Page 7 of 10 FirstFirst ... 345678910 LastLast
Results 61 to 70 of 94
Like Tree12Likes
Thread: RFO Benchmark v3.1 2018 results
  1. #61
    December 30, 2017
    2
    11:05 PM
    Here's one of the computers of my office. i5 6600k - GTX 960 - SSD Samsung 850 Evo 256gb - 16GB RAM
    Code:
    RVT 2018 - Full_Simplified set - 2018.05.24 @ 16.18.28 on GXX.txt
        RFO Benchmark v3.1 (build 01.09.2017)
        RevitForum.org
    All times are in seconds, lower is better.
    Run on Revit FCS
    _________________________________________________________________
    Model creation benchmark
        3.05   opening and loading the custom template
       10.33   creating the floors levels and grids
       18.73   creating a group of walls and doors
       34.55   modifying the group by adding a curtain wall
       11.39   creating the exterior curtain wall
       10.15   creating the sections
        4.01   changing the curtain wall panel type
       14.79   creating area plans
        1.91   creating and applying view template
      108.91   TOTAL
    Graphics
        4.00   activate View Styles view
        1.45   change view to Wireframe
        0.11   change view to Hidden
        0.42   change view to Shaded
        0.45   change view to Consistent Colors
        0.43   change view to Realistic
        1.15   refresh Wireframe Line view x10
        4.46   refresh Hidden Line view x10
        4.55   refresh Shaded view x10
        4.41   refresh Consistent Colors view x10
        5.40   refresh Realistic view x10
        0.48   activate View Cube view
        3.24   rotate view x1
       30.55   TOTAL
    Notes:
        Graphics benchmark measures the entire graphics stack, which includes CPU and memory.
        To meaningfully compare graphics cards, test all cards in the same machine
        and use the 'Graphics - expanded' benchmark.
    TEST CONDITIONS:
    Mfr: System manufacturer
    Model: System Product Name
    OS: Microsoft Windows 10 Pro64-bit
    CPU: Intel(R) Core(TM) i5-6600K CPU @ 3.50GHz
    Max Clock Speed: 3.501Ghz
    Number of Processors: 4
    Number of Logical Processors: 4
    Total Physical Memory: 16GB @ 2133 2133Mhz
    Drive Type: local Disk (NTFS)
    Drive Model: Samsung SSD 850 EVO 250GB
    Graphics Card: NVIDIA GeForce GTX 960
    Graphics RAM: 2GB
    Driver version: 23.21.13.8813
    Screen Resolution: 1920x1080x32bit @ 60Hz
  2. #62
    Junior Member fafa007's Avatar
    June 9, 2011
    Panam
    21
    11:05 PM
    Hello all,
    Do you know if it's possible to know if TurboBoost from Intel processor is activated or activated as needed on your computer ?
    This article say it depend of various factors : https://www.intel.com/content/www/us...echnology.html
    Actualy i7-8700k seems the most powered single thread processor ( https://www.cpubenchmark.net/singleThread.html ) and is Clockspeed: 3.7 GHz and Turbo Speed: 4.7 GHz so just near @remiscs show brillantly to us.
    But if your configuration don't allow TurboBoost ;(
    By the way, I'll try my next configuration with faster RAM, thanks @remiscs.
  3. #63
    February 10, 2011
    29
    06:05 PM
    I will be writing a post about a Dell 5820 I have been testing with several different graphics cards; such as NVIDIA GeForce 1070, 1080, Quadro P2000, P5000, P6000 and several combinations of one and two GP100s. I also test the Xeon with various cores turned off via the BIOS. Overall impressive results w/o any overclocking, liquid cooling or resolution adjustments. Watch for it on BIM Chapters, www.bimchapters.blogspot.com
    Code:
    RVT 2018 - Full_Standard set - 2018.04.19 @ 08.08.02 on DESKTOP-MJK4MTO.txt
        RevitForum.org
    Run on Revit 2018.3
    Update
        7.07   update previous version file
        2.71   opening and loading the custom template
        8.49   creating the floors levels and grids
       15.39   creating a group of walls and doors
       28.38   modifying the group by adding a curtain wall
        9.15   creating the exterior curtain wall
        7.90   creating the sections
        3.36   changing the curtain wall panel type
       11.47   creating area plans
        1.52   creating and applying view template
       88.37   TOTAL
    Export benchmark
       54.83   export all views as PNGs at 300 dpi
       43.10   export all views as DWFs
       81.70   export all views as DWGs
       49.13   print all views as vector *
       82.42   print all views as raster *
    Notes:
     *  Print Views tests require the 'Microsoft XPS Document Writer' printer be installed.
