Page 4 of 9 FirstFirst 12345678 ... LastLast
Results 31 to 40 of 84
Like Tree11Likes
Thread: RFO Benchmark v3.2 2019 results
  1. #31
    June 28, 2018
    1
    02:58 PM
    Hi all - I'm having to run RFO tests on several machines. All are running in trial mode since my lab doesn't have access to the corporate license server at the moment. Is there a way to bypass having to click the "Run" button at the trial splash screen? If I recall, a former co-worker used to append some variables to the application target. Any ideas how to do this?
    Thanks
    Joe
  2. #32
    Member remiscs's Avatar
    May 18, 2015
    Las Vegas, NV
    230
    12:58 PM
    Quote Originally Posted by amdlab View Post
    Thanks
    Joe
    What has worked for me was to literally take the system off line and then start the test. It will not do the prompt. I was able to duplicate this worked on two different systems.
  3. #33
    December 6, 2013
    1
    09:58 PM
    My oldtimer machine...MSI Pro-e X58...just switched i7 to Xeon x5680(50$) (OC 4.2Ghz)
    Code:
    RVT 2019 - Full_Standard set - 2018.10.19 @ 22.10.39 on BLERIM-PC.txt
        RFO Benchmark v3.2 (build 01.05.2018)
        RevitForum.org
    All times are in seconds, lower is better.
    Run on Revit 2019.1
    _________________________________________________________________
    Update
       10.19   update previous version file
    Model creation benchmark
        3.75   opening and loading the custom template
       12.70   creating the floors levels and grids
       27.40   creating a group of walls and doors
       53.35   modifying the group by adding a curtain wall
       17.18   creating the exterior curtain wall
       12.54   creating the sections
        5.81   changing the curtain wall panel type
       17.30   creating area plans
        2.51   creating and applying view template
      152.54   TOTAL
    Export benchmark
       83.98   export all views as PNGs at 300 dpi
       73.27   export all views as DWFs
      137.69   export all views as DWGs
       89.81   print all views as vector *
      125.61   print all views as raster *
    Notes:
     *  Print Views tests require the 'Microsoft XPS Document Writer' printer be installed.
    Render benchmark
       90.29   render
    Graphics - Standard View
        5.14   activate View Styles view
        0.61   change view to Wireframe
        1.25   change view to Hidden
        1.78   change view to Shaded
        1.77   change view to Consistent Colors
        2.62   change view to Realistic
        1.44   refresh Wireframe Line view x10
        6.24   refresh Hidden Line view x10
        6.76   refresh Shaded view x10
        6.35   refresh Consistent Colors view x10
        7.11   refresh Realistic view x10
        0.82   activate View Cube view
        5.16   rotate view x1
       47.05   TOTAL
    Notes:
        Graphics benchmark measures the entire graphics stack, which includes CPU and memory.
        To meaningfully compare graphics cards, test all cards in the same machine
        and use the 'Graphics - expanded' benchmark.
    TEST CONDITIONS:
    Mfr: MSI
    Model: MS-7522
    OS: Microsoft Windows 10 Pro64-bit
    CPU: Intel(R) Xeon(R) CPU           X5680  @ 3.33GHz
    Max Clock Speed: 3.333Ghz
    Number of Processors: 6
    Number of Logical Processors: 12
    Total Physical Memory: 24GB @ 1328 1328 1328 1328 1328 1328Mhz
    Drive Type: local Disk (NTFS)
    Drive Model: Samsung SSD 850 PRO 256GB
    Graphics Card: NVIDIA GeForce GTX 780
    Graphics RAM: 3GB
    Driver version: 24.21.13.9811
    Screen Resolution: 2560x1440x32bit @ 59Hz
