Page 1 of 11 12345 ... LastLast
Results 1 to 10 of 103
Like Tree14Likes
Thread: RFO Benchmark v3.1 2018 results
    Rotterdam, South Holland
    3,038
    10:59 AM
    Please post your RFOBenchmark V3.1 results for the 2018 products here.
    Comments and suggestions should be made in the RFOBenchmark v3.1 thread. The download is there too.
    Note: To condense your results, click Go Advanced, highlight the results, then click the code button (the one with a #).
    Thanks!
    Gordon
    3,038
    10:59 AM
    I'll kick things off with my final test runs. Note that, as is often the case, the newest version of Revit is not the fastest. But if you look at the 2016 & 2017 results I posted, you see that 2017 is now basically as fast as 2016, though that wasn't initially the case either. Revit updates over time can dramatically affect performance as well as address bugs. All the more reason for the improved build reporting in RFO Benchmark 3.1.
    Code:
    RVT 2018 - Full_Simplified set - 2017.09.15 @ 14.59.35 on PX-0.txt
        RFO Benchmark v3.1 (build 01.09.2017)
        RevitForum.org
    All times are in seconds, lower is better.
    Run on Revit 2018.1
    _________________________________________________________________
    Model creation benchmark
        5.90   opening and loading the custom template
       20.39   creating the floors levels and grids
       35.05   creating a group of walls and doors
       53.09   modifying the group by adding a curtain wall
       22.30   creating the exterior curtain wall
       15.97   creating the sections
        5.74   changing the curtain wall panel type
       20.50   creating area plans
        2.45   creating and applying view template
      181.39   TOTAL
    Graphics
        5.56   activate View Styles view
        2.52   change view to Wireframe
        0.13   change view to Hidden
        0.64   change view to Shaded
        0.67   change view to Consistent Colors
        0.64   change view to Realistic
        1.43   refresh Wireframe Line view x10
        7.01   refresh Hidden Line view x10
        7.05   refresh Shaded view x10
        6.80   refresh Consistent Colors view x10
        8.43   refresh Realistic view x10
        0.76   activate View Cube view
       10.31   rotate view x1
       51.95   TOTAL
    Notes:
        Graphics benchmark measures the entire graphics stack, which includes CPU and memory.
        To meaningfully compare graphics cards, test all cards in the same machine
        and use the 'Graphics - expanded' benchmark.
    TEST CONDITIONS:
    Mfr: Apple Inc.
    Model: MacBookPro11,3
    OS: Microsoft Windows 10 Pro64-bit
    CPU: Intel(R) Core(TM) i7-4870HQ CPU @ 2.50GHz
    Max Clock Speed: 2.501Ghz
    Number of Processors: 4
    Number of Logical Processors: 8
    Total Physical Memory: 16GB @ 1600 1600Mhz
    Drive Type: Network Drive
    Drive Model: Not Available
    Graphics Card: NVIDIA GeForce GT 750M
    Graphics RAM: 2GB
    Driver version: 22.21.13.8494
    Screen Resolution: 2880x1800x32bit @ 59Hz
    Member troygates's Avatar
    December 17, 2010
    Southern California
    143
    01:59 AM
    Results of Graphics_Expanded set on a Surface Book with discrete graphics card
    Code:
    RVT 2018 - Graphics_Expanded set - 2017.09.15 @ 14.10.19
    Graphics - Activate first view
       80.20   activate View Styles view
    Graphics - Change view visual style from a common start
       38.34   common start: from Hidden Line to Wireframe
       68.49   common start: from Hidden Line to Shaded
       67.86   common start: from Hidden Line to Consistent Colors
       72.08   common start: from Hidden Line to Realistic
       21.62   common start: from Consistent Colors to Wireframe