    Render benchmark
       70.18   render
    Graphics - Standard View
        3.66   activate View Styles view
        0.42   change view to Wireframe
        0.75   change view to Hidden
        0.98   change view to Shaded
        0.95   change view to Consistent Colors
        1.56   change view to Realistic
        0.79   refresh Wireframe Line view x10
        3.07   refresh Hidden Line view x10
        3.23   refresh Shaded view x10
        3.10   refresh Consistent Colors view x10
        3.36   refresh Realistic view x10
        0.40   activate View Cube view
        2.63   rotate view x1
       24.90   TOTAL
    Graphics - Sketchy View
        0.35   activate View Styles - Sketchy view
        1.74   change sketchy view to Wireframe
        1.04   change sketchy view to Hidden
        1.32   change sketchy view to Shaded
        1.32   change sketchy view to Consistent Colors
        1.19   change sketchy view to Realistic
        1.46   refresh sketchy Wireframe Line view x10
        3.77   refresh sketchy Hidden Line view x10
        3.93   refresh sketchy Shaded view x10
        3.79   refresh sketchy Consistent Colors view x10
        4.04   refresh sketchy Realistic view x10
        0.48   activate View Cube - Sketchy view
       10.05   rotate sketchy view x1
       34.48   TOTAL
    Notes:
    TEST CONDITIONS:
    Mfr: Dell Inc.
    Model: Precision 5820 Tower
    OS: Microsoft Windows 10 Pro for Workstations64-bit
    CPU: Intel(R) Xeon(R) W-2125 CPU @ 4.00GHz
    Max Clock Speed: 4.008Ghz
    Number of Logical Processors: 8
    Total Physical Memory: 128GB @ 2666 2666 2666 2666 2666 2666 2666 2666Mhz
    Drive Model: NVMe KXG50ZNV512G NVM
    Graphics Card: NVIDIA Quadro P6000
    Graphics RAM: 3.9990234375GB
    Driver version: 23.21.13.9133
    Screen Resolution: 1920x1200x32bit @ 59Hz
    remiscs likes this.
  4. #64
    Member remiscs's Avatar
    May 18, 2015
    Las Vegas, NV
    201
    03:05 PM
    Quote Originally Posted by fafa007 View Post
    Hello all,
    Easiest way to see what the CPU is doing is by either running MSI Afterburner or CPU-Z. MSI Afterburner will show you what the clocks speed of each thread is at. HWmonitor will as well but MSI AB will plot it on a graph. CPU-Z just shows you the highest clocked core at any given time.
    I have only done 8700k builds with the z370 chipset but when I have done K sku CPU on the H-series chipsets in the past the turbo clock worked normally. Basically 4.7ghz will occur at times but the 8700k tends to render on all cores at 4.3ghz. The 3.7ghz on all core I have never seen it that low. Might be is it is at 90-100c or something it will run that low.
    Intel is very vague with the exact parameters of turbo boost. There used to be charts of what clock speed it would be at depending on how many cores are used.
    Quote Originally Posted by UpNorth View Post
    (snipped)
    Looking forward to it.
  5. #65
    September 17, 2013
    2
    09:05 AM
    Hey all,
    Just ran the bench on one of our workstations main specs are:
    CPU: i7-6700k with AIO running very stable with OC @ 4.5Ghz
    MEM: 32Gb DDR4 @ 3000MHz, Corsair Vengeance LPX C15
    GPU: Nvidia GTX1060 6Gb (Asus Turbo blower style version)
    SSD: 480Gb Transcend SATA
    The system's over a year old now but still seems to fit as a nice price to performance system.
