Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: RFO Benchmark v3.1 2017 results
    Rotterdam, South Holland
    2,948
    02:46 AM
    Please post your RFOBenchmark V3.1 results for the 2017 products here.
    Comments and suggestions should be made in the RFOBenchmark v3.1 thread. The download is there too.
    Note: To condense your results, click Go Advanced, highlight the results, then click the code button (the one with a #).
    Thanks!
    Gordon
    2,948
    02:46 AM
    I'll kick things off with my final test runs.
    Code:
    RVT 2017 - Full_Simplified set - 2017.09.15 @ 15.05.30 on PX-0.txt
        RFO Benchmark v3.1 (build 01.09.2017)
        RevitForum.org
    All times are in seconds, lower is better.
    Run on Revit 2017.2
    _________________________________________________________________
    Model creation benchmark
        7.17   opening and loading the custom template
       16.29   creating the floors levels and grids
       29.68   creating a group of walls and doors
       48.22   modifying the group by adding a curtain wall
       16.50   creating the exterior curtain wall
       11.42   creating the sections
        5.46   changing the curtain wall panel type
       13.90   creating area plans
        1.97   creating and applying view template
      150.61   TOTAL
    Graphics
        7.24   activate View Styles view
        2.54   change view to Wireframe
        0.13   change view to Hidden
        0.55   change view to Shaded
        0.65   change view to Consistent Colors
        0.57   change view to Realistic
        1.47   refresh Wireframe Line view x10
        6.24   refresh Hidden Line view x10
        6.43   refresh Shaded view x10
        6.09   refresh Consistent Colors view x10
        7.60   refresh Realistic view x10
        0.66   activate View Cube view
       10.29   rotate view x1
       50.46   TOTAL
    Notes:
        Graphics benchmark measures the entire graphics stack, which includes CPU and memory.
        To meaningfully compare graphics cards, test all cards in the same machine
        and use the 'Graphics - expanded' benchmark.
    TEST CONDITIONS:
    Mfr: Apple Inc.
    Model: MacBookPro11,3
    OS: Microsoft Windows 10 Pro64-bit
    CPU: Intel(R) Core(TM) i7-4870HQ CPU @ 2.50GHz
    Max Clock Speed: 2.501Ghz
    Number of Processors: 4
    Number of Logical Processors: 8
    Total Physical Memory: 16GB @ 1600 1600Mhz
    Drive Type: Network Drive
    Drive Model: Not Available
    Graphics Card: NVIDIA GeForce GT 750M
    Graphics RAM: 2GB
    Driver version: 22.21.13.8494
    Screen Resolution: 2880x1800x32bit @ 59Hz
    February 10, 2011
    26
    08:46 PM
    Thanks Gordon, this benckmark is great to have again. I think I found one slight issue (maybe a Y2K type of thing)... when the graphics card has a double digit number for memory it drops the first number.
    Sorry, I don't know how to enclose the results in a "Code" window like Gordon did in the previous post. Here is my first test:
    Code:
    RVT 2017 - Full_Simplified set - 2017.09.16 @ 08.57.10 on DLHVRBOX.txt
        RevitForum.org
    Run on Revit 2017.2.1
        2.77   opening and loading the custom template
        9.69   creating the floors levels and grids
       19.45   creating a group of walls and doors
       37.39   modifying the group by adding a curtain wall
       11.34   creating the exterior curtain wall
        7.80   creating the sections
        4.01   changing the curtain wall panel type
        9.13   creating area plans
        1.31   creating and applying view template
      102.89   TOTAL
    Graphics
        4.10   activate View Styles view
        1.50   change view to Wireframe
        0.12   change view to Hidden
        0.46   change view to Shaded
        0.48   change view to Consistent Colors
        0.46   change view to Realistic
        1.26   refresh Wireframe Line view x10
        4.89   refresh Hidden Line view x10
        5.06   refresh Shaded view x10
        4.85   refresh Consistent Colors view x10
        6.04   refresh Realistic view x10
        0.53   activate View Cube view
        3.41   rotate view x1
       33.16   TOTAL
    Notes:
    TEST CONDITIONS:
    Mfr: Dell Inc.