       68.93   common start: from Consistent Colors to Hidden Line
       62.26   common start: from Consistent Colors to Shaded
       60.31   common start: from Consistent Colors to Realistic
      459.89   TOTAL
    Graphics - Change view visual style from a common end
       56.14   common end: from Wireframe to Hidden Line
       55.54   common end: from Shaded to Hidden Line
       71.98   common end: from Consistent Colors to Hidden Line
       65.45   common end: from Realistic to Hidden Line
       58.24   common end: from Wireframe to Consistent Colors
       60.14   common end: from Hidden Line to Consistent Colors
       58.40   common end: from Shaded to Consistent Colors
       59.10   common end: from Realistic to Consistent Colors
      484.99   TOTAL
    Graphics - Change view visual style in sequence
       24.13   in sequence: from Realistic to Wireframe
       68.41   in sequence: from Wireframe to Hidden Line
       63.82   in sequence: from Hidden Line to Shaded
       58.30   in sequence: from Shaded to Consistent Colors
       70.89   in sequence: from Consistent Colors to Realistic
       67.67   in sequence: from Realistic to Consistent Colors
       64.04   in sequence: from Consistent Colors to Shaded
       70.29   in sequence: from Shaded to Hidden Line
       22.11   in sequence: from Hidden Line to Wireframe
      509.66   TOTAL
    Graphics - Refresh views
       77.39   refresh Wireframe view x10
      167.52   refresh Hidden Line view x10
      188.49   refresh Shaded view x10
      184.06   refresh Consistent Colors view x10
      222.63   refresh Realistic view x10
      840.09   TOTAL
    Graphics - Rotate views
       19.89   activate View Cube view
      185.31   rotate view x1
       19.41   activate View Cube - Sketchy view
      266.92   rotate sketchy view x1
      491.53   TOTAL
    TEST CONDITIONS:
    Mfr: Microsoft Corporation
    Model: Surface Book
    CPU: Intel(R) Core(TM) i7-6600U CPU @ 2.60GHz
    Max Clock Speed: 2.808Ghz
    Number of Processors: 2
    Number of Logical Processors: 4
    Total Physical Memory: 16GB @ 1867 1867Mhz
    Graphics Card: NVIDIA GeForce GPU
    Graphics RAM: 1GB
    Driver version: 21.21.13.7667
    Graphics Card: Intel(R) HD Graphics 520
    Graphics RAM: 1GB
    Driver version: 20.19.15.4463
    Screen Resolution:  1920x 1200x32bit @  60Hz
    November 4, 2012
    3
    10:59 AM
    This is my results. Revit still doesn't really use multiple cores (dual xeon, 16cores 32 threads).
    Code:
    RVT 2018 - Full_Simplified set - 2017.09.17 @ 18.01.00 on DUPLAXEON.txt
        RevitForum.org
    Run on Revit 2018.1
        4.89   opening and loading the custom template
       21.16   creating the floors levels and grids
       37.50   creating a group of walls and doors
       69.18   modifying the group by adding a curtain wall
       24.25   creating the exterior curtain wall
       21.13   creating the sections
        7.93   changing the curtain wall panel type
       27.58   creating area plans
        3.25   creating and applying view template
      216.87   TOTAL
    Graphics
        7.25   activate View Styles view
        2.61   change view to Wireframe
        0.25   change view to Hidden
        0.97   change view to Shaded
        1.07   change view to Consistent Colors
        1.00   change view to Realistic
        2.41   refresh Wireframe Line view x10
       10.13   refresh Hidden Line view x10
       10.38   refresh Shaded view x10
        9.79   refresh Consistent Colors view x10
       11.99   refresh Realistic view x10
        1.11   activate View Cube view
        6.70   rotate view x1
       65.66   TOTAL
    Notes:
    TEST CONDITIONS:
    Mfr: ASUSTeK COMPUTER INC.