    Code:
    RVT 2018 - Full_Standard set - 2018.06.19 @ 11.27.08 on OMNII-CSQ-02.txt
        RevitForum.org
    Run on Revit 2018.3
    Update
        6.76   update previous version file
        2.99   opening and loading the custom template
        9.83   creating the floors levels and grids
       16.17   creating a group of walls and doors
       29.07   modifying the group by adding a curtain wall
        9.80   creating the exterior curtain wall
        8.94   creating the sections
        3.43   changing the curtain wall panel type
       13.32   creating area plans
        1.71   creating and applying view template
       95.26   TOTAL
    Export benchmark
       57.14   export all views as PNGs at 300 dpi
       42.86   export all views as DWFs
       92.93   export all views as DWGs
       56.86   print all views as vector *
       89.16   print all views as raster *
    Notes:
    Render benchmark
       71.05   render
        3.87   activate View Styles view
        0.41   change view to Wireframe
        0.72   change view to Hidden
        0.96   change view to Shaded
        0.94   change view to Consistent Colors
        1.52   change view to Realistic
        2.97   refresh Hidden Line view x10
        3.14   refresh Shaded view x10
        3.01   refresh Consistent Colors view x10
        3.31   refresh Realistic view x10
        0.42   activate View Cube view
        2.57   rotate view x1
       24.63   TOTAL
        1.72   change sketchy view to Wireframe
        1.03   change sketchy view to Hidden
        1.27   change sketchy view to Shaded
        1.30   change sketchy view to Consistent Colors
        1.14   change sketchy view to Realistic
        1.42   refresh sketchy Wireframe Line view x10
        3.61   refresh sketchy Hidden Line view x10
        3.79   refresh sketchy Shaded view x10
        3.63   refresh sketchy Consistent Colors view x10
        3.95   refresh sketchy Realistic view x10
        5.78   rotate sketchy view x1
       29.47   TOTAL
    Notes:
    TEST CONDITIONS:
    CPU: Intel(R) Core(TM) i7-6700K CPU @ 4.00GHz
    Total Physical Memory: 32GB @ 3000 3000Mhz
    Drive Model: TS480GSSD220S
    Graphics Card: NVIDIA GeForce GTX 1060 6GB
    Driver version: 23.21.13.9135
  6. #66
    January 23, 2012
    35
    06:05 PM
    Razer Blade 15" (2018) - i7-8750H CPU + GTX 1070 (8gb)
    This test is with a Razer Blade 15" Laptop connected to a 4k monitor. Ran 10 tests to make sure performance was consistent. Very happy with the $2,500 laptop!
    Code:
    RVT 2018 - Full_Standard set - 2018.06.30 @ 16.53.13 on BY1822A45003150.txt
        RevitForum.org
    Run on Revit 2018.3.1
    Update
        8.26   update previous version file
        4.23   opening and loading the custom template
       11.01   creating the floors levels and grids
       18.32   creating a group of walls and doors
       33.33   modifying the group by adding a curtain wall
       11.06   creating the exterior curtain wall
        9.92   creating the sections
        3.79   changing the curtain wall panel type
       14.06   creating area plans
        1.92   creating and applying view template
      107.64   TOTAL
    Export benchmark
       66.28   export all views as PNGs at 300 dpi
       46.69   export all views as DWFs
      102.36   export all views as DWGs
       62.65   print all views as vector *
      100.75   print all views as raster *
    Notes:
    Render benchmark
       72.34   render
        3.94   activate View Styles view
        0.44   change view to Wireframe
        0.74   change view to Hidden
        0.93   change view to Shaded
        1.62   change view to Realistic
        0.84   refresh Wireframe Line view x10
        3.24   refresh Hidden Line view x10
