Results 1 to 6 of 6
Like Tree6Likes
  • 5 Post By Gordon Price
  • 1 Post By Gordon Price
Thread: RFO Benchmark v3.1
    Rotterdam, South Holland
    2,928
    08:00 PM
    RFO Benchmark v3.1
    Well, after a long, busy summer, RFO Benchmark v3.1 is finally here. My apologies for the delay. Next year... fewer changes!
    Please post your results in
    RFO Benchmark v3 2018 results
    RFO Benchmark v3 2017 results
    RFO Benchmark v3 2016 results
    This v3.1 benchmark changes a few things you should be aware of.
    1: Additional GPU testing options now allow detail heavy/large model testing.
    2: The Standard & Expanded GPU tests now compare Sketchy and non-Sketchy views for both the regen and view cube tests. The Simplified test does only includes standard views.
    3: Graphics without Hardware Acceleration has been moved to a standalone GPU only test.
    4: Improved reporting of Revit build information.
    5: Test resources are now copied to a dedicated folder for processing, so multiple machines can be benchmarked from a network RFO benchmark folder. This facilitates benchmarking en mass.
    6: Various performance issues have been addressed, mostly related to how long the benchmark takes to run, not the actual Revit processing performance.
    7: The bug related to unzipping with 7ZIP has been addressed, however, the best unarchiving approach remains simply right clicking the ZIP file and choosing Extract All, thus using the built in Windows UnZIP capability.
    As always, comparisons cannot be made between v3.1 and earlier versions. And it's worth the reminder, while comparisons of results reported here at RFO are interesting, and often entertaining, this is not appropriate data for purchasing decisions. To use RFO Benchmark for meaningful comparisons you need to ensure consistent test conditions with no extra software running, identical screen sizes, etc.
    Attached Files Attached Files
    troygates, esk0r, jraiten and 2 others like this.
    2,928
    08:00 PM
    So, I finally made time to finish this beast up. Sorry for the big delay. There was a LOT of under the hood fixes/changes this year, in both the PowerShell code and the Journal files, and this summer has been the busiest I have had in 10 years (woot to that!). I am making a promise to myself and everyone else now, there will NOT be so much change next year. My hope is that the journal files are now very stable, and next year we can simply add a 2019 suite and be done. time will tell.
    Thanks for your patience!
    Gordon
    jraiten likes this.
  3.    #3
    February 7, 2017
    3
    07:00 PM
    "Could not load module" error
    Great tool. Going to be busy benchmarking at work!
    Just a quick tip for those who are getting the "Could not load module" error: Navigate to the Resources folder, right-click on the file "RFOBenchmark.psm1" and select Properties. Then click on Unblock and the script should run. (This applies to all versions).
  4.    #4
    2,928
    08:00 PM
    VERY good point esk0r. Thanks for the heads up for everyone.
    Also, you can unblock the ZIP file prior to unzipping, and all contents will also be unblocked.
    Gordon
  5.    #5
    October 9, 2017
    1
    01:00 PM
    Hi, I am new. I did a google search for Revit Benchmarking that lead me here. I am not a Revit Ninja. I literally install it and patch it. I am using a Dell R730 running XenServer with some Nvidia cards and a issci back end tied to my SAN. The Revit Ninja's connect remotely via Citrix .ica. I want to test Revit 2016 and separately 2017 between SSDs on the server versus my SAN. Is there a benchmarking "profile" that I can use for this type of setup?
  6.    #6
    October 19, 2017
    1
    01:00 PM
    Hello - new to the group so here goes. Run my first test this morning and these are the results. Not real sure how to read this - How does it look? what test should I run next? If I would save this folder on my network drive would the test still work? (this would be where we save all our Central Revit files.)
    Thank you.
    RVT 2017 - Full_Standard set - 2017.10.19 @ 05.32.05 on IC-JOSHGBIM.txt
    RFO Benchmark v3.1 (build 01.09.2017)
    RevitForum.org
    All times are in seconds, lower is better.
    Run on Revit 2017.2.2
    __________________________________________________ _______________
    Update
    7.29 update previous version file
    Model creation benchmark
    3.17 opening and loading the custom template
    11.86 creating the floors levels and grids
    20.47 creating a group of walls and doors
    37.03 modifying the group by adding a curtain wall
    12.88 creating the exterior curtain wall
    8.52 creating the sections
    4.06 changing the curtain wall panel type
    9.84 creating area plans
    1.46 creating and applying view template
    109.29 TOTAL
    Export benchmark
    62.17 export all views as PNGs at 300 dpi
    47.63 export all views as DWFs
    102.41 export all views as DWGs
    69.99 print all views as vector *
    104.58 print all views as raster *
    Notes:
    * Print Views tests require the 'Microsoft XPS Document Writer' printer be installed.