    DPI Scaling: 100%
    RAW DATA:
       10.258   10.203   10.117   update previous version file
        3.883    3.539    3.820   opening and loading the custom template
       13.586   10.758   13.766   creating the floors levels and grids
       27.930   26.344   27.922   creating a group of walls and doors
       53.328   53.734   52.992   modifying the group by adding a curtain wall
       17.117   17.367   17.047   creating the exterior curtain wall
       12.133   12.672   12.820   creating the sections
        5.836    5.844    5.742   changing the curtain wall panel type
       17.250   17.711   16.945   creating area plans
        2.555    2.508    2.477   creating and applying view template
       84.273   83.031   84.641   export all views as PNGs at 300 dpi
       73.781   72.945   73.094   export all views as DWFs
      139.039  135.453  138.570   export all views as DWGs
       90.453   88.266   90.703   print all views as vector
      126.227  123.719  126.875   print all views as raster
       86.555   86.203   98.117   render
        5.188    5.133    5.102   activate View Styles view
        0.617    0.602    0.609   change view to Wireframe
        1.266    1.266    1.227   change view to Hidden
        1.789    1.758    1.805   change view to Shaded
        1.781    1.766    1.766   change view to Consistent Colors
        2.633    2.609    2.625   change view to Realistic
        1.492    1.414    1.406   refresh Wireframe Line view x10
        6.375    6.133    6.219   refresh Hidden Line view x10
        6.906    6.641    6.742   refresh Shaded view x10
        6.477    6.281    6.297   refresh Consistent Colors view x10
        7.273    6.953    7.094   refresh Realistic view x10
        0.836    0.812    0.812   activate View Cube view
        5.219    5.078    5.195   rotate view x1
    Code:
    RVT 2019 - Full_Simplified set - 2018.10.19 @ 22.00.46 on BLERIM-PC.txt
        RevitForum.org
    Run on Revit 2019.1
        4.21   opening and loading the custom template
       13.60   creating the floors levels and grids
       27.84   creating a group of walls and doors
       53.12   modifying the group by adding a curtain wall
       17.31   creating the exterior curtain wall
       12.74   creating the sections
        5.85   changing the curtain wall panel type
       17.91   creating area plans
      155.09   TOTAL
    Graphics
        5.30   activate View Styles view
        1.99   change view to Wireframe
        0.16   change view to Hidden
        0.70   change view to Shaded
        0.77   change view to Consistent Colors
        0.70   change view to Realistic
        1.66   refresh Wireframe Line view x10
        7.30   refresh Hidden Line view x10
        7.82   refresh Shaded view x10
        7.32   refresh Consistent Colors view x10
        8.85   refresh Realistic view x10
        5.21   rotate view x1
       48.60   TOTAL
    Notes:
    TEST CONDITIONS:
    Mfr: MSI
    Model: MS-7522
    Graphics RAM: 3GB
    DPI Scaling: 100%
    Cheers!
  4. #34
    October 21, 2018
    1
    04:58 PM
    Hello, Im new here. Like to benchmark my setups and this time is not the exception. Wanted to try something different from regular ones like R15, wPrime, etc. Seems Autodesk is not taking advantage of these CPUs with a lot of cores. Still, for someone that is looking to build a TR PC this submit might be useful. CPU is overclocked at 4100 MHz for all cores (and also 24/7 use). DRAM is working as a 4x8GB to enable QuadChannel and using DOCP (like XMP for AMD Asus MBs) at 3200Mhz 14 14 14 34 2T @ 1.35v.