    Model: Z9PA-D8 Series
    OS: Microsoft Windows 10 Pro64 64-bit
    CPU: Intel(R) Xeon(R) CPU E5-2670 0 @ 2.60GHz Intel(R) Xeon(R) CPU E5-2670 0 @ 2.60GHz
    Max Clock Speed: Ghz
    Number of Processors: 8 8
    Number of Logical Processors: 16 16
    Total Physical Memory: 56GB @ 1333 1333 1333 1333 1333 1333 1333Mhz
    Drive Type: local Disk (NTFS)
    Drive Model: Samsung SSD 840 EVO 250GB
    Graphics Card: NVIDIA GeForce GTX 970
    Graphics RAM: 3.9990234375GB
    Driver version: 22.21.13.8541
    Graphics Card: Általános Microsoft-videokártya
    Graphics RAM: 0GB
    Driver version: 10.0.15063.0
    Screen Resolution: 1920 1920x1200 1200x32bit @ 59 59Hz
    March 4, 2011
    C.Budejovice, CZ
    9
    10:59 AM
    Quite impressive numbers on a HP Z240 Workstation with a SSD disk:
    Code:
    RVT 2018 - Full_Standard set - 2017.09.18 @ 15.15.23 on PC-CADstudio.txt
        RevitForum.org
    Run on Revit 2018.1.1
    Update
        7.52   update previous version file
        2.77   opening and loading the custom template
       10.04   creating the floors levels and grids
       18.04   creating a group of walls and doors
       33.70   modifying the group by adding a curtain wall
       10.63   creating the exterior curtain wall
        9.06   creating the sections
        3.70   changing the curtain wall panel type
       12.35   creating area plans
        1.69   creating and applying view template
      101.98   TOTAL
    Export benchmark
       63.42   export all views as PNGs at 300 dpi
       48.64   export all views as DWFs
       99.85   export all views as DWGs
       57.69   print all views as vector *
       92.80   print all views as raster *
    Notes:
     *  Print Views tests require the 'Microsoft XPS Document Writer' printer be installed.
    Render benchmark
       78.74   render
    Graphics - Standard View
        3.95   activate View Styles view
        0.49   change view to Wireframe
        0.96   change view to Hidden
        1.14   change view to Shaded
        1.13   change view to Consistent Colors
        1.89   change view to Realistic
        0.95   refresh Wireframe Line view x10
        3.65   refresh Hidden Line view x10
        3.89   refresh Shaded view x10
        3.75   refresh Consistent Colors view x10
        4.12   refresh Realistic view x10
        0.56   activate View Cube view
        5.83   rotate view x1
       32.31   TOTAL
    Graphics - Sketchy View
        0.78   activate View Styles - Sketchy view
        2.38   change sketchy view to Wireframe
        1.35   change sketchy view to Hidden
        1.59   change sketchy view to Shaded
        1.58   change sketchy view to Consistent Colors
        1.39   change sketchy view to Realistic
        1.74   refresh sketchy Wireframe Line view x10
        4.46   refresh sketchy Hidden Line view x10
        4.68   refresh sketchy Shaded view x10
        4.51   refresh sketchy Consistent Colors view x10
        4.86   refresh sketchy Realistic view x10
        0.62   activate View Cube - Sketchy view
       12.81   rotate sketchy view x1
       42.75   TOTAL
    Notes:
    TEST CONDITIONS:
    Mfr: HP
    Model: HP Z240 Tower Workstation
    CPU: Intel(R) Core(TM) i7-6700 CPU @ 3.40GHz
    Max Clock Speed: 3.401Ghz
    Total Physical Memory: 32GB @ 2133 2133Mhz
    Drive Model: MTFDDAK512TBN-1AR1ZABHA
    Graphics Card: NVIDIA Quadro K620
    Graphics RAM: 2GB
    Driver version: 22.21.13.8248
    Screen Resolution: 1920x1200x32bit @ 59Hz
    November 4, 2012
    3
    10:59 AM
    I ran it on my small core m notebook. not bad from a 4.5W chip.