    Model: Precision Tower 5810
    CPU: Intel(R) Xeon(R) CPU E5-1630 v3 @ 3.70GHz
    Max Clock Speed: 3.701Ghz
    Number of Logical Processors: 4
    Total Physical Memory: 16GB @ 2133 2133 2133 2133Mhz
    Drive Type: local Disk (NTFS)
    Drive Model: NVMe SM951 NVMe SAMSU
    Graphics Card: NVIDIA Quadro P6000
    Graphics RAM: 3.9990234375GB
    Driver version: 22.21.13.8205
    Screen Resolution: 1920x1200x32bit @ 59Hz
    September 18, 2017
    1
    08:46 AM
    Hello
    Code:
    RVT 2017 - Full_Simplified set - 2017.09.18 @ 15.23.03 on N052454.txt
        RevitForum.org
        5.73   opening and loading the custom template
       16.53   creating the floors levels and grids
       27.48   creating a group of walls and doors
       46.66   modifying the group by adding a curtain wall
       15.11   creating the exterior curtain wall
       11.62   creating the sections
        4.98   changing the curtain wall panel type
       13.73   creating area plans
        1.71   creating and applying view template
      143.55   TOTAL
    Graphics
        7.23   activate View Styles view
        1.73   change view to Wireframe
        0.51   change view to Shaded
        0.52   change view to Consistent Colors
        0.51   change view to Realistic
        1.30   refresh Wireframe Line view x10
        5.51   refresh Hidden Line view x10
        5.60   refresh Shaded view x10
        5.25   refresh Consistent Colors view x10
        6.66   refresh Realistic view x10
        0.61   activate View Cube view
        4.22   rotate view x1
       39.78   TOTAL
    Notes:
    TEST CONDITIONS:
    Mfr: Hewlett-Packard
    Model: HP Z440 Workstation
    OS: Майкрософт Windows 10 Pro (Registered Trademark)64-bit
    CPU: Intel(R) Xeon(R) CPU E5-1650 v3 @ 3.50GHz
    Max Clock Speed: 3.501Ghz
    Number of Processors: 6
    Number of Logical Processors: 12
    Total Physical Memory: 32GB @ 2133 2133 2133 2133Mhz
    Drive Model: WDC WD10EZEX-60WN4A0
    Graphics Card: NVIDIA Quadro M4000
    Driver version: 21.21.13.7295
    Screen Resolution: 1920x1080x32bit @ 60Hz
    February 7, 2017
    3
    02:46 AM
    This is great. Seems like the new mobile workstation I got at work today should cope nicely
    Code:
    RVT 2017 - Full_Simplified set - 2017.09.20 @ 00.14.40 on GB-7VY2GH2.txt    RFO Benchmark v3.1 (build 01.09.2017)
        RevitForum.org
        5.36   opening and loading the custom template
       12.06   creating the floors levels and grids
       22.34   creating a group of walls and doors
       40.07   modifying the group by adding a curtain wall
       12.21   creating the exterior curtain wall
        8.07   creating the sections
        4.12   changing the curtain wall panel type
        9.49   creating area plans
        1.41   creating and applying view template
      115.13   TOTAL
    Graphics
        4.83   activate View Styles view
        1.68   change view to Wireframe
        0.14   change view to Hidden
        0.50   change view to Consistent Colors
        0.53   change view to Realistic
        1.37   refresh Wireframe Line view x10
        5.42   refresh Hidden Line view x10
        5.58   refresh Shaded view x10
        5.20   refresh Consistent Colors view x10
        6.56   refresh Realistic view x10
        0.55   activate View Cube view
        3.72   rotate view x1
       36.59   TOTAL
    Notes:
    TEST CONDITIONS:
    Mfr: Dell Inc.
    Model: Precision 7520
    OS: Microsoft Windows 7 Enterprise 64-bit
    CPU: Intel(R) Core(TM) i7-6820HQ CPU @ 2.70GHz
    Max Clock Speed: 2.701Ghz
    Total Physical Memory: 32GB @ 2400 2400Mhz
    Drive Model: NVMe A400 NVMe SanDis SCSI Disk Device
    Graphics Card: Intel(R) HD Graphics 530
    Graphics RAM: 1GB
    Driver version: 21.20.16.4574
    Graphics Card: NVIDIA Quadro M2200
    Driver version: 21.21.13.7711
    Screen Resolution:  1920x 1080x32bit @  60Hz
    May 10, 2017
    3
    03:46 AM
    Code:
    RVT 2017 - Full_Standard set - 2017.09.20 @ 17.07.53 on PC1.txt
        RevitForum.org
    Run on Revit 2017 FCS
    Update
        7.28   update previous version file
        2.91   opening and loading the custom template
       12.46   creating the floors levels and grids
       19.26   creating a group of walls and doors
       32.84   modifying the group by adding a curtain wall
       11.37   creating the exterior curtain wall
        8.99   creating the sections
        3.79   changing the curtain wall panel type
       10.36   creating area plans
        1.35   creating and applying view template
      103.33   TOTAL
    Export benchmark
       64.16   export all views as PNGs at 300 dpi
       87.15   export all views as DWFs
      137.50   export all views as DWGs
       65.01   print all views as vector *
      101.80   print all views as raster *
    Notes:
     *  Print Views tests require the 'Microsoft XPS Document Writer' printer be installed.