    2990WX stock
    Code:
    RVT 2019 - Full_Simplified set - 2018.10.20 @ 21.41.51 on DESKTOP-8S6KD98.txt
        RevitForum.org
    Run on Revit 2019 FCS
        4.34   opening and loading the custom template
       13.22   creating the floors levels and grids
       22.53   creating a group of walls and doors
       40.52   modifying the group by adding a curtain wall
       13.55   creating the exterior curtain wall
        9.90   creating the sections
        4.66   changing the curtain wall panel type
       14.35   creating area plans
        1.95   creating and applying view template
      125.02   TOTAL
    Graphics
        4.52   activate View Styles view
        1.34   change view to Wireframe
        0.10   change view to Hidden
        0.49   change view to Shaded
        0.55   change view to Consistent Colors
        0.51   change view to Realistic
        0.99   refresh Wireframe Line view x10
        5.12   refresh Hidden Line view x10
        5.54   refresh Shaded view x10
        5.02   refresh Consistent Colors view x10
        6.30   refresh Realistic view x10
        0.58   activate View Cube view
        4.26   rotate view x1
       35.32   TOTAL
    Notes:
    TEST CONDITIONS:
    Mfr: System manufacturer
    Model: System Product Name
    CPU: AMD Ryzen Threadripper 2990WX 32-Core Processor
    Max Clock Speed: 4.1Ghz
    Number of Processors: 32
    Number of Logical Processors: 64
    Total Physical Memory: 30GB @ 3200 3200 3200 3200Mhz
    Drive Model: KINGSTON SUV400S37240G
    Graphics Card: NVIDIA Quadro 5000
    Graphics RAM: 2.1875GB
    Driver version: 10.18.13.5330
    Screen Resolution: 1920x1080x32bit @ 60Hz
    DPI Scaling: 100%
    2990X w/ SMT off
    Code:
    RVT 2019 - Full_Simplified set - 2018.10.20 @ 21.58.02 on DESKTOP-8S6KD98.txt
        RevitForum.org
        4.09   opening and loading the custom template
       10.10   creating the floors levels and grids
       20.00   creating a group of walls and doors
       37.34   modifying the group by adding a curtain wall
       11.64   creating the exterior curtain wall
        8.41   creating the sections
        4.05   changing the curtain wall panel type
       12.55   creating area plans
        1.73   creating and applying view template
      109.91   TOTAL
    Graphics
        4.25   activate View Styles view
        1.27   change view to Wireframe
        0.09   change view to Hidden
        0.42   change view to Shaded
        0.45   change view to Consistent Colors
        0.43   change view to Realistic
        0.91   refresh Wireframe Line view x10
        4.42   refresh Hidden Line view x10
        4.56   refresh Shaded view x10
        4.33   refresh Consistent Colors view x10
        5.50   refresh Realistic view x10
        0.48   activate View Cube view
        4.23   rotate view x1
       31.34   TOTAL
    Notes:
    TEST CONDITIONS:
    Number of Logical Processors: 32
    DPI Scaling: 100%
    Regards
    remiscs and quattro23 like this.
  5. #35
    July 30, 2017
    1
    01:58 AM
    Code:
    RVT 2019 - Full_Standard set - 2018.06.30 @ 23.57.25 on DESKTOP-E8IS73P.txt
        RevitForum.org
    Update
        7.38   update previous version file
        3.45   opening and loading the custom template
        9.60   creating the floors levels and grids
       17.13   creating a group of walls and doors
       31.45   modifying the group by adding a curtain wall
       10.13   creating the exterior curtain wall
        7.84   creating the sections
        3.38   changing the curtain wall panel type
       11.48   creating area plans
        1.61   creating and applying view template
       96.07   TOTAL
    Export benchmark
       54.92   export all views as PNGs at 300 dpi
       43.51   export all views as DWFs
       87.85   export all views as DWGs
       54.64   print all views as vector *
       85.46   print all views as raster *
    Notes:
    Render benchmark
       56.60   render
        4.44   activate View Styles view
        0.39   change view to Wireframe
        0.88   change view to Hidden
        0.87   change view to Shaded
        0.88   change view to Consistent Colors
        1.49   change view to Realistic
        0.71   refresh Wireframe Line view x10
        2.93   refresh Hidden Line view x10
        3.12   refresh Shaded view x10
        2.96   refresh Consistent Colors view x10
        3.33   refresh Realistic view x10
        0.40   activate View Cube view
        2.40   rotate view x1
       24.80   TOTAL
    Notes:
    TEST CONDITIONS:
    Mfr: To Be Filled By O.E.M.
    Model: To Be Filled By O.E.M.