        3.44   refresh Shaded view x10
        3.27   refresh Consistent Colors view x10
        3.64   refresh Realistic view x10
        0.44   activate View Cube view
        2.84   rotate view x1
       26.32   TOTAL
        0.38   activate View Styles - Sketchy view
        1.97   change sketchy view to Wireframe
        1.09   change sketchy view to Hidden
        1.34   change sketchy view to Shaded
        1.36   change sketchy view to Consistent Colors
        1.20   change sketchy view to Realistic
        1.55   refresh sketchy Wireframe Line view x10
        3.96   refresh sketchy Hidden Line view x10
        4.17   refresh sketchy Shaded view x10
        3.99   refresh sketchy Consistent Colors view x10
        4.35   refresh sketchy Realistic view x10
        0.52   activate View Cube - Sketchy view
        5.02   rotate sketchy view x1
       30.90   TOTAL
    Notes:
    TEST CONDITIONS:
    Mfr: Razer
    Model: Blade
    OS: Microsoft Windows 10 Enterprise64-bit
    CPU: Intel(R) Core(TM) i7-8750H CPU @ 2.20GHz
    Max Clock Speed: 2.201Ghz
    Number of Processors: 6
    Number of Logical Processors: 12
    Total Physical Memory: 16GB @ 2667 2667Mhz
    Drive Model: SAMSUNG MZVLW512HMJP-00000
    Graphics Card: Intel(R) UHD Graphics 630
    Graphics RAM: 1GB
    Driver version: 23.20.16.4974
    Graphics Card: NVIDIA GeForce GTX 1070 with Max-Q Design
    Driver version: 23.21.13.8904
    Screen Resolution: 3840 x2160 x32bit @ 29 Hz
    RAW DATA:
        8.723>    8.1370    8.125<    8.5120    8.2660    8.3050    8.1950    8.1480    8.2810    8.2190   update previous version file
        3.969<    4.2300    4.375>    4.3280    4.2420    4.1950    4.1880    4.2190    4.1330    4.3360   opening and loading the custom template
       11.0940   10.9180   10.9450   10.9690   10.9800   11.0160   11.1250   11.188>   11.0700   10.898<   creating the floors levels and grids
       18.3560   18.3630   18.4180   18.3200   18.2540   18.2340   18.2890   18.477>   18.2970   18.156<   creating a group of walls and doors
       33.730>   33.1440   33.6910   33.3790   33.2380   33.1480   33.4380   33.5230   33.1020   32.875<   modifying the group by adding a curtain wall
       11.0310   10.9880   11.0430   11.0700   11.0080   11.1090   11.1640   11.289>   10.984<   11.0700   creating the exterior curtain wall
        9.793<    9.8670    9.996>    9.8050    9.9450    9.9380    9.9380    9.9840    9.9060    9.9450   creating the sections
        3.7810    3.75<    3.8320    3.7500    3.7580    3.7890    3.8120    3.844>    3.7890    3.7730   changing the curtain wall panel type
       14.0040   13.8980   14.1480   13.9410   13.809<   14.0310   14.0390   16.969>   13.8910   14.5550   creating area plans
        1.9180    1.8940    1.9180    1.8940    1.8870    2.0390    1.9300    2.086>    1.8830    1.820<   creating and applying view template
       65.8940   65.8870   68.5940   65.449<   65.5620   65.6020   66.0310   68.766>   66.2030   66.4530   export all views as PNGs at 300 dpi
       46.5270   46.6950   46.6370   46.523<   46.6520   46.5620   46.8280   48.773>   46.8910   46.7420   export all views as DWFs
      104.1640  101.8280  102.6290  101.7890  101.586<  101.7500  102.0080  106.711>  101.7970  102.9450   export all views as DWGs
       62.6680   62.3440   63.0660   62.4380   62.2850   62.281<   62.6640   62.9220   62.8520   63.477>   print all views as vector
      100.8560  100.3520  101.3120  100.012<  100.3480  100.7190  100.4610  101.922>  100.8280  101.1090   print all views as raster
       72.2500   72.4020   83.676>   72.2730   71.844<   72.5080   72.5310   72.2810   72.0780   72.4060   render
        3.9800    3.8750    3.9410    3.9300    3.8830    3.9060    3.859<    3.9690    4.117>    4.0000   activate View Styles view