    Render benchmark
      114.33   render
    Graphics - Standard View
        4.79   activate View Styles view
        0.57   change view to Wireframe
        1.23   change view to Hidden
        1.56   change view to Shaded
        1.49   change view to Consistent Colors
        2.18   change view to Realistic
        1.02   refresh Wireframe Line view x10
        4.17   refresh Hidden Line view x10
        4.75   refresh Shaded view x10
        4.36   refresh Consistent Colors view x10
        6.46   refresh Realistic view x10
        1.00   activate View Cube view
        5.33   rotate view x1
       38.91   TOTAL
    Graphics - Sketchy View
        0.81   activate View Styles - Sketchy view
        2.30   change sketchy view to Wireframe
        1.49   change sketchy view to Hidden
        1.82   change sketchy view to Shaded
        1.84   change sketchy view to Consistent Colors
        1.67   change sketchy view to Realistic
        1.77   refresh sketchy Wireframe Line view x10
        4.96   refresh sketchy Hidden Line view x10
        5.56   refresh sketchy Shaded view x10
        5.14   refresh sketchy Consistent Colors view x10
        7.21   refresh sketchy Realistic view x10
        1.09   activate View Cube - Sketchy view
        7.07   rotate sketchy view x1
       42.73   TOTAL
    Notes:
    TEST CONDITIONS:
    Mfr: MSI
    Model: MS-7A70
    CPU: Intel(R) Core(TM) i5-7600 CPU @ 3.50GHz
    Max Clock Speed: 3.504Ghz
    Total Physical Memory: 16GB @ 2133 2133Mhz
    Drive Model: ADATA SX8000NP
    Graphics Card: Intel(R) HD Graphics 630
    Graphics RAM: 1GB
    Driver version: 21.20.16.4534
    Coeur d Alene, ID
    4,183
    05:46 PM
    Quote Originally Posted by bobivg View Post
    Code:
    Graphics RAM: 1GB
    Bob, do you not have a dedicated video card on your machine? If you do, check to make sure that it is setup as default in the display settings
    Link is for Infraworks, but it works for all programs when you select Global Settings. https://knowledge.autodesk.com/suppo...nfraWorks.html
    Check that and see if that improves your benchmark some.
    May 10, 2017
    3
    03:46 AM
    I do not have a video card. My computer is for Autocad and studying the Revit.
    March 17, 2015
    1
    01:46 AM
    First time posting here.
    This is my setup that I ran with the benchmark test:
    Code:
    RVT 2017 - Full_Standard set - 2017.09.20 @ 10.38.14 on SEA-DROONEY-L.txt    RFO Benchmark v3.1 (build 01.09.2017)
        RevitForum.org
    Run on Revit 2017.2.2
    Update
        8.74   update previous version file
        3.45   opening and loading the custom template
       14.04   creating the floors levels and grids
       24.49   creating a group of walls and doors
       43.01   modifying the group by adding a curtain wall
       15.08   creating the exterior curtain wall
       10.73   creating the sections
        5.23   changing the curtain wall panel type
       12.88   creating area plans
        1.84   creating and applying view template
      130.75   TOTAL
    Export benchmark
       70.99   export all views as PNGs at 300 dpi
       55.81   export all views as DWFs
      102.66   export all views as DWGs
       63.41   print all views as vector *
      104.73   print all views as raster *
    Notes:
    Render benchmark
       97.66   render
        4.88   activate View Styles view
        0.51   change view to Wireframe
        1.01   change view to Hidden
        1.33   change view to Shaded
        1.38   change view to Consistent Colors
        2.16   change view to Realistic
        1.12   refresh Wireframe Line view x10
        4.25   refresh Hidden Line view x10
        4.59   refresh Shaded view x10
        4.38   refresh Consistent Colors view x10
        4.70   refresh Realistic view x10
        0.57   activate View Cube view
        4.34   rotate view x1
       35.22   TOTAL
        0.65   activate View Styles - Sketchy view
        2.55   change sketchy view to Wireframe
        1.45   change sketchy view to Hidden
        1.64   change sketchy view to Realistic
        2.02   refresh sketchy Wireframe Line view x10
        5.23   refresh sketchy Hidden Line view x10