    OS: Майкрософт Windows 10 Корпоративная 2016 с долгосрочным обслуживанием64-bit
    CPU: Intel(R) Core(TM) i7-8700 CPU @ 3.20GHz
    Max Clock Speed: 3.192Ghz
    Total Physical Memory: 16GB @ 2667 2667Mhz
    Drive Model: ST500DM002-1BD142
    Graphics Card: NVIDIA GeForce GTX 980
    Graphics RAM: 3.9990234375GB
    Driver version: 24.21.13.9836
    DPI Scaling: 100%
    RAW DATA:
        8.586    6.768    6.796   update previous version file
        3.438    3.446    3.478   opening and loading the custom template
        9.828    9.509    9.463   creating the floors levels and grids
       17.078   17.263   17.048   creating a group of walls and doors
       31.633   31.288   31.426   modifying the group by adding a curtain wall
       10.203   10.150   10.042   creating the exterior curtain wall
        7.835    7.908    7.773   creating the sections
        3.371    3.393    3.368   changing the curtain wall panel type
       11.589   11.428   11.436   creating area plans
        1.622    1.580    1.640   creating and applying view template
       54.525   55.488   54.732   export all views as PNGs at 300 dpi
       43.613   43.675   43.234   export all views as DWFs
       88.298   87.425   87.841   export all views as DWGs
       54.366   54.767   54.790   print all views as vector
       85.299   85.584   85.507   print all views as raster
       57.154   56.251   56.397   render
        4.466    4.451    4.410   activate View Styles view
        0.397    0.384    0.384   change view to Wireframe
        0.905    0.896    0.843   change view to Hidden
        0.870    0.848    0.893   change view to Shaded
        0.904    0.868    0.873   change view to Consistent Colors
        1.485    1.501    1.476   change view to Realistic
        0.721    0.697    0.702   refresh Wireframe Line view x10
        2.946    2.903    2.938   refresh Hidden Line view x10
        3.123    3.089    3.154   refresh Shaded view x10
        2.969    2.936    2.983   refresh Consistent Colors view x10
        3.317    3.340    3.339   refresh Realistic view x10
        0.406    0.386    0.398   activate View Cube view
        2.429    2.390    2.395   rotate view x1
  6. #36
    March 19, 2014
    44
    08:58 PM
    RVT 2019 rfo results i7 4790k/quadro p1000
    Code:
    RVT 2019 - Full_Simplified set - 2018.11.05 @ 11.30.18 on A55.txt
        RevitForum.org
    Run on Revit 2019.0.2
        4.50   opening and loading the custom template
       10.37   creating the floors levels and grids
       17.42   creating a group of walls and doors
       31.42   modifying the group by adding a curtain wall
       10.64   creating the exterior curtain wall
        7.93   creating the sections
        3.75   changing the curtain wall panel type
       11.70   creating area plans
        1.71   creating and applying view template
       99.44   TOTAL
    Graphics
        4.38   activate View Styles view
        1.26   change view to Wireframe
        0.36   change view to Shaded
        0.39   change view to Consistent Colors
        0.37   change view to Realistic
        1.01   refresh Wireframe Line view x10
        3.90   refresh Hidden Line view x10
        4.06   refresh Shaded view x10
        3.92   refresh Consistent Colors view x10
        5.03   refresh Realistic view x10
        0.42   activate View Cube view
        2.88   rotate view x1
       28.08   TOTAL
    Notes:
    TEST CONDITIONS:
    Mfr: ASUS
    Model: All Series
    CPU: Intel(R) Core(TM) i7-4790K CPU @ 4.00GHz
    Max Clock Speed: 4.001Ghz
    Number of Processors: 4
    Number of Logical Processors: 8
    Total Physical Memory: 16GB @ 1600 1600Mhz
    Graphics Card: NVIDIA Quadro P1000
    Driver version: 23.21.13.9174
    Screen Resolution: 2560x1080x32bit @ 60Hz
    DPI Scaling: 100%
  7. #37
    March 19, 2014
    44
    08:58 PM
    If the ryzen could run at 4,6ghz.......that would be awesome!!!
    Right now the intel with highest clock speed (overclocked or not) is really the revit king.
    Shame the prices of the intels are way too high at the moment.
  8. #38
    10,038
    02:58 PM
    Helping someone test another VDI setup, that DOESNT use Nvidias vGPU's, because their licensing is goddamned out of control, price wise. Have to say, im quite pleased with these results. And its only our third test.