        0.4380    0.4410    0.4490    0.4380    0.430<    0.4300    0.461>    0.4530    0.4300    0.4610   change view to Wireframe
        0.730<    0.7300    0.766>    0.7460    0.7340    0.7420    0.7420    0.7420    0.7340    0.7340   change view to Hidden
        0.9570    0.922<    0.9300    0.9220    0.9220    0.9300    0.9220    0.9530    0.969>    0.9380   change view to Shaded
        0.9340    0.9450    0.9490    0.9340    0.914<    0.9140    0.9300    0.969>    0.9450    0.9300   change view to Consistent Colors
        1.6250    1.6090    1.6440    1.6210    1.594<    1.6090    1.6330    1.6330    1.688>    1.6090   change view to Realistic
        0.8520    0.8480    0.8360    0.8560    0.8440    0.8440    0.828<    0.8360    0.867>    0.8440   refresh Wireframe Line view x10
        3.2380    3.2270    3.270>    3.2340    3.2270    3.2420    3.2420    3.2500    3.2660    3.188<   refresh Hidden Line view x10
        3.4530    3.4380    3.473>    3.4690    3.4220    3.4220    3.4140    3.4610    3.4530    3.391<   refresh Shaded view x10
        3.2810    3.2580    3.305>    3.2580    3.2580    3.2660    3.2890    3.2890    3.2660    3.227<   refresh Consistent Colors view x10
        3.6440    3.6760    3.6330    3.6210    3.6250    3.6170    3.602<    3.6170    3.773>    3.6640   refresh Realistic view x10
        0.4380    0.4340    0.4380    0.453>    0.4380    0.430<    0.4380    0.4450    0.4450    0.4300   activate View Cube view
        2.8050    2.8480    2.8280    2.934>    2.8120    2.8980    2.8360    2.7730    2.9220    2.695<   rotate view x1
        0.348<    0.3560    0.3480    0.3590    0.4840    0.3520    0.492>    0.3520    0.4060    0.3590   activate View Styles - Sketchy view
        2.0080    1.9490    2.0040    1.9530    1.9610    1.938<    1.9840    1.9380    2.047>    1.9690   change sketchy view to Wireframe
        1.1290    1.0590    1.156>    1.1330    1.055<    1.0550    1.1020    1.0780    1.0860    1.0620   change sketchy view to Hidden
        1.293<    1.3280    1.3320    1.3280    1.3440    1.3200    1.359>    1.3520    1.3590    1.3360   change sketchy view to Shaded
        1.3630    1.344<    1.3480    1.3590    1.3590    1.3440    1.3590    1.367>    1.3590    1.3670   change sketchy view to Consistent Colors
        1.1950    1.176<    1.2110    1.2150    1.1950    1.1880    1.227>    1.1880    1.2270    1.1880   change sketchy view to Realistic
        1.5430    1.578>    1.5700    1.5430    1.5620    1.539<    1.5390    1.5470    1.5550    1.5620   refresh sketchy Wireframe Line view x10
        3.9840    3.9410    3.9610    3.9650    3.9530    3.9450    3.9380    3.9610    4.062>    3.930<   refresh sketchy Hidden Line view x10
        4.1840    4.125<    4.1840    4.1720    4.1800    4.1800    4.1800    4.1800    4.234>    4.1330   refresh sketchy Shaded view x10
        3.9840    3.9690    3.9840    4.0160    3.9770    3.961<    3.9840    4.0080    4.055>    3.9610   refresh sketchy Consistent Colors view x10
        4.3560    4.320<    4.3320    4.3560    4.3670    4.3360    4.3280    4.3590    4.406>    4.3280   refresh sketchy Realistic view x10
        0.5270    0.516<    0.5160    0.5200    0.531>    0.5310    0.5310    0.5160    0.5230    0.5230   activate View Cube - Sketchy view
        5.0310    5.0080    4.949<    5.0660    4.9770    5.0620    4.9840    5.0550    5.109>    4.9840   rotate sketchy view x1
    remiscs likes this.
  7. #67
    July 3, 2018
    1
    06:35 PM
    hello ... I registered a few minutes ago and downloaded a file I needed .. thank you for your contributions ..
  8. #68
    Member mjajansen's Avatar
    December 26, 2011
    116
    12:05 AM
    Did a run with overclock on 5.0 Ghz.