        5.39   refresh sketchy Shaded view x10
        5.22   refresh sketchy Consistent Colors view x10
        5.63   refresh sketchy Realistic view x10
        0.69   activate View Cube - Sketchy view
       14.46   rotate sketchy view x1
       48.59   TOTAL
    Notes:
    TEST CONDITIONS:
    Mfr: HP
    Model: HP ZBook 17 G4
    OS: Microsoft Windows 10 Enterprise64-bit
    CPU: Intel(R) Core(TM) i7-7820HQ CPU @ 2.90GHz
    Max Clock Speed: 2.904Ghz
    Drive Model: THNSN5512GPU7 TOSHIBA
    Graphics Card: NVIDIA Quadro P5000
    Driver version: 22.21.13.8541
    Graphics RAM: 1GB
    Driver version: 21.20.16.4590
    Screen Resolution: 2560 1920x1440 1080x32bit @ 59 60Hz
    RAW DATA:
        9.059    9.059    8.094   update previous version file
        3.445    3.562    3.336   opening and loading the custom template
       13.863   14.094   14.152   creating the floors levels and grids
       23.098   25.777   24.582   creating a group of walls and doors
       43.012   45.305   40.699   modifying the group by adding a curtain wall
       14.801   15.555   14.891   creating the exterior curtain wall
       10.211   11.219   10.758   creating the sections
        4.969    5.613    5.102   changing the curtain wall panel type
       11.770   14.414   12.461   creating area plans
        1.824    1.832    1.859   creating and applying view template
       70.156   74.668   68.152   export all views as PNGs at 300 dpi
       56.711   56.199   54.531   export all views as DWFs
      105.023  102.457  100.500   export all views as DWGs
       64.371   63.422   62.445   print all views as vector
      105.527  104.531  104.133   print all views as raster
      101.383   95.879   95.719   render
        4.832    4.934    4.871   activate View Styles view
        0.500    0.516    0.504   change view to Wireframe
        0.969    1.035    1.012   change view to Hidden
        1.363    1.336    1.293   change view to Shaded
        1.438    1.293    1.414   change view to Consistent Colors
        2.266    2.062    2.141   change view to Realistic
        1.129    1.121    1.117   refresh Wireframe Line view x10
        4.273    4.254    4.234   refresh Hidden Line view x10
        4.875    4.477    4.422   refresh Shaded view x10
        4.629    4.246    4.266   refresh Consistent Colors view x10
        4.863    4.613    4.625   refresh Realistic view x10
        0.559    0.609    0.547   activate View Cube view
        4.484    4.305    4.230   rotate view x1
        0.656    0.668    0.625   activate View Styles - Sketchy view
        2.559    2.574    2.516   change sketchy view to Wireframe
        1.539    1.387    1.430   change sketchy view to Hidden
        1.898    1.773    1.785   change sketchy view to Shaded
        1.918    1.809    1.805   change sketchy view to Consistent Colors
        1.766    1.586    1.555   change sketchy view to Realistic
        2.129    1.973    1.965   refresh sketchy Wireframe Line view x10
        5.551    5.074    5.062   refresh sketchy Hidden Line view x10
        5.586    5.309    5.262   refresh sketchy Shaded view x10
        5.418    5.137    5.117   refresh sketchy Consistent Colors view x10
        5.742    5.551    5.598   refresh sketchy Realistic view x10
        0.758    0.656    0.656   activate View Cube - Sketchy view
       15.035   14.289   14.066   rotate sketchy view x1
    June 2, 2013
    3
    02:46 AM
    RVT 2017 - Full_Standard set - 2017.09.21 @ 10.18.56 on LAP16321.txt
    RevitForum.org
    Run on Revit 2017.0.3
    __________________________________________________ _______________
    Update
    10.17 update previous version file
    6.17 opening and loading the custom template
    23.27 creating the floors levels and grids
    34.90 creating a group of walls and doors
    51.17 modifying the group by adding a curtain wall
    19.91 creating the exterior curtain wall
    16.91 creating the sections
    5.66 changing the curtain wall panel type
    16.67 creating area plans
    2.54 creating and applying view template
    177.20 TOTAL
    Export benchmark
    95.79 export all views as PNGs at 300 dpi
    130.62 export all views as DWFs
    204.26 export all views as DWGs
