.664   refresh Consistent Colors view x10
        3.961    3.980    3.961   refresh Realistic view x10
        0.465    0.477    0.508   activate View Cube view
        3.699    3.676    3.664   rotate view x1
    I also made an excel spreadsheet to analyze the results that have been posted so far. I also included a few specs from the CPU/GPU manufacturers. Correlation isn't causation blah blah blah, but I was interested to see that RAM MHz could matter even more than single thread CPU speed. Does this make sense to anyone?
    Attached Files Attached Files
    rsnbrgj likes this.
  4.    #54
    February 12, 2019
    1
    09:53 PM
    Results i7-9700k
    Code:
    RVT 2019 - Full_Simplified set - 2019.02.12 @ 15.50.16 on HWRIGHTOLD.txt
        RevitForum.org
    Run on Revit 2019.1
        3.88   opening and loading the custom template
        8.06   creating the floors levels and grids
       14.96   creating a group of walls and doors
       26.82   modifying the group by adding a curtain wall
        8.55   creating the exterior curtain wall
        6.58   creating the sections
        2.88   changing the curtain wall panel type
        9.72   creating area plans
        1.33   creating and applying view template
       82.78   TOTAL
    Graphics
        3.32   activate View Styles view
        0.89   change view to Wireframe
        0.30   change view to Shaded
        0.32   change view to Consistent Colors
        0.30   change view to Realistic
        0.70   refresh Wireframe Line view x10
        3.06   refresh Hidden Line view x10
        3.21   refresh Shaded view x10
        3.02   refresh Consistent Colors view x10
        3.94   refresh Realistic view x10
        0.34   activate View Cube view
        2.18   rotate view x1
       21.65   TOTAL
    Notes:
    TEST CONDITIONS:
    Mfr: Micro-Star International Co., Ltd.
    Model: MS-7B54
    CPU: Intel(R) Core(TM) i7-9700K CPU @ 3.60GHz
    Total Physical Memory: 32GB @ 2667 2667Mhz
    Drive Model: INTEL SSDPEKKW512G8
    Driver version: 23.21.13.8813
    Screen Resolution: 1920x1080x32bit @ 60Hz
    DPI Scaling: 100%
  5.    #55
    November 19, 2018
    Dresden, Germany
    11
    05:53 AM
    For better comparison I ran a test on 1080p and am quite excited. For some reason, the bench didnt realize it was 1080p!? Maybe i had to reboot first. I can consider this the next days.
    System runs stable at 1.275V air cooled (stress tested with Prime95)
    i9-9900K@5.0GHz
    Code:
    RVT 2019 - Full_Simplified set - 2019.02.15 @ 19.37.33 on CAD-001.txt
        RevitForum.org
        2.93   opening and loading the custom template
        7.67   creating the floors levels and grids
       13.62   creating a group of walls and doors
       25.29   modifying the group by adding a curtain wall
        8.19   creating the exterior curtain wall
        6.45   creating the sections
        2.73   changing the curtain wall panel type
        9.45   creating area plans
        1.36   creating and applying view template
       77.69   TOTAL
    Graphics
        3.39   activate View Styles view
        0.87   change view to Wireframe
        0.06   change view to Hidden
        0.28   change view to Shaded
        0.30   change view to Consistent Colors
        0.27   change view to Realistic
        0.63   refresh Wireframe Line view x10
        2.83   refresh Hidden Line view x10
        2.99   refresh Shaded view x10
        2.84   refresh Consistent Colors view x10
        3.72   refresh Realistic view x10
        0.33   activate View Cube view
        2.02   rotate view x1
       20.53   TOTAL
    Notes:
    TEST CONDITIONS:
    DPI Scaling: 100%
  6.    #56
    February 15, 2019
    1
    01:53 AM
    RVT 2019 - Full_Standard set - 2019.02.17 @ 00.28.41 on DESKTOP-B47L6FL.txt
    RevitForum.org
    __________________________________________________ _______________
    Update
    8.36 update previous version file
    4.34 opening and loading the custom template
    14.17 creating the floors levels and grids
    21.35 creating a group of walls and doors
    38.67 modifying the group by adding a curtain wall
    14.21 creating the exterior curtain wall
    12.50 creating the sections
    4.38 changing the curtain wall panel type
    18.02 creating area plans