    Code:
    RVT 2018 - Full_Simplified set - 2017.09.24 @ 17.22.44 on YOGA3PRO.txt
        RevitForum.org
    Run on Revit 2018.1
        5.31   opening and loading the custom template
       23.74   creating the floors levels and grids
       41.76   creating a group of walls and doors
       67.02   modifying the group by adding a curtain wall
       24.74   creating the exterior curtain wall
       22.17   creating the sections
        8.84   changing the curtain wall panel type
       32.10   creating area plans
        3.78   creating and applying view template
      229.46   TOTAL
    Graphics
        8.02   activate View Styles view
        4.88   change view to Wireframe
        0.35   change view to Hidden
        1.37   change view to Shaded
        1.45   change view to Consistent Colors
        1.39   change view to Realistic
        4.14   refresh Wireframe Line view x10
       16.05   refresh Hidden Line view x10
       16.06   refresh Shaded view x10
       15.19   refresh Consistent Colors view x10
       18.89   refresh Realistic view x10
        1.73   activate View Cube view
       13.36   rotate view x1
      102.88   TOTAL
    Notes:
    TEST CONDITIONS:
    Mfr: LENOVO
    Model: 80HE
    CPU: Intel(R) Processor 5Y70 CPU @ 1.10GHz
    Max Clock Speed: 1.301Ghz
    Total Physical Memory: 8GB @ 1600 1600Mhz
    Drive Model: SAMSUNG MZNTE256HMHP-000L2
    Graphics Card: Intel(R) HD Graphics 5300
    Graphics RAM: 1GB
    Driver version: 20.19.15.4642
    Screen Resolution: 1600x900x32bit @ 59Hz
    October 4, 2017
    1
    04:59 AM
    I7-7700, 32 GB ram, 960 Pro, 1080 TI - My results
    Code:
    RVT 2018 - Full_Standard set - 2017.10.04 @ 17.20.50 on TW.txt
        RevitForum.org
    Run on Revit 2018.1
    Update
        7.25   update previous version file
        2.76   opening and loading the custom template
        9.74   creating the floors levels and grids
       16.76   creating a group of walls and doors
       29.67   modifying the group by adding a curtain wall
        9.80   creating the exterior curtain wall
        8.59   creating the sections
        3.47   changing the curtain wall panel type
       11.35   creating area plans
        1.59   creating and applying view template
       93.73   TOTAL
    Export benchmark
       50.50   export all views as PNGs at 300 dpi
       41.13   export all views as DWFs
       81.83   export all views as DWGs
       48.56   print all views as vector *
       70.41   print all views as raster *
    Notes:
    Render benchmark
       67.76   render
        3.54   activate View Styles view
        0.41   change view to Wireframe
        0.87   change view to Hidden
        1.08   change view to Shaded
        1.05   change view to Consistent Colors
        1.67   change view to Realistic
        0.86   refresh Wireframe Line view x10
        3.58   refresh Hidden Line view x10
        3.74   refresh Shaded view x10
        3.60   refresh Consistent Colors view x10
        3.85   refresh Realistic view x10
        0.47   activate View Cube view
        3.72   rotate view x1
       28.44   TOTAL
        0.49   activate View Styles - Sketchy view
        1.89   change sketchy view to Wireframe
        1.18   change sketchy view to Hidden
        1.42   change sketchy view to Shaded
        1.45   change sketchy view to Consistent Colors
        1.28   change sketchy view to Realistic
        1.54   refresh sketchy Wireframe Line view x10
        4.23   refresh sketchy Hidden Line view x10
        4.40   refresh sketchy Shaded view x10
        4.26   refresh sketchy Consistent Colors view x10
