Page 1 of 4 1234 LastLast
Results 1 to 10 of 33
Like Tree21Likes
Thread: Laptops & Revit
    January 18, 2018
    3
    12:15 AM
    Laptops & Revit
    I am looking for a laptop that will primarily run Revit, and occasionally run Autocad and Navisworks. I don't do a lot of graphics and rendering in Revit, my focus is primarily on production work and not design. I will be working with some large models as links (~400mb), but my own files will rarely go above 50mb.
    I am looking at the Microsoft Surface Book 2, quad-core i7 8650U cpu, 16 GB RAM. I am not too savvy on CPUs and how to compare them, so I am a little concerned that it has a 1.9 GHz base freq (4.2 GHz Turbo). Does having a lower base frequency really matter with Revit if it has a higher turbo? Autodesk simply states "Highest affordable CPU speed rating recommended".
    Or if you have recommendations for other solid laptops/workstations, I would really appreciate it.
    Thanks!
    uaifestival likes this.
    New Member poch2017's Avatar
    October 30, 2017
    philippines
    1
    02:15 PM
    I found this thru searching in the internet: In-depth guide to 5 Best Laptops for Revit (2017 August update)
    hope it helps.
    cvts1 likes this.
    June 21, 2012
    Tours, France
    896
    07:15 AM
    Hi cvts1,
    First of all Welcome to the forum!
    Secondly, You need to consider that if you want a good laptop the cost will be high, Processor Speed must be as high as your budget allows it, most high speed is better, I'm running a laptop with a Intel CORE I7, 7820HK CPU @2.90GHz 2.90 GHz, 32 GB RAM DDR4, as a graphics card I'm running a NVIDIA GeForce GTX 1080, WIN 10 64 Bits, and two extra screens.
    My personal opinion about this laptop is: Even if We bought the best machine possible at the time, I found it good for graphics, I can handled high detail projects, since here we work in interior architecture so our models are very high detailed, I'm struggling with WIN 10 Crashes most part of time without an explanation, so System is a mayor pain these days for me, today our models are 130 MB minimum, so I strongly recommend you to seek for a most powerful processor.
    if you want more info please look at this thread:
    https://www.revitforum.org/hardware-...dware-cpu.html
    cvts1 likes this.
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    6,055
    02:15 AM
    You should also take into account things like traveling and docking. If you spend a lot of time in airports, the weight of the system can become an issue. Lugging a 10lb laptop around gets old quick, even with a backpack. If you are going to be working at your desk most of the time and are hooking up to external monitors, the outputs on the laptop can matter. Some of them don't officially support docking and require external hardware (usually USB) to connect everything.
    Andres Franco and cvts1 like this.
    June 21, 2012
    Tours, France
    896
    07:15 AM
    Yes!! I have actually 2 USB Ports , 1 HDMI port, 1 mini USB and 1 Mini display port , not enough in my opinion, and yes this laptop is quite heavy
    9,906
    01:15 AM
    I really really really really really really love the Surface Books..... But i wouldnt buy one for Revit. Itll run it decently, but strictly in the "value per dollar" category, they arent a great deal for running Revit.
    A mid level Dell Precision 7520, or any of the Gaming Laptops with decent hardware, will run it much better and be decently cheaper.
    cganiere, remiscs and cvts1 like this.
    Member FBlome's Avatar
    Menlo Park, California
    82
    11:15 PM
    Just for perspective, I've been using a very portable but now ancient Razer Blade 14 2013 for outside of the office work, meetings, and presentations. My Revit models are under 150mb and I don't see any speed issues. I'd never use it for production work due to it's dinky/flat keyboard, but I have plugged in keyboards, monitors and huge TVs. It has a Nvidia card that drives Enscape and Twinmotion just fine. The latest Lumion lags though. And the aging battery's life sucks now.
    i7-4702 - 2..2GHz @ 3.2Ghz 8GB ram, Nvidia GTX 765M https://www.pcmag.com/article2/0,2817,2421240,00.asp
    cvts1 likes this.
    December 21, 2010
    C.LONDON
    4,343
    06:15 AM
    I use a 13" 1.3Ghz Atom "powered" handbag-friendly laptop sporting a monstrous 2GB of RAM and a whole 32GB of SSD. It runs Revit perfectly, when I remote into my main machine.
    My point?
    Whilst I think I understand the arguments why people still do... I don't "get" why people keep busting gut and nut to spec. laptops to workstation-level performance markers for Revit.
    For games, sure, you ain't joining the PCMR when using remote protocols - but this is Revit, that glitchy-chuggy-epileptic-fit-inducing-nightmare-of-GUI-cludgeness... you don't need 60fps to use it. You don't even need 8bit colour.
    cganiere likes this.
    August 9, 2011
    Louisville, KY
    6,055
    02:15 AM
    Having a decent internet connection isn't always available for a decent RDC.
    9,906
    01:15 AM
    My point?
    Opinions obviously vary, but the performance of "glitchy chuggy epileptic fit inducing nightmare of GUI cludgeness" in Revit running on a 15 inch mobile workstation is tangible WORLDS different than running through RDP or a remote viewing protocol like LogMeIn or Teamviewer. WORLDS better. Only with real VDI on vGPU enabled workstations, would i even entertain remote access for more than a temporary solution.
  1. Looking for laptops to run Revit
    By joewallace in forum Hardware and Infrastructure
    Last Post: August 31st, 2018, 03:47 PM
  2. RTC: Get Your Laptops And Lederhosen Ready!
    By RTC in forum Blog Feeds
    Last Post: March 21st, 2017, 12:45 AM
  3. The thinnest Revit laptops side by side
    By Andrew P in forum Hardware and Infrastructure
    Last Post: March 13th, 2014, 04:06 PM
  4. Existing conditions field measurement & tablets / laptops
    By cellophane in forum Hardware and Infrastructure
    Last Post: June 3rd, 2013, 03:10 PM
  5. Dell 97 Whr 9-Cell Lithium Battery Slice for Latitude Laptops / Precision
    By airedale in forum Hardware and Infrastructure
    Last Post: December 26th, 2012, 05:04 AM