    2.37 creating and applying view template
    130.01 TOTAL
    Export benchmark
    76.41 export all views as PNGs at 300 dpi
    56.76 export all views as DWFs
    116.91 export all views as DWGs
    78.98 print all views as vector *
    104.03 print all views as raster *
    Notes:
    Render benchmark
    99.50 render
    5.23 activate View Styles view
    0.59 change view to Wireframe
    1.03 change view to Hidden
    1.34 change view to Shaded
    1.34 change view to Consistent Colors
    2.10 change view to Realistic
    1.05 refresh Wireframe Line view x10
    3.94 refresh Hidden Line view x10
    4.19 refresh Shaded view x10
    3.98 refresh Consistent Colors view x10
    4.39 refresh Realistic view x10
    0.53 activate View Cube view
    3.19 rotate view x1
    32.90 TOTAL
    Notes:
    TEST CONDITIONS:
    Mfr: ASUS
    Model: All Series
    CPU: Intel(R) Core(TM) i7-4770 CPU @ 3.40GHz
    Max Clock Speed: 3.401Ghz
    Total Physical Memory: 24GB @ 1600 1600 1600 1600Mhz
    Drive Model: WDC WD10EZEX-08M2NA0
    Graphics Card: AMD Radeon R9 200 Series
    Driver version: 25.20.15017.1010
    Screen Resolution: 1920x1080x32bit @ 59Hz
    DPI Scaling: 100%
    RAW DATA:
    8.414 8.293 8.368 update previous version file
    4.400 4.282 4.328 opening and loading the custom template
    14.047 14.314 14.140 creating the floors levels and grids
    21.525 21.247 21.269 creating a group of walls and doors
    38.490 38.960 38.572 modifying the group by adding a curtain wall
    14.349 14.121 14.148 creating the exterior curtain wall
    12.847 12.020 12.619 creating the sections
    4.431 4.374 4.321 changing the curtain wall panel type
    18.602 17.486 17.969 creating area plans
    2.332 2.359 2.422 creating and applying view template
    76.840 75.656 76.729 export all views as PNGs at 300 dpi
    57.708 56.228 56.357 export all views as DWFs
    117.763 116.182 116.789 export all views as DWGs
    78.959 78.928 79.050 print all views as vector
    102.850 104.972 104.271 print all views as raster
    99.365 99.754 99.366 render
    5.276 5.211 5.204 activate View Styles view
    0.576 0.588 0.599 change view to Wireframe
    1.045 1.020 1.035 change view to Hidden
    1.360 1.322 1.337 change view to Shaded
    1.355 1.337 1.318 change view to Consistent Colors
    2.125 2.103 2.073 change view to Realistic
    1.066 1.034 1.044 refresh Wireframe Line view x10
    3.960 3.935 3.922 refresh Hidden Line view x10
    4.222 4.162 4.183 refresh Shaded view x10
    4.029 3.944 3.970 refresh Consistent Colors view x10
    4.489 4.313 4.356 refresh Realistic view x10
    0.540 0.522 0.538 activate View Cube view
    3.174 3.198 3.210 rotate view x1
  7.    #57
    December 17, 2016
    1
    05:53 AM
    Code:
    RVT 2019 - Full_Standard set - 2019.02.15 @ 15.55.57 on GFRAW00013496.txt    RFO Benchmark v3.2 (build 01.05.2018)
        RevitForum.org
    Update
        7.97   update previous version file
        3.61   opening and loading the custom template
       10.41   creating the floors levels and grids
       18.26   creating a group of walls and doors
       32.91   modifying the group by adding a curtain wall
       11.11   creating the exterior curtain wall
        8.45   creating the sections
        3.66   changing the curtain wall panel type
       12.52   creating area plans
        1.79   creating and applying view template
      102.72   TOTAL
    Export benchmark
       79.18   export all views as PNGs at 300 dpi
       56.56   export all views as DWFs
      125.74   export all views as DWGs
       59.29   print all views as vector *
       96.52   print all views as raster *
    Notes:
    Render benchmark
       68.34   render
        4.08   activate View Styles view
        0.42   change view to Wireframe
        0.74   change view to Hidden
        0.96   change view to Shaded
        0.95   change view to Consistent Colors
        1.61   change view to Realistic
        0.77   refresh Wireframe Line view x10
        3.19   refresh Hidden Line view x10
        3.39   refresh Shaded view x10
        3.24   refresh Consistent Colors view x10
        3.59   refresh Realistic view x10
        0.44   activate View Cube view
        3.14   rotate view x1
       26.52   TOTAL
    Notes:
    TEST CONDITIONS:
    Mfr: Dell Inc.