    Code:
    RVT 2018 - Full_Standard set - 2018.07.03 @ 11.16.41 on DESKTOP-BENEDEN.txt
        RevitForum.org
    Update
        6.31   update previous version file
        2.92   opening and loading the custom template
        8.83   creating the floors levels and grids
       14.55   creating a group of walls and doors
       26.70   modifying the group by adding a curtain wall
        9.02   creating the exterior curtain wall
        8.17   creating the sections
        3.20   changing the curtain wall panel type
       11.48   creating area plans
        1.55   creating and applying view template
       86.42   TOTAL
    Export benchmark
       52.20   export all views as PNGs at 300 dpi
       37.86   export all views as DWFs
       82.36   export all views as DWGs
       48.81   print all views as vector *
       80.68   print all views as raster *
    Notes:
    Render benchmark
       68.01   render
        3.72   activate View Styles view
        0.39   change view to Wireframe
        0.69   change view to Hidden
        0.90   change view to Shaded
        0.89   change view to Consistent Colors
        1.42   change view to Realistic
        0.73   refresh Wireframe Line view x10
        2.85   refresh Hidden Line view x10
        3.01   refresh Shaded view x10
        2.89   refresh Consistent Colors view x10
        3.15   refresh Realistic view x10
        0.38   activate View Cube view
        2.69   rotate view x1
       23.71   TOTAL
        0.40   activate View Styles - Sketchy view
        1.60   change sketchy view to Wireframe
        0.94   change sketchy view to Hidden
        1.20   change sketchy view to Shaded
        1.19   change sketchy view to Consistent Colors
        1.08   change sketchy view to Realistic
        1.29   refresh sketchy Wireframe Line view x10
        3.43   refresh sketchy Hidden Line view x10
        3.58   refresh sketchy Shaded view x10
        3.44   refresh sketchy Consistent Colors view x10
        3.71   refresh sketchy Realistic view x10
        0.45   activate View Cube - Sketchy view
        8.87   rotate sketchy view x1
       31.18   TOTAL
    Notes:
    TEST CONDITIONS:
    CPU: Intel(R) Core(TM) i7-7700K CPU @ 4.20GHz
    Max Clock Speed: 4.201Ghz
    Total Physical Memory: 32GB @ 2133 2133 2133 2133Mhz
    Drive Model: Samsung SSD 970 PRO 512GB
    Graphics Card: NVIDIA GeForce GTX 1070 Ti
    Screen Resolution: 2560x1440x32bit @ 59Hz
    RAW DATA:
        6.344    6.277    6.316   update previous version file
        2.945    2.894    2.918   opening and loading the custom template
        8.918    8.742    8.828   creating the floors levels and grids
       14.606   14.551   14.488   creating a group of walls and doors
       26.832   26.906   26.348   modifying the group by adding a curtain wall
        9.078    8.957    9.012   creating the exterior curtain wall
        8.141    8.062    8.309   creating the sections
        3.199    3.219    3.188   changing the curtain wall panel type
       11.566   11.535   11.324   creating area plans
        1.555    1.539    1.559   creating and applying view template
       52.320   52.234   52.043   export all views as PNGs at 300 dpi
       37.828   37.949   37.816   export all views as DWFs
       82.379   82.504   82.203   export all views as DWGs
       48.789   48.859   48.785   print all views as vector
       80.625   80.832   80.590   print all views as raster
       61.848   71.074   71.109   render
        3.707    3.719    3.730   activate View Styles view
        0.387    0.402    0.383   change view to Wireframe
        0.672    0.691    0.699   change view to Hidden
        0.918    0.891    0.883   change view to Shaded
        0.891    0.887    0.879   change view to Consistent Colors
        1.418    1.449    1.398   change view to Realistic
        0.734    0.730    0.715   refresh Wireframe Line view x10
        2.871    2.840    2.844   refresh Hidden Line view x10
        3.031    3.008    2.984   refresh Shaded view x10
        2.914    2.883    2.867   refresh Consistent Colors view x10
        3.180    3.137    3.125   refresh Realistic view x10
        0.375    0.379    0.394   activate View Cube view
        2.586    2.816    2.668   rotate view x1
        0.394    0.394    0.398   activate View Styles - Sketchy view
        1.625    1.594    1.590   change sketchy view to Wireframe
        0.977    0.918    0.926   change sketchy view to Hidden
        1.203    1.199    1.188   change sketchy view to Shaded
        1.172    1.195    1.203   change sketchy view to Consistent Colors
        1.086    1.074    1.082   change sketchy view to Realistic
        1.285    1.305    1.285   refresh sketchy Wireframe Line view x10
        3.461    3.453    3.391   refresh sketchy Hidden Line view x10
        3.625    3.566    3.562   refresh sketchy Shaded view x10
        3.457    3.422    3.434   refresh sketchy Consistent Colors view x10
        3.730    3.695    3.699   refresh sketchy Realistic view x10
        0.449    0.441    0.445   activate View Cube - Sketchy view
        8.910    8.938    8.762   rotate sketchy view x1
  9. #69
    February 10, 2011
    29
    06:05 PM
    Dell 7730 Precision laptop with i9 and Quadro P5200 results below. Pretty good number from 2.9GHz cpu.