        4.52   refresh sketchy Realistic view x10
        0.53   activate View Cube - Sketchy view
       16.52   rotate sketchy view x1
       43.71   TOTAL
    Notes:
    TEST CONDITIONS:
    Mfr: System manufacturer
    Model: System Product Name
    CPU: Intel(R) Core(TM) i7-7700K CPU @ 4.20GHz
    Max Clock Speed: 4.201Ghz
    Total Physical Memory: 32GB @ 1333 1333 1333 1333Mhz
    Drive Model: Samsung SSD 960 PRO 1TB
    Graphics Card: NVIDIA GeForce GTX 1080 Ti
    Driver version: 22.21.13.8205
    Screen Resolution: 2560x1600x32bit @ 59Hz
    RAW DATA:
        8.008    6.891    6.852   update previous version file
        2.844    2.750    2.695   opening and loading the custom template
        9.711    9.812    9.699   creating the floors levels and grids
       16.305   17.500   16.484   creating a group of walls and doors
       29.438   30.180   29.398   modifying the group by adding a curtain wall
        9.805    9.758    9.840   creating the exterior curtain wall
        8.469    8.578    8.734   creating the sections
        3.508    3.445    3.453   changing the curtain wall panel type
       11.238   11.348   11.477   creating area plans
        1.562    1.574    1.621   creating and applying view template
       50.781   50.223   50.500   export all views as PNGs at 300 dpi
       41.164   41.164   41.047   export all views as DWFs
       82.047   82.106   81.332   export all views as DWGs
       48.906   48.266   48.504   print all views as vector
       70.578   69.980   70.664   print all views as raster
       67.977   67.582   67.715   render
        3.500    3.582    3.527   activate View Styles view
        0.410    0.418    0.406   change view to Wireframe
        0.852    0.844    0.902   change view to Hidden
        1.059    1.086    1.090   change view to Shaded
        1.035    1.051    1.051   change view to Consistent Colors
        1.691    1.672    1.648   change view to Realistic
        0.859    0.852    0.883   refresh Wireframe Line view x10
        3.555    3.613    3.574   refresh Hidden Line view x10
        3.723    3.727    3.766   refresh Shaded view x10
        3.594    3.590    3.609   refresh Consistent Colors view x10
        3.832    3.856    3.867   refresh Realistic view x10
        0.488    0.461    0.457   activate View Cube view
        3.844    3.621    3.703   rotate view x1
        0.492    0.508    0.477   activate View Styles - Sketchy view
        1.844    1.875    1.938   change sketchy view to Wireframe
        1.164    1.180    1.184   change sketchy view to Hidden
        1.402    1.453    1.402   change sketchy view to Shaded
        1.414    1.434    1.492   change sketchy view to Consistent Colors
        1.277    1.266    1.293   change sketchy view to Realistic
        1.527    1.520    1.574   refresh sketchy Wireframe Line view x10
        4.207    4.242    4.254   refresh sketchy Hidden Line view x10
        4.379    4.398    4.418   refresh sketchy Shaded view x10
        4.262    4.270    4.258   refresh sketchy Consistent Colors view x10
        4.516    4.523    4.516   refresh sketchy Realistic view x10
        0.531    0.535    0.527   activate View Cube - Sketchy view
       16.461   16.609   16.477   rotate sketchy view x1
    worxman02 likes this.
    December 21, 2010
    C.LONDON
    4,339
    09:59 AM
    Welcome to the forum Trey!
    Forum Addict Robin Deurloo's Avatar
    July 7, 2011
    Rotterdam, Holland
    1,058
    10:59 AM
    Never actually ran the benchmark. But going to drink a Beer with Gordon tomorrow, so I feel obligated to do so .