    Model: Precision 7530
    OS: Microsoft Windows 10 Professionnel64-bit
    CPU: Intel(R) Core(TM) i7-8850H CPU @ 2.60GHz
    Max Clock Speed: 2.592Ghz
    Number of Processors: 6
    Number of Logical Processors: 12
    Drive Model: ST2000LM007-1R8174
    Graphics Card: Intel(R) UHD Graphics 630
    Graphics RAM: 1GB
    Driver version: 24.20.100.6287
    Graphics Card: NVIDIA Quadro P1000
    Driver version: 23.21.13.8908
    Screen Resolution:  1920x 1080x32bit @  60Hz
    DPI Scaling: 100%
    RAW DATA:
        9.262    7.285    7.359   update previous version file
        3.609    3.644    3.562   opening and loading the custom template
       10.520   10.434   10.270   creating the floors levels and grids
       18.336   18.172   18.258   creating a group of walls and doors
       33.133   33.027   32.578   modifying the group by adding a curtain wall
       11.152   11.223   10.957   creating the exterior curtain wall
        8.570    8.434    8.336   creating the sections
        3.656    3.668    3.668   changing the curtain wall panel type
       12.555   12.613   12.406   creating area plans
        1.820    1.758    1.777   creating and applying view template
       79.734   78.238   79.582   export all views as PNGs at 300 dpi
       55.926   57.328   56.422   export all views as DWFs
      125.008  128.125  124.082   export all views as DWGs
       59.316   59.191   59.359   print all views as vector
       95.894   96.648   97.008   print all views as raster
       68.293   67.957   68.777   render
        4.066    4.078    4.082   activate View Styles view
        0.418    0.426    0.430   change view to Wireframe
        0.746    0.730    0.734   change view to Hidden
        0.953    0.957    0.969   change view to Shaded
        0.949    0.969    0.945   change view to Consistent Colors
        1.617    1.606    1.617   change view to Realistic
        0.766    0.770    0.762   refresh Wireframe Line view x10
        3.207    3.168    3.195   refresh Hidden Line view x10
        3.414    3.383    3.383   refresh Shaded view x10
        3.254    3.219    3.242   refresh Consistent Colors view x10
        3.617    3.574    3.574   refresh Realistic view x10
        0.453    0.438    0.422   activate View Cube view
        3.168    3.082    3.180   rotate view x1
  8.    #58
    December 16, 2013
    7
    11:53 PM
    Decent score for reasonable build
    Code:
    RVT 2019 - Full_Simplified set - 2019.02.20 @ 09.41.02 on CAPTIVATE4D-CPU.txt
        RevitForum.org
        5.06   opening and loading the custom template
        9.76   creating the floors levels and grids
       17.12   creating a group of walls and doors
       30.48   modifying the group by adding a curtain wall
       10.27   creating the exterior curtain wall
        8.17   creating the sections
        3.45   changing the curtain wall panel type
       12.11   creating area plans
        1.68   creating and applying view template
       98.10   TOTAL
    Graphics
        4.75   activate View Styles view
        1.25   change view to Wireframe
        0.09   change view to Hidden
        0.36   change view to Shaded
        0.38   change view to Consistent Colors
        0.37   change view to Realistic
        0.98   refresh Wireframe Line view x10
        3.93   refresh Hidden Line view x10
        4.04   refresh Shaded view x10
        3.82   refresh Consistent Colors view x10
        4.83   refresh Realistic view x10
        0.42   activate View Cube view
        2.80   rotate view x1
       28.02   TOTAL
    Notes:
    TEST CONDITIONS:
    Model: MS-7B48
    OS: Microsoft Windows 10 Home64-bit
    CPU: Intel(R) Core(TM) i3-8350K CPU @ 4.20GHz
    Max Clock Speed: 4.20Ghz
    Number of Logical Processors: 4
    Total Physical Memory: 16GB @ 3600 3600Mhz
    Drive Model: INTEL SSDPEKNW020T8
    Driver version: 25.21.14.1881
    Screen Resolution: 1920x1200x32bit @ 59Hz
    DPI Scaling: 100%
  9.    #59
    December 16, 2013
    7
    11:53 PM
    Code:
        RevitForum.org
       98.10   TOTAL
    Graphics
        2.80   rotate view x1
       28.02   TOTAL
    Notes:
    TEST CONDITIONS:
    Model: MS-7B48
    DPI Scaling: 100%
  1. RFO Benchmark v3.1 2018 results
    By Gordon Price in forum Hardware and Infrastructure
    Last Post: January 30th, 2019, 09:20 PM
  2. RFO Benchmark v3 2017 results
    Last Post: May 9th, 2018, 08:20 AM
  3. RFO Benchmark v3 2015 results
    Last Post: June 22nd, 2017, 11:39 AM
  4. RFO Benchmark v3 2016 results
    Last Post: May 9th, 2017, 12:00 AM