    106.68 print all views as vector *
    133.02 print all views as raster *
    Notes:
    Render benchmark
    154.47 render
    9.19 activate View Styles view
    0.61 change view to Wireframe
    1.28 change view to Hidden
    1.71 change view to Shaded
    1.74 change view to Consistent Colors
    2.48 change view to Realistic
    1.29 refresh Wireframe Line view x10
    5.06 refresh Hidden Line view x10
    5.52 refresh Shaded view x10
    5.05 refresh Consistent Colors view x10
    5.70 refresh Realistic view x10
    0.85 activate View Cube view
    10.64 rotate view x1
    51.12 TOTAL
    1.72 activate View Styles - Sketchy view
    2.60 change sketchy view to Wireframe
    1.23 change sketchy view to Hidden
    1.45 change sketchy view to Shaded
    1.39 change sketchy view to Consistent Colors
    1.29 change sketchy view to Realistic
    1.51 refresh sketchy Wireframe Line view x10
    4.04 refresh sketchy Hidden Line view x10
    4.26 refresh sketchy Shaded view x10
    4.06 refresh sketchy Consistent Colors view x10
    4.71 refresh sketchy Realistic view x10
    0.79 activate View Cube - Sketchy view
    19.30 rotate sketchy view x1
    48.35 TOTAL
    Notes:
    TEST CONDITIONS:
    Mfr: HP
    Model: HP ZBook Studio G3
    CPU: Intel(R) Xeon(R) CPU E3-1505M v5 @ 2.80GHz
    Max Clock Speed: 2.808Ghz
    Total Physical Memory: 32GB @ 2133 2133Mhz
    Drive Model: TS1TMTS800
    Graphics Card: Intel(R) HD Graphics P530
    Graphics RAM: 1GB
    Graphics Card: NVIDIA Quadro M1000M
    Driver version: 21.21.13.7748
    Screen Resolution: 3840 x2160 x32bit @ 59 Hz
    RAW DATA:
    11.180 9.711 9.609 update previous version file
    6.852 5.992 5.652 opening and loading the custom template
    24.398 22.465 22.957 creating the floors levels and grids
    34.230 31.172 39.301 creating a group of walls and doors
    50.637 49.672 53.188 modifying the group by adding a curtain wall
    19.606 18.309 21.809 creating the exterior curtain wall
    17.094 16.754 16.891 creating the sections
    5.969 5.344 5.668 changing the curtain wall panel type
    16.840 16.195 16.977 creating area plans
    2.461 2.488 2.664 creating and applying view template
    93.168 95.641 98.570 export all views as PNGs at 300 dpi
    121.805 139.664 130.394 export all views as DWFs
    188.109 205.633 219.023 export all views as DWGs
    101.566 101.012 117.477 print all views as vector
    131.449 135.215 132.410 print all views as raster
    144.672 146.820 171.930 render
    8.926 9.352 9.301 activate View Styles view
    0.535 0.684 0.598 change view to Wireframe
    1.305 1.250 1.285 change view to Hidden
    1.965 1.629 1.539 change view to Shaded
    1.852 1.664 1.695 change view to Consistent Colors
    2.492 2.473 2.461 change view to Realistic
    1.227 1.324 1.309 refresh Wireframe Line view x10
    5.129 5.062 4.977 refresh Hidden Line view x10
    5.660 5.410 5.504 refresh Shaded view x10
    5.043 5.027 5.066 refresh Consistent Colors view x10
    5.609 5.426 6.059 refresh Realistic view x10
    0.856 0.816 0.891 activate View Cube view
    10.106 10.465 11.340 rotate view x1
    1.484 2.230 1.449 activate View Styles - Sketchy view
    3.496 3.578 0.738 change sketchy view to Wireframe
    1.891 1.738 0.047 change sketchy view to Hidden
    2.121 2.184 0.047 change sketchy view to Shaded
    2.055 2.055 0.047 change sketchy view to Consistent Colors
    1.891 1.930 0.047 change sketchy view to Realistic
    2.211 2.195 0.137 refresh sketchy Wireframe Line view x10
    5.961 6.000 0.156 refresh sketchy Hidden Line view x10
    6.301 6.148 0.332 refresh sketchy Shaded view x10
    6.020 6.016 0.152 refresh sketchy Consistent Colors view x10
    6.523 7.457 0.144 refresh sketchy Realistic view x10
    0.988 1.246 0.144 activate View Cube - Sketchy view
    25.617 29.945 2.324 rotate sketchy view x1
  1. RFO Benchmark v3.1 2018 results
    By Gordon Price in forum Hardware and Infrastructure
    Last Post: February 11th, 2018, 04:10 AM
  2. RFO Benchmark v3 2017 results
    Last Post: December 19th, 2017, 09:14 PM
  3. RFO Benchmark v3 2015 results
    Last Post: June 22nd, 2017, 11:39 AM
  4. RFO Benchmark v3 2016 results
    Last Post: May 9th, 2017, 12:00 AM