    Machine runs OK for the size of the projects I do, but am looking to buy a new one depending on what the financial numbers are at the end of the year
    Code:
    RVT 2018 - Full_Standard set - 2017.10.20 @ 21.48.40 on WORKSTATION.txt
    RevitForum.org
    Run on Revit 2018.2
    Update
       11.96   update previous version file
        4.67   opening and loading the custom template
       15.50   creating the floors levels and grids
       29.75   creating a group of walls and doors
       56.33   modifying the group by adding a curtain wall
       17.53   creating the exterior curtain wall
       13.81   creating the sections
        6.30   changing the curtain wall panel type
       19.31   creating area plans
        2.64   creating and applying view template
      165.84   TOTAL
    Export benchmark
       84.85   export all views as PNGs at 300 dpi
       84.10   export all views as DWFs
      163.34   export all views as DWGs
    80142.63   print all views as vector *
    80142.64   print all views as raster *
    Notes:
    Render benchmark
      207.41   render
        7.21   activate View Styles view
        0.87   change view to Wireframe
        1.76   change view to Hidden
        2.31   change view to Shaded
        2.34   change view to Consistent Colors
        3.30   change view to Realistic
        2.13   refresh Wireframe Line view x10
        7.22   refresh Hidden Line view x10
        7.86   refresh Shaded view x10
        7.44   refresh Consistent Colors view x10
        8.16   refresh Realistic view x10
        1.06   activate View Cube view
        5.55   rotate view x1
       57.21   TOTAL
        0.71   activate View Styles - Sketchy view
        3.67   change sketchy view to Wireframe
        2.30   change sketchy view to Hidden
        2.87   change sketchy view to Shaded
        2.95   change sketchy view to Consistent Colors
        2.72   change sketchy view to Realistic
        3.18   refresh sketchy Wireframe Line view x10
        8.54   refresh sketchy Hidden Line view x10
        8.97   refresh sketchy Shaded view x10
        8.74   refresh sketchy Consistent Colors view x10
        9.40   refresh sketchy Realistic view x10
        1.14   activate View Cube - Sketchy view
        6.56   rotate sketchy view x1
       61.75   TOTAL
    Notes:
    TEST CONDITIONS:
    Mfr: MSI
    Model: MS-7673
    CPU: Intel(R) Core(TM) i5-2500K CPU @ 3.30GHz
    Max Clock Speed: 3.301Ghz
    Total Physical Memory: 8GB @ 1333 1333 1333 1333Mhz
    Drive Model: Samsung SSD 850 PRO 256GB ATA Device
    Graphics Card: NVIDIA GeForce GTX 770
    Graphics RAM: 2GB
    Driver version: 23.21.13.8792
    Screen Resolution: 1920x1080x32bit @ 60Hz
    RAW DATA:
       12.203   11.852   11.828   update previous version file
        3.727    6.477    3.812   opening and loading the custom template
       15.156   15.219   16.117   creating the floors levels and grids
       29.500   30.094   29.656   creating a group of walls and doors
       55.438   56.922   56.625   modifying the group by adding a curtain wall
       17.352   17.766   17.477   creating the exterior curtain wall
       13.984   13.773   13.672   creating the sections
        6.273    6.445    6.180   changing the curtain wall panel type
       19.047   20.031   18.844   creating area plans
        2.727    2.578    2.602   creating and applying view template
       84.219   86.898   83.430   export all views as PNGs at 300 dpi
       84.656   85.133   82.516   export all views as DWFs
      161.234  169.734  159.039   export all views as DWGs
    79152.21080139.76081135.930   print all views as vector
    79152.21080139.77081135.930   print all views as raster
      205.523  228.094  188.617   render
        7.320    7.156    7.148   activate View Styles view
        0.781    0.836    0.992   change view to Wireframe
        1.719    1.750    1.820   change view to Hidden
        2.211    2.492    2.227   change view to Shaded
        2.422    2.281    2.305   change view to Consistent Colors
        3.414    3.453    3.023   change view to Realistic
        2.172    2.242    1.977   refresh Wireframe Line view x10
        7.117    7.367    7.172   refresh Hidden Line view x10
        7.844    8.102    7.648   refresh Shaded view x10
        7.258    7.766    7.297   refresh Consistent Colors view x10
        8.188    8.398    7.891   refresh Realistic view x10
        1.055    1.109    1.008   activate View Cube view
        5.555    5.758    5.328   rotate view x1
        0.570    0.797    0.758   activate View Styles - Sketchy view
        3.703    3.695    3.617   change sketchy view to Wireframe
        2.438    2.164    2.289   change sketchy view to Hidden
        2.703    2.992    2.906   change sketchy view to Shaded
        2.828    3.094    2.914   change sketchy view to Consistent Colors
        2.641    2.922    2.594   change sketchy view to Realistic
        3.219    3.258    3.070   refresh sketchy Wireframe Line view x10
        8.430    8.836    8.367   refresh sketchy Hidden Line view x10
        9.000    9.141    8.781   refresh sketchy Shaded view x10
        8.531    9.102    8.578   refresh sketchy Consistent Colors view x10
        9.305    9.688    9.211   refresh sketchy Realistic view x10
        1.133    1.148    1.148   activate View Cube - Sketchy view
        6.680    6.750    6.258   rotate sketchy view x1
    May 2, 2017
    8
    02:59 AM
    Here are my 2018 results using custom built desktops running i7-7700k 4.2 stock and Turbo is set to 4.8 all cores and RAM is two 16GB sticks dual channel at 2900MHz with Nvidia GTX 1050.