    Also, here is a post I wrote about a bunch of benchmark tests I did with a Dell 5820 Precision tower using different NVIDIA cards: https://bimchapters.blogspot.com/201...sion-5820.html
    Fun stuff!
    RVT 2018 - Full_Standard set - 2018.07.03 @ 16.08.15 on DJSTINE02.txt
    RevitForum.org
    Run on Revit FCS
    __________________________________________________ _______________
    Update
    7.46 update previous version file
    2.85 opening and loading the custom template
    9.47 creating the floors levels and grids
    16.68 creating a group of walls and doors
    30.69 modifying the group by adding a curtain wall
    10.19 creating the exterior curtain wall
    9.44 creating the sections
    3.49 changing the curtain wall panel type
    12.86 creating area plans
    1.78 creating and applying view template
    97.45 TOTAL
    Export benchmark
    61.85 export all views as PNGs at 300 dpi
    44.55 export all views as DWFs
    100.04 export all views as DWGs
    59.89 print all views as vector *
    92.41 print all views as raster *
    Notes:
    Render benchmark
    60.98 render
    3.65 activate View Styles view
    0.73 change view to Hidden
    0.92 change view to Shaded
    1.59 change view to Realistic
    0.81 refresh Wireframe Line view x10
    3.08 refresh Hidden Line view x10
    3.32 refresh Shaded view x10
    3.18 refresh Consistent Colors view x10
    3.51 refresh Realistic view x10
    2.60 rotate view x1
    25.17 TOTAL
    0.34 activate View Styles - Sketchy view
    1.79 change sketchy view to Wireframe
    1.01 change sketchy view to Hidden
    1.29 change sketchy view to Consistent Colors
    1.15 change sketchy view to Realistic
    1.47 refresh sketchy Wireframe Line view x10
    3.76 refresh sketchy Hidden Line view x10
    3.96 refresh sketchy Shaded view x10
    3.84 refresh sketchy Consistent Colors view x10
    4.15 refresh sketchy Realistic view x10
    0.51 activate View Cube - Sketchy view
    4.57 rotate sketchy view x1
    29.11 TOTAL
    Notes:
    TEST CONDITIONS:
    Mfr: Dell Inc.
    Model: Precision 7730
    CPU: Intel(R) Core(TM) i9-8950HK CPU @ 2.90GHz
    Max Clock Speed: 2.904Ghz
    Total Physical Memory: 32GB @ 2667 2667 2667 2667Mhz
    Drive Model: KXG50ZNV256G NVMe TOSHIBA 256GB
    Graphics Card: NVIDIA Quadro P5200
    Driver version: 23.21.13.8908
  10. #70
    9,532
    05:05 PM
    My new desktop arrived from RemisCS. Im quite pleased. Its balls out fast.