    Render benchmark
    66.05 render
    Graphics - Standard View
    4.97 activate View Styles view
    0.42 change view to Wireframe
    1.14 change view to Hidden
    1.19 change view to Shaded
    1.14 change view to Consistent Colors
    1.92 change view to Realistic
    0.94 refresh Wireframe Line view x10
    3.95 refresh Hidden Line view x10
    4.18 refresh Shaded view x10
    3.93 refresh Consistent Colors view x10
    4.32 refresh Realistic view x10
    0.52 activate View Cube view
    3.58 rotate view x1
    32.20 TOTAL
    Graphics - Sketchy View
    0.56 activate View Styles - Sketchy view
    2.16 change sketchy view to Wireframe
    1.26 change sketchy view to Hidden
    1.64 change sketchy view to Shaded
    1.66 change sketchy view to Consistent Colors
    1.41 change sketchy view to Realistic
    1.83 refresh sketchy Wireframe Line view x10
    4.82 refresh sketchy Hidden Line view x10
    5.09 refresh sketchy Shaded view x10
    4.85 refresh sketchy Consistent Colors view x10
    5.22 refresh sketchy Realistic view x10
    0.63 activate View Cube - Sketchy view
    13.42 rotate sketchy view x1
    44.55 TOTAL
    Notes:
    Graphics benchmark measures the entire graphics stack, which includes CPU and memory.
    To meaningfully compare graphics cards, test all cards in the same machine
    and use the 'Graphics - expanded' benchmark.
    TEST CONDITIONS:
    Mfr: To Be Filled By O.E.M.
    Model: To Be Filled By O.E.M.
    OS: Microsoft Windows 10 Pro64-bit
    CPU: Intel(R) Core(TM) i7-6850K CPU @ 3.60GHz
    Max Clock Speed: 3.601Ghz
    Number of Processors: 6
    Number of Logical Processors: 12
    Total Physical Memory: 64GB @ 3200 3200 3200 3200Mhz
    Drive Type: local Disk (NTFS)
    Drive Model: Samsung SSD 960 EVO 500GB
    Graphics Card: NVIDIA GeForce GTX 1080
    Graphics RAM: 3.9990234375GB
    Driver version: 22.21.13.8253
    Screen Resolution: 2560x1440x32bit @ 59Hz
    RAW DATA:
    7.357 7.225 7.273 update previous version file
    3.150 3.191 3.166 opening and loading the custom template
    11.633 12.012 11.945 creating the floors levels and grids
    20.785 20.445 20.166 creating a group of walls and doors
    37.393 36.760 36.928 modifying the group by adding a curtain wall
    12.621 12.594 13.424 creating the exterior curtain wall
    8.367 8.328 8.879 creating the sections
    4.020 3.982 4.180 changing the curtain wall panel type
    9.564 9.738 10.209 creating area plans
    1.428 1.432 1.516 creating and applying view template
    62.002 61.516 62.992 export all views as PNGs at 300 dpi
    47.965 46.832 48.098 export all views as DWFs
    99.111 107.002 101.129 export all views as DWGs
    66.797 75.045 68.121 print all views as vector
    94.207 112.434 107.104 print all views as raster
    64.600 65.135 68.418 render
    5.006 4.938 4.957 activate View Styles view
    0.414 0.418 0.434 change view to Wireframe
    1.119 1.141 1.156 change view to Hidden
    1.148 1.156 1.256 change view to Shaded
    1.113 1.146 1.156 change view to Consistent Colors
    1.898 1.883 1.980 change view to Realistic
    0.926 0.934 0.955 refresh Wireframe Line view x10
    3.896 3.924 4.022 refresh Hidden Line view x10
    4.143 4.203 4.205 refresh Shaded view x10
    3.875 3.879 4.037 refresh Consistent Colors view x10
    4.254 4.281 4.424 refresh Realistic view x10
    0.508 0.529 0.525 activate View Cube view
    3.527 3.541 3.666 rotate view x1
    0.547 0.555 0.570 activate View Styles - Sketchy view
    2.121 2.172 2.178 change sketchy view to Wireframe
    1.246 1.266 1.277 change sketchy view to Hidden
    1.600 1.643 1.672 change sketchy view to Shaded
    1.639 1.604 1.734 change sketchy view to Consistent Colors
    1.398 1.385 1.445 change sketchy view to Realistic
    1.812 1.818 1.857 refresh sketchy Wireframe Line view x10
    4.736 4.789 4.926 refresh sketchy Hidden Line view x10
    5.066 4.967 5.244 refresh sketchy Shaded view x10
    4.777 4.748 5.014 refresh sketchy Consistent Colors view x10
    5.156 5.115 5.398 refresh sketchy Realistic view x10
    0.611 0.633 0.633 activate View Cube - Sketchy view
    13.369 13.279 13.625 rotate sketchy view x1
  1. RFO Benchmark v3
    By Gordon Price in forum Hardware and Infrastructure
    Last Post: August 28th, 2017, 01:18 AM
  2. RFO Benchmark v3 2017 results
    Last Post: August 21st, 2017, 02:10 PM
  3. RFO Benchmark 3.1 beta
    Last Post: August 18th, 2017, 08:51 PM
  4. RFO Benchmark v2
    Last Post: March 13th, 2017, 09:44 PM