    Code:
    RVT 2018 - Full_Standard set - 2017.10.31 @ 15.59.54 on ENGR115.txt
        RevitForum.org
    Run on Revit 2018.2
    Update
        6.18   update previous version file
        2.44   opening and loading the custom template
        7.51   creating the floors levels and grids
       14.34   creating a group of walls and doors
       27.29   modifying the group by adding a curtain wall
        8.45   creating the exterior curtain wall
        7.19   creating the sections
        3.01   changing the curtain wall panel type
        9.37   creating area plans
        1.30   creating and applying view template
       80.90   TOTAL
    Export benchmark
       49.10   export all views as PNGs at 300 dpi
       37.52   export all views as DWFs
       75.94   export all views as DWGs
       43.27   print all views as vector *
       71.24   print all views as raster *
    Notes:
    Render benchmark
       63.89   render
        3.19   activate View Styles view
        0.42   change view to Wireframe
        0.69   change view to Hidden
        0.90   change view to Shaded
        0.89   change view to Consistent Colors
        1.45   change view to Realistic
        0.72   refresh Wireframe Line view x10
        2.86   refresh Hidden Line view x10
        2.98   refresh Shaded view x10
        2.86   refresh Consistent Colors view x10
        3.14   refresh Realistic view x10
        0.37   activate View Cube view
        2.57   rotate view x1
       23.04   TOTAL
        0.34   activate View Styles - Sketchy view
        1.59   change sketchy view to Wireframe
        1.00   change sketchy view to Hidden
        1.20   change sketchy view to Shaded
        1.22   change sketchy view to Consistent Colors
        1.09   change sketchy view to Realistic
        1.35   refresh sketchy Wireframe Line view x10
        3.47   refresh sketchy Hidden Line view x10
        3.64   refresh sketchy Shaded view x10
        3.49   refresh sketchy Consistent Colors view x10
        3.76   refresh sketchy Realistic view x10
        0.45   activate View Cube - Sketchy view
        4.49   rotate sketchy view x1
       27.09   TOTAL
    Notes:
    TEST CONDITIONS:
    Max Turbo All Cores: 4.8GHz
    Total Physical Memory: 32GB @ 2900 2900Mhz
    Drive Model: Samsung SSD 850 EVO 500GB
    Graphics Card: NVIDIA GeForce GTX 1050
    Graphics RAM: 2GB
  1. RFO Benchmark v3 2017 results
    By Gordon Price in forum Hardware and Infrastructure
    Last Post: May 9th, 2018, 08:20 AM
  2. RFO Benchmark v3 2015 results
    Last Post: June 22nd, 2017, 11:39 AM
  3. RFO Benchmark v3 2016 results
    Last Post: May 9th, 2017, 12:00 AM
  4. RFO Benchmark 2013 results - Citrix Xenapp
    By Markus in forum Hardware and Infrastructure
    Last Post: September 18th, 2014, 02:08 PM