    Code:
    RVT 2019 - Full_Standard set - 2018.11.06 @ 13.43.47 on POC.txt
        RevitForum.org
    Update
        8.60   update previous version file
        3.52   opening and loading the custom template
       11.03   creating the floors levels and grids
       21.46   creating a group of walls and doors
       40.03   modifying the group by adding a curtain wall
       12.58   creating the exterior curtain wall
        9.02   creating the sections
        4.25   changing the curtain wall panel type
       13.98   creating area plans
        2.23   creating and applying view template
      118.10   TOTAL
    Export benchmark
       77.20   export all views as PNGs at 300 dpi
       60.49   export all views as DWFs
      115.84   export all views as DWGs
       63.68   print all views as vector *
       97.08   print all views as raster *
    Notes:
    Render benchmark
       21.69   render
        5.12   activate View Styles view
        0.81   change view to Wireframe
        1.54   change view to Hidden
        1.67   change view to Shaded
        1.68   change view to Consistent Colors
        2.79   change view to Realistic
        1.04   refresh Wireframe Line view x10
        3.98   refresh Hidden Line view x10
        4.41   refresh Shaded view x10
        4.29   refresh Consistent Colors view x10
        4.94   refresh Realistic view x10
        0.59   activate View Cube view
        3.16   rotate view x1
       36.02   TOTAL
    Notes:
    TEST CONDITIONS:
    Mfr:
    Model:
    OS:
    CPU: Intel(R) Xeon(R) CPU E5-2667 v4 @ 3.20GHz Intel(R) Xeon(R) CPU E5-2667 v4 @ 3.20GHz
    Max Clock Speed: Ghz
    Number of Processors: 4 4
    Number of Logical Processors: 4 4
    Total Physical Memory: 32GB @  Mhz
    Drive Model: VMware Virtual disk SCSI Disk Device
    Graphics Card: AMD MxGPU
    Driver version: 24.20.12024.10
    Graphics Card: Microsoft Basic Display Adapter
    Graphics RAM: 0GB
    Driver version: 10.0.14393.0
    Screen Resolution: 1920 1024x1080 768x32bit @ 59 1Hz
    DPI Scaling: 100%
    RAW DATA:
        9.133    8.336    8.344   update previous version file
        3.598    3.473    3.492   opening and loading the custom template
       11.180   11.051   10.852   creating the floors levels and grids
       21.617   21.438   21.340   creating a group of walls and doors
       39.859   40.352   39.883   modifying the group by adding a curtain wall
       12.695   12.465   12.590   creating the exterior curtain wall
        8.930    9.039    9.090   creating the sections
        4.230    4.258    4.270   changing the curtain wall panel type
       13.812   13.801   14.316   creating area plans
        2.211    2.184    2.281   creating and applying view template
       78.027   77.496   76.062   export all views as PNGs at 300 dpi
       60.652   60.133   60.672   export all views as DWFs
      117.859  115.219  114.449   export all views as DWGs
       65.633   62.305   63.102   print all views as vector
      101.113   95.016   95.098   print all views as raster
       21.832   21.496   21.754   render
        5.082    5.191    5.082   activate View Styles view
        0.805    0.824    0.805   change view to Wireframe
        1.500    1.535    1.570   change view to Hidden
        1.652    1.680    1.664   change view to Shaded
        1.707    1.668    1.652   change view to Consistent Colors
        2.894    2.766    2.711   change view to Realistic
        0.945    0.992    1.184   refresh Wireframe Line view x10
        3.812    4.000    4.113   refresh Hidden Line view x10
        4.586    4.391    4.262   refresh Shaded view x10
        4.781    4.109    3.980   refresh Consistent Colors view x10
        5.371    4.730    4.711   refresh Realistic view x10
        0.656    0.551    0.559   activate View Cube view
        3.164    3.172    3.141   rotate view x1
  9. #39
    March 19, 2014
    44
    08:58 PM
    Not bad at all. So with a faster xeon you should even get higher scores?
    Verstuurd vanaf mijn SM-G935F met Tapatalk
  10. #40
    July 13, 2017
    5
    09:58 PM
    Is there not a way to collate this information in a format that it is easy to compare different units?
  1. RFO Benchmark v3.1 2018 results
    By Gordon Price in forum Hardware and Infrastructure
    Last Post: March 11th, 2019, 08:47 AM
  2. RFO Benchmark v3 2017 results
    Last Post: May 9th, 2018, 08:20 AM
  3. RFO Benchmark v3 2015 results
    Last Post: June 22nd, 2017, 11:39 AM
  4. RFO Benchmark v3 2016 results
    Last Post: May 9th, 2017, 12:00 AM