    RVT 2018 - Full_Standard set - 2018.07.16 @ 14.50.14 on DESKTOP-BT3UAHV.txt
    RevitForum.org
    Update
    6.02 update previous version file
    2.58 opening and loading the custom template
    7.44 creating the floors levels and grids
    13.39 creating a group of walls and doors
    25.08 modifying the group by adding a curtain wall
    7.87 creating the exterior curtain wall
    7.18 creating the sections
    2.72 changing the curtain wall panel type
    9.95 creating area plans
    1.35 creating and applying view template
    77.56 TOTAL
    Export benchmark
    50.47 export all views as PNGs at 300 dpi
    36.87 export all views as DWFs
    78.93 export all views as DWGs
    47.99 print all views as vector *
    79.21 print all views as raster *
    Notes:
    Render benchmark
    41.41 render
    3.20 activate View Styles view
    0.32 change view to Wireframe
    0.54 change view to Hidden
    0.73 change view to Shaded
    0.72 change view to Consistent Colors
    1.25 change view to Realistic
    0.60 refresh Wireframe Line view x10
    2.49 refresh Hidden Line view x10
    2.66 refresh Shaded view x10
    2.54 refresh Consistent Colors view x10
    2.78 refresh Realistic view x10
    0.33 activate View Cube view
    1.98 rotate view x1
    20.14 TOTAL
    0.26 activate View Styles - Sketchy view
    1.36 change sketchy view to Wireframe
    0.79 change sketchy view to Hidden
    1.01 change sketchy view to Shaded
    1.01 change sketchy view to Consistent Colors
    0.91 change sketchy view to Realistic
    1.16 refresh sketchy Wireframe Line view x10
    3.05 refresh sketchy Hidden Line view x10
    3.21 refresh sketchy Shaded view x10
    3.09 refresh sketchy Consistent Colors view x10
    3.35 refresh sketchy Realistic view x10
    0.40 activate View Cube - Sketchy view
    3.71 rotate sketchy view x1
    23.31 TOTAL
    Notes:
    TEST CONDITIONS:
    CPU: Intel(R) Core(TM) i7-8086K CPU @ 4.00GHz
    Total Physical Memory: 64GB @ 3200 3200 3200 3200Mhz
    Drive Model: Samsung SSD 970 PRO 1TB
    Graphics Card: NVIDIA GeForce GTX 1080 Ti
    RAW DATA:
    6.266 5.906 5.887 update previous version file
    2.531 2.535 2.664 opening and loading the custom template
    7.457 7.418 7.453 creating the floors levels and grids
    13.281 13.438 13.457 creating a group of walls and doors
    25.078 25.094 25.062 modifying the group by adding a curtain wall
    7.777 7.977 7.859 creating the exterior curtain wall
    7.160 7.230 7.160 creating the sections
    2.711 2.734 2.723 changing the curtain wall panel type
    9.922 9.996 9.945 creating area plans
    1.312 1.379 1.363 creating and applying view template
    50.352 50.586 50.461 export all views as PNGs at 300 dpi
    36.902 36.922 36.785 export all views as DWFs
    78.750 79.418 78.633 export all views as DWGs
    47.781 48.332 47.856 print all views as vector
    79.133 79.488 79.016 print all views as raster
    41.559 41.191 41.492 render
    3.203 3.203 3.184 activate View Styles view
    0.320 0.328 0.324 change view to Wireframe
    0.539 0.539 0.535 change view to Hidden
    0.719 0.734 0.727 change view to Shaded
    0.727 0.719 0.727 change view to Consistent Colors
    1.254 1.246 1.238 change view to Realistic
    0.609 0.598 0.598 refresh Wireframe Line view x10
    2.492 2.504 2.488 refresh Hidden Line view x10
    2.664 2.668 2.656 refresh Shaded view x10
    2.531 2.551 2.527 refresh Consistent Colors view x10
    2.777 2.781 2.781 refresh Realistic view x10
    0.328 0.332 0.336 activate View Cube view
    1.996 1.980 1.953 rotate view x1
    0.262 0.266 0.266 activate View Styles - Sketchy view
    1.359 1.344 1.363 change sketchy view to Wireframe
    0.789 0.785 0.789 change sketchy view to Hidden
    1.012 1.016 1.016 change sketchy view to Shaded
    1.012 1.012 1.016 change sketchy view to Consistent Colors
    0.902 0.910 0.914 change sketchy view to Realistic
    1.160 1.160 1.152 refresh sketchy Wireframe Line view x10
    3.051 3.055 3.035 refresh sketchy Hidden Line view x10
    3.207 3.223 3.195 refresh sketchy Shaded view x10
    3.090 3.098 3.078 refresh sketchy Consistent Colors view x10
    3.352 3.367 3.336 refresh sketchy Realistic view x10
    0.398 0.402 0.394 activate View Cube - Sketchy view
    3.723 3.723 3.691 rotate sketchy view x1
    remiscs likes this.
  1. RFO Benchmark v3 2017 results
    By Gordon Price in forum Hardware and Infrastructure
    Last Post: May 9th, 2018, 08:20 AM
  2. RFO Benchmark v3 2015 results
    Last Post: June 22nd, 2017, 11:39 AM
  3. RFO Benchmark v3 2016 results
    Last Post: May 9th, 2017, 12:00 AM
  4. RFO Benchmark 2013 results - Citrix Xenapp
    By Markus in forum Hardware and Infrastructure
    Last Post: September 18th, 2014, 02:08 PM
